Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Blemco Brackets w/ 12.75" 350z Rotors?
Old Jul 24, 2013 | 10:43 AM
nishfish871's Avatar
Dimension wise it looks possible. The 12.75" rotors are at about the same price as 12.6". Offer a lot more ventilation 30mm vs 24mm. My calipers have been shaved slightly on the inside, but I have another pair that hasn't. I will try both when mocking up. This should get rid of the pad overhang most people are having. Has anyone proven this setup?
Dimensions:
12.6"
12.75"
Old Jul 27, 2013 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
The maxima rotor you have up there is the rear
This is the front:
Old Jul 27, 2013 | 08:48 AM
Crusher103's Avatar
^I 'd
But I doubt it would fit unless you use a larger caliper. Search Zilvia they use the 350Z brembo rotors all the time for their 300zx upgrades.
Old Jul 27, 2013 | 09:44 AM
Kevlo911's Avatar
Kevlo for President
I think it will fit though, i have a brake pad overhang and this rotor might fix it.
Prop easily just to buy a cheap autozone rotor and try it, if no good return it...
Old Jul 29, 2013 | 03:14 PM
ranmas2004's Avatar
22.5lbs...DAYUM thats heavy..thats why I haven't done that 6th gen upgrade. The rotor is just a boat anchor.
Old Jul 31, 2013 | 11:00 AM
MrEous's Avatar
^ Jeff™
Um Javon you have little to worry about with your power setup... Lolol
Old Aug 2, 2013 | 04:18 PM
MAXIMA_STYLE's Avatar
There's a few local guys running 12.75 rotors from brembo equipped Z's but I think they have the doggone mounts and not Matty's. I'd like to know as well cause I have a set of brackets sitting here and been debating for over a month which to buy
Old Aug 2, 2013 | 08:01 PM
Crusher103's Avatar
350Z brembo rotors would fix the pad overhang but you need different brackets not the ones for the cobra rotors.
Old Aug 6, 2013 | 10:12 AM
Solicitous's Avatar
It's funny cuz I'm going to run the 240 brackets for the 12.75 set up. The s14 5 lug can take the 4gen calipers and rotor with no mods there for we can run that bracket kit for 12.75 brembo rotors kit.
Old Sep 16, 2013 | 04:57 PM
marke's Avatar
^^ what's the status on this? I'm interested in this setup too.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
Calabar
Oct 5, 2015 09:57 PM
Socalstillen
Sep 26, 2015 12:01 PM
