View Poll Results: Who will be first in the 12's?
SR20DEN
40
45.98%
TILLEYS99
19
21.84%
krismax
8.05%
vsamoylov
3.45%
Ceasar
3.45%
I30 mike
3.45%
other
13.79%
Voters: 87. You may not vote on this poll
Who will be the one to be in the 12's ...
Well if you use the occasion to put headers, flywheel an all on, plus lightweight 15" wheels and the rest of the N/A mods+ECU... mid 13s, street tires perhaps? I mean Tilley got 13.87 on 16" even with the restrictive 3.0 heads/manifold(US), no ecu...
Slow down here. When he gets an 8000 rpm redline he'll beat you, don't worry, I was just being conservative. I think with the right mods, a 3.5-powered 4th gen will eventually be able to break 12's NA on slicks. But not right away. You can't do everything at the same time, his 3.5 isn't fully modded like your 3.0. Give him the same time you had to mod yours.
And id like to see his 3.5 go to 8000
boom
They are a joke ,vasily shouldnt have to heavely modifiy his 3.5 in order to beat my times.SR20DEN car is not modded that much and runs a 13.1 @ 107 thats a insane trap also. And keep in mind its in a 5th gen,so vlastic should be much faster if not it was a waste
Originally Posted by krismax
I believe a 3.5 in a 4th gen is faster than a 3.0 in a 4th gen but the times you guys throw out that he should run
Fully modded are you joking ,i'am far from fully modded.
boom
boom
As for SR20DEN, yes he is running 13.19 on slicks, and yes, Neal was running 13.43 before some ****head smashed his car, but how many NA maximas are this fast? We don't know whether or not he's a good driver, at what elevation he's at, if he has a bad Knock Sensor, how ****ty his tires are, if he knows how to get a good launch ... ect. ect. ect.
That's my point. You have "only" a 3.0, but he can't go over 6600 right now, not 8000 like yours. I mean, how many guys other than you have taken their 3.0 up to 8000? None that I know of.
True, but he was lucky enough to get an entire car for 1550$. I couldn't find a smashed 2002+ Altima/Maxima for less than 6800$. JapMax couldn't find anything lower than 4000$ and Tilley didn't bother. The lack of variable Timing Control without the 5.5gen ECU will rob some power right there for anybody else doing this swap without going through the trouble of rewiring the entire car. So if he can't drive, we're not going to see a 3.5 powered 4th gen hitting 107+ trap speeds anytime soon. Also I don't think he has aftermarket headers/cat/catback and all.
Originally Posted by blubyu2k2
15x7 35-38 offset without a lip...need all the clearance we can get. Some 15's fit and some don't.
Originally Posted by spanishrice
why does SR need to rev to 8000 rpm. Kirsmax can't have any usable power that higfh in the rpm range with the mods he has.
But you guys forget one this weight determines usable power ,how does a civic with 156peak hp run 12.6 ? Trust me i use past 7500 in first and it pulls me. But i must say second is only good for 7600.
Don't foget to use the same dyno you used for 3.5/3.0 hybrid so we can the difference and if the 1.2:1 drop in comp ratio made a significant difference with the higher flowing heads.
Originally Posted by E55AMG2
Krismax: valve float doesnt bother you does it?
Thanks to the 31 people who voted for me. The task is complete and this competition is over. Now the 12.50 competition begins.
http://forums.maxima.org/showthread.php?t=377044
Same here [/shameless plug] Although I gave some thought to choosing Tilley instead.
It's gonna take a while for someone to break 11.99 N/A
But now i can concentrate on my 11 second goal
hey a max could be in the 9's if someone felt like spending enough money on it. i'm sure if we get krismax or sr to run low 12 then maybe go for some boost i dont see y low 10's wont be possible. but i dunno.
Guys, does anyone remember a certain Max clip of a beige? 4th gen that had some wild engine/cam work done IIRC. The small clip was of it in a store parking lot revving like crazy, sounded like a built engine w/open headers or something almost. Then the Max pulls out into traffic and takes off down the street......? I can't find the vid on my comp right now but was wondering what time that fellow ran...13's???
Just curious if anyone remembered what I'm talking about...
Jeremy
Jeremy
Jeremy
Jeremy
Congrats on the feat there SR20...when I used to run my Altima ('93) the fastest guy on the Altima forum had a bolt on '95 w/a 75shot and slicks...he ran a 13.1 and the fastest NA was a 13.9...Other than turboed Altimas, those were the fastest recorded Altys I think..
BTW, a Max member spread the word about the 12.85 run over at Altimas.net...the vast majority was very impressed and supportive...only a few of the '02+ Altima owners got a Napoleon complex...
Jeremy
Jeremy
If we get that from fellow Nissan guys, I have a hard time figuring out how anyone would ever convince an f-body/mustang owner that N/A maximas are running 12s...
