Sponsored by:
Sponsored by: CARiD
The Great Gearhead thread
Old Nov 2, 2004 | 02:39 PM
  #41
MyownNismo's Avatar
Future Camaro SS owner
Would swapping parts be easier then putting the whole 3.5 in a 2000.
Old Nov 12, 2004 | 03:40 PM
  #42
SR20DEN's Avatar
VQ Wizard
VQ30DE Cams:
Pending
VQ30DE-K Cams:
Int: 8.55mm lift (gross)
Ex: 9.0mm lift (gross)
VQ35DE Cams:
Int: 9.5mm lift (gross)
Ex: 9.5mm lift (gross)
Old Nov 12, 2004 | 05:26 PM
  #43
JClaw's Avatar
Most likely the DE-K and DE cams are //
EDIT: It wasn't a question, SR, whether you read this or not. The joke was never funny, and this is just beating a dead horse. G'Night.
Old Nov 12, 2004 | 07:22 PM
  #44
SR20DEN's Avatar
VQ Wizard
Old Nov 13, 2004 | 01:44 PM
  #45
MyownNismo's Avatar
So what is easier to do. Use 3.5 parts in the 3.0 or drop a 3.5 into my 2000.
Old Nov 14, 2004 | 07:00 AM
  #46
JClaw's Avatar
There you go Nismo:
Originally Posted by SR20DEN
OK guys, Thanks to Dxit for sending me a VQ30DE-K head I now have tons of information comparing the two. I will just have to document everthing over the next couple of days but what I can say for sure already is that I wouldn't even consider putting the VQ30 heads on a VQ35 block or even a VQ33 stroker. You will never make any real NA power with these inferior heads unless you have some extensive work done to them. If you guys really want to make power then you need to use the VQ35 heads on your VQ30 blocks.
And at this point Im certain the VQ35 heads can be used with the VQ35 cams with no VTCs if you wish.
And on the flipside of that I am 99% certain (as of now) that the more agreesive VQ35 cams can be fitted onto the VQ30 heads so long as you lighten the valvetrain via VK45 Ti valves and retainers.
I will report the numbers as I get everything measured but I'll give you a short rundown for now.
VQ30 Intake ports: Smaller
VQ30 Intake valves: Smaller face
VQ30 Buckets/lifters: Wider, deeper, much heavier
VQ30 retainers: Heavier
VQ30 Cams: Less lift, less duration
The VQ30 has hydraulic lifters. And as far as I can determin the VQ35 has a solid lifter setup. There just isn't any type of cushioning device that can be called a lifter.
What sucks is that if we're going for N/A power the extra compression (11.5:1 versus 10.3:1 and 10:1) would be good for quite a few hp. We'd need everything from the 3.5 heads except, well, the combustion chamber, instead of the VQ30's 46cc.
The problem is that I don't know much much compression the 3.5 internals will be able to take. 11.5:1 seems really high.
Old Nov 14, 2004 | 08:22 AM
  #47
stephenlc's Avatar
Originally Posted by JClaw
There you go Nismo:
cars come from the factory with higher octane than that. So no worries.
Old Nov 14, 2004 | 08:56 AM
  #48
JClaw's Avatar
K. BTW, would adjusting the timing higher and running 94 Octane yeld the same hp/tq gains than a smaller combustion chamber/higher compression ratio? Cause I'm not sure the 3.0 heads could be modified with the 3.5 head parts and port matches to perfectly immitate a 3.5 head, except with the VQ30's smaller combustion chamber, which would basically give a nismo head.
Old Nov 14, 2004 | 10:28 AM
  #49
MyownNismo's Avatar
SR20DEN How can the 3.5 heads run without the VTC.
Old Dec 10, 2004 | 06:09 PM
  #50
SR20DEN's Avatar
VQ Wizard
I have the 2005 G35 and 350Z ESMs in my posession now. They're only listing the old cam specs.
They're supposed to have new cams and exhaust VTCs. None of which are listed.
Old Dec 10, 2004 | 06:29 PM
  #51
E55AMG2's Avatar
Wat
You could save yourself alot of headache and get domed pistons.
spazma7ik
Jan 12, 2017 09:38 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
wingnut2006
Sep 19, 2015 06:13 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
videomano
Sep 8, 2015 03:28 PM
