Sponsored by:
Sponsored by: CARiD
VQ35 longblock + VQ30 Cam Gear = What?
Old Nov 28, 2004 | 08:19 PM
Nismo3112's Avatar
Custom User Title
I just had a thought that if someone were to take a complete VQ35 motor,
used VQ30 cam gears, and the VQ30 timing cover, would that essentially take away the VTC, allowing the 4th gen cam pos sensor to be used on the VQ35 heads?, and not having to disassemble the engine for 3.0 heads?
The 3.0 cam pos sensor reads a signal off of the cams right? Someone please tell me this is the case!
Old Nov 28, 2004 | 08:31 PM
SR20DEN's Avatar
VQ Wizard
I think every possible combination has been discussed already.
Yes the VQ30 cam sensor reads the marks off the main timing gear.
Old Nov 29, 2004 | 08:55 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
you would have to ditch the following
3.5 cams
3.5TB
you would need to use...
3.0 timing covers
oil pan upper/lower
3.0 IAC modded to work with 2k2+IM
And a bunch of other lil wiring/and hoses
Im not sure on how the EGR will work either
Old Nov 29, 2004 | 11:22 AM
Nismo3112's Avatar
Custom User Title
Didn't you use the 3.5 oil pans? And that bolted up to the 3.0 timing cover right?
Old Nov 29, 2004 | 03:42 PM
TILLEYS99's Avatar
3.5 pan needs shaved too mount the CPS right. They will work either way its just the 3.5 one is a lil different.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
knight_yyz
Nov 1, 2015 01:34 PM
