Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
6gen Brakes swap into 4gen that fits 16s
Old Jan 13, 2015 | 12:42 PM
vipervadim's Avatar
I like Maximas
Thumbs up 6gen Brakes swap into 4gen that fits 16s
Another Project from 2014
6gen brakes swap into 4th gen Maxima that clear 16in rims
I've seen plenty of 6th gen brake swaps into 4th/5th gens but I've never seen them modified to clear 16in rims.
I have 16s, spring and stuts, I plow through potholes in NYC, I'm never going to drive low and SLOW and avoid all potholes like some others with huge rims and lowered cars.
With that being said, I needed bigger brakes to help me SLOW down better.
I already had 11" 2000 Max rotors and 4 piston wilwood dynalite calipers.
good for 60-0mph stops, but doesn't fare too well with repeated high speed braking (100mph+)
so back to the drawing board I went - The result is this thread
old brake setup: 2000 Maxima(thicker than 95-99) 11" rotor with dynalite 4-piston wilwoods
they clear 15s with no problem!
OLD setup vs New (11" rotor vs 12.6" rotor)
here's where the fun begins:
To put 6th gen brakes into a 4th gen you need to enlarge the caliper mounting holes on the spindles.
stock is 12mm
need to enlarge holes to 14mm
So I got spare spindles, drilled them out, replaced wheel bearings, and cut off the heat/splash shields to clear bigger rotor.
I mounted the 6gen rotor and caliper to spindle with a wheel spacer to hold it in and test the fitment on 16s.
It didn't fit so time to bring out the grinder!
I grinded off the following parts of the caliper:
and then grinded some more and some more..
and then test fit it
and got it down to this
once it cleared without issues I painted them
old SS brake lines were all nasty and weathered so: New Goodridge SS brake lines
I did not need to use wheel spacers - they fit under the rims
SO TIIIIIIIIIGHT!!! I love it!!!
Braking is greatly improved. Had this setup since the end of summer and no rubbing, no issues just good brakes.
How do they compare to the wilwoods?
The wilwoods did have a better initial bite (4 piston clamp vs 1 piston) but when you step on the 6gens they just hold and hold like no tomorrow.
Wilwoods would hold until a certain point and then start slipping (rotors gets hot)
for a typical drive around there's no difference in braking 50-0, but when you push the car hard repeatedly, or braking from high speeds - they perform very well.
Project complete. Special thanks to IslandMax for the help and spare spindles
Old Jan 13, 2015 | 02:48 PM
Fakie J Farkerton's Avatar
Great work!
Good to see this can be done and we aren't stuck with 17" and up.
Old Jan 13, 2015 | 08:17 PM
95naSTA's Avatar
I went 5.5 gen so I could still fit 16s with DRs.. Cool to see a 1" larger rotor setup tucking under 16s.
Old Jan 13, 2015 | 08:52 PM
nismomaxgtr18's Avatar
Vadim! Good to see you still posting up even past the end of NYCMaximas. 6gen brakes FTW. I need to give you a call one of these days.
Old Jan 14, 2015 | 11:25 AM
vipervadim's Avatar
I like Maximas
You can grind down the 5.5gen calipers to fit 15" DRs
Yeah nycmaximas.org is gone, just as the maxima scene in nyc is pretty much dead. there's a few serious maxes still around
you have the number - my work/career still takes up most of my time as you know.
Old Jan 14, 2015 | 08:43 PM
maxfever1987's Avatar
This is definitely an amazing bbk setup, very cost effective and simple enough for anyone to install, I have done this in several 4th and 5th gens,
Wats up mitesh and Vadim?
Old Jan 16, 2015 | 03:04 AM
asand1's Avatar
How tall were those two high spots you knocked down? I will be doing the 6th gen swap as soon as my wife’s check comes in, but I am running 17" Mustang GTs. I'm just not sure how the 'Stang ID compares to Max ID, and I worry I might have to grind.
Old Jan 16, 2015 | 10:38 AM
vipervadim's Avatar
I like Maximas
You should have no problem fitting 17s over a 6gen BBK
otherwise grind those nubs down all the way and some on the sides.
Look at the before/after picture I posted where it shows the grinding up top
Old Jan 17, 2015 | 06:48 PM
maxprivate's Avatar
Black Lion
Holy moly thats a tight fit.. How are those Wilwoods gonna clear when you reinstall those? You have to grind those down as well.
Old Jan 30, 2015 | 04:21 AM
asand1's Avatar
I ordered Brakemotive powdercoated calipers with ceramic pads from ebay, and cheap rotors from Rockauto tonight for $193.80 total. Sourced 14mm bolts from a Mazda truck and just need fluid. now its a waiting game.
Old Jan 30, 2015 | 07:35 AM
schmellyfart's Avatar
A bit off topic, did those Wilwoods need an adapter bracket to bolt up to the 4th gen spindle?
Old Jan 30, 2015 | 08:12 AM
maxprivate's Avatar
Black Lion
YupP they do. But I think it really depends on the type of caliper you use. There are a bunch of different ones. Contact Fastbrakes, they can make a bracket for you. I'm going with a 6 piston Wilwood caliper and Brian at Fastbrakes is making the setup for my 97
Old Jan 30, 2015 | 09:30 AM
Even on the stock rotor? I'll look into fastbrakes.
Old Jan 30, 2015 | 09:40 AM
maxprivate's Avatar
Black Lion
Not sure about using stock rotors. I'm gonna be using Wilwood 2 peice rotors. 13 inch
Maybe Vadim can chime in.
Old Jan 30, 2015 | 10:34 AM
vipervadim's Avatar
I like Maximas
^^^ I really hope the bolts you picked up are right thread (I think M14x1.50), and are right length (just in case you might want to look into CL/ebay/junkyard - local parting out a 00-01 max or 02-08 maxima/altima to get the correct front caliper bolts, M35/g35/350z are different bolts - much longer) or can always order them from the nissan dealership in case it doesn't work out.
14mm = size of enlarged hole on stock 4gen spindle (12mm = size of original hole on spindle = you must drill out holes to fit new calipers on)
You will be drilling through cast steel and have to use a GOOD METAL drill bit to drill out the spindles.
If you cannot find a 14mm metric bit(order online), you can use a SAE 9/16 in (=14.2mm) bit to get it done. I still prefer the 14mm bit with a drill press as the clearances for brakes should be closer to prevent vibration/movement.
Good luck!
Old Jan 30, 2015 | 11:17 AM
vipervadim's Avatar
I like Maximas
yes they require an adapter bracket for stock 11" maxima rotors 95-01
Fastbrakes.com sells the wilwood dynalite kit for about $700, you would have to mention your application as they do not list it on the website.
They use a 2000-01 11" maxima rotor 24mm thick vs 21mm on 11" 4gen rotor.
Old Jan 30, 2015 | 01:08 PM
asand1's Avatar
Thank you for your concern, i have been familiar with this swap for five years and just waiting until i needed brakes to do it.
Yes, they are M14x1.50. If they are too long I will grind them flush, but I don't think I'll need to. There are not many Nissan/Infinities in the yard here so I gotta be more inventive.
I do have a 9/16 bit and 1/2" drill.
Sent from my XT1060 using Maxima
Old Jan 30, 2015 | 01:50 PM
Appreciate the info.
Old Feb 1, 2015 | 03:26 PM
t6378tp's Avatar
Turbo 3.5
well guess I'll been grinding my calipers this week to fit my z32 wheels
Old Feb 1, 2015 | 04:05 PM
nestorlugo's Avatar
I was gonna go j30 cuz i don't have doh to spend on 17" but a grinder is readily available....
Old Feb 3, 2015 | 03:49 AM
dwapenyi's Avatar
That's just insane. Great work
Old Feb 3, 2015 | 03:06 PM
Blackwind's Avatar
LENNY!!!!!! send me pics of what you doin, its Navfe
Old Feb 3, 2015 | 03:21 PM
Originally Posted by blackwind
lenny!!!!!! Send me pics of what you doin, its navfe
Old Feb 3, 2015 | 03:25 PM
Blackwind's Avatar
Originally Posted by Fakie J Farkerton
dont hate gurl lol
Old Feb 5, 2015 | 02:05 PM
asand1's Avatar
Brakes arrived today. Can't wait to get home and check them out. Will be raining for a week, though my next days off should be dry. :-)
Old Feb 5, 2015 | 07:44 PM
asand1's Avatar
Good luck!
The bolts i picked up were not M14x1.5. I went back to the wrecking yard and got the correct bolts.
Old Feb 13, 2015 | 04:57 AM
t6378tp's Avatar
Turbo 3.5
just installed my brakes and noticed you have to grinder more on the non bleeder side to clear 16inch wheels
Old Feb 13, 2015 | 03:14 PM
asand1's Avatar
Do these fit under STOCK 16s? I just installed mine with the mustang wheels, and they clear by a finger all the way around. Look super sexy too with the powder coat
Old Apr 4, 2015 | 05:17 AM
Maximeltman's Avatar
I'm attempting this as well will they clear my stock 16" rims?
Old Apr 4, 2015 | 05:35 AM
asand1's Avatar
IDK, op is running aftermarket 16s and had to grind the crap out of them. I imagine stock wheels might be thicker castings and require even more grinding.
It would be an expensive experiment unless you have a good wrecking yard with all the parts.
Old Apr 4, 2015 | 02:05 PM
Shoot! I wonder how much the structural integrity is jeapordized by grinding, I don't want to hit the brakes and suddenly be without said brakes
But I just bought some oem calipers and getting them blasted and picked up a new rebuild kit, some brembo rotors, already have the ss lines in the car, my currebt 4th gen brakes are shot anyways (I do engine braking mostly and it pizzes people off) so I'm going to try this with stock 16s but only if I don't have to grind too much off, if not then I'll have a nice brake package for sale I guess.
Another thing is the FSM states that the cylinder bores are the same for 4th gen and 6th gen, around 57mm.
Old Apr 4, 2015 | 04:14 PM
asand1's Avatar
Put em on a shelf and keep your eyes out for 17s. You eventually need tires anyway, right?
Old Apr 4, 2015 | 06:10 PM
yea I want to keep my 16s there are potholes-a-plenty in Nebraska...I was gonna buy some 16x8 nissan gt-r but someone bought them before me. Are those Cobra rims legit? They look great but hows the weight?
Old Apr 4, 2015 | 07:51 PM
asand1's Avatar
They're just gt rims I believe. Bought them at Les Schwab tires. OEM takeoffs. I believe the are 19lbs. $150 for all 4, brand new I think.
Old Apr 4, 2015 | 07:55 PM
Yea well I gottta fugure out my scenario when the calipers get back to me, Those red ones are nice do they still sell them? Might look up a local powdercoater..
Old Apr 4, 2015 | 08:38 PM
asand1's Avatar
Probably do. Brakemotive on eBay, and some on rockauto too. $246 I think for calipers, pads and slotted/dimpled rotors on eBay.
Old Apr 5, 2015 | 04:35 PM
nestorlugo's Avatar
Got mine ready screaming for paint
Old Apr 6, 2015 | 10:00 AM
[QUOTE=nestorlugo;9036844]Got mine ready screaming for paint:woot2QUOTE]
Nice!
And what rims are you using?
Old Apr 6, 2015 | 03:50 PM
nestorlugo's Avatar
Stock 5spoke 16"s
Old Apr 8, 2015 | 09:16 PM
Originally Posted by nestorlugo
Stock 5spoke 16"s
Really? How much did you shave off and do they still seem structuarlly sound? Post some pics when youre finished !
