Sponsored by:
Sponsored by: CARiD
What has to be done to get 4th gen injectors to fit 00VI lower manifold?
Old Nov 18, 2004 | 11:57 AM
Stephen Max's Avatar
Anybody know?
Old Nov 18, 2004 | 12:10 PM
Pimpmobile's Avatar
nothing, they are not compatible. Atleast the 00 fule rail isnt. The 4thgen injectors are side feed while the 00+ are top feed.
IIRC
Old Nov 18, 2004 | 12:23 PM
krismax's Avatar
Father of the 00 VI
Originally Posted by Stephen Max
Anybody know?
00-01 injectors are top feed saturation and 95-99 are side feed peak and hold ,not going to happen id just get the 00 lower and aftermarket injectors and sell your setup.
You could get the 4th gen lower welded and machined to fit the 00 upper
Old Nov 18, 2004 | 12:27 PM
IIRC
Yeah, I know. But as far as inserting the 4th gen injectors and fuel rail into the 2k lower IM, what needs to be modified? Is it simply a matter of enlarging the diameter of the holes in the IM? Or what?
Old Nov 18, 2004 | 12:30 PM
krismax's Avatar
Father of the 00 VI
you would have to weld more metal in those spots and machine it like the 4th gen holes then weld and make tabs so the rail can be bolted on like the 4th gen because the 00-01 bolts on very different.
Much easier to weld and machine the top of the 4th gen manifold to fit the desired application
Old Nov 18, 2004 | 12:31 PM
Okay, thanks, Krismax.
Old Nov 18, 2004 | 12:32 PM
krismax's Avatar
Father of the 00 VI
the 00 lower is alot less beefy and weighs almost 4lbs less than the 4th gen one id have the top welded on the 4th taped and plained
Old Nov 24, 2004 | 10:53 PM
Nismo3112's Avatar
Custom User Title
Anyone know if I will run into problems when running the 00 injectors with like a JWT or Technosquare ECU programmed for the 4th gen?
Old Nov 25, 2004 | 06:15 AM
krismax's Avatar
Father of the 00 VI
I have a JW ecu and 00 injectors no problem and the 00 injectors are fine.
Old Dec 1, 2004 | 11:47 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just tell JWT you had RC Engineering make you *CUSTOM* 290cc injectors, otherwise they won't believe 2000-2001s don't use 240cc injectors.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
fulloboost
Sep 12, 2015 08:03 AM
tcb_02_max
Sep 11, 2015 12:23 PM
MaxStock
Aug 12, 2015 08:33 AM
