Sponsored by:
Sponsored by: CARiD
Need help ASAP before i make a Purchase!!!
Old Jan 5, 2005 | 07:37 AM
chris'smax's Avatar
I just want to clarify a couple of things before i call and order the Hotshot headers for the 3.5. Keep in mind i have the 3.0
1) Is it necessary to hook up the EGR to the manifold. I do not want to risk not hooking it up if it will cause any negative affects.
2) New 02 bungs need to be welded on, AC compressor line moved are the only things that need to be changed.
3) In the end do you all think the labor will end up negating the savings of not going with the cattmans for the 3.0
Chris
Old Jan 5, 2005 | 11:15 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Not sure on those Chris, but FYI JWT is having a "sale" on them for $529 shipped, if that's a good price.
http://www.jimwolftechnology.com/hs_..._close_out.asp
Old Jan 5, 2005 | 12:17 PM
chris'smax's Avatar
dude that is a good price. They only have limited quantities so i guess i got to hurry up
Old Jan 5, 2005 | 01:05 PM
2kGLE's Avatar
1) Not sure about the EGR. Cant you just disconnect it?
2) Why not just get 02 sims like this: http://o2simulator.com/24803.html You have a test pipe so its not like you can just relocate them behind the cat. Or am i missing something?
3) I’m sure you’ll save money, but haven’t there been some inconsistencies with the quality of HS headers? I remember reading something about a “bad batch” or something. As I recall, SR was pissed off about the fitment on some of them. I’ve thought about this a lot and I think the extra 2 bills is worth it to get them straight from cattman. They have a much better rep IMHO. Just my .02
Old Jan 5, 2005 | 01:55 PM
chris'smax's Avatar
I agree about the fact that the cattman having a better rep, but the price difference is about $300 so my thinking is that i get cheap labor to do some welding and i may save at least $200 which can go towards something else. I'm just hoping i don't get one of the duds. I didn't even think of the o2 sims and also i am still not sure about the negative effects of disconnecting the EGR.
Old Jan 5, 2005 | 02:04 PM
2kGLE's Avatar
Yeah I hear you. I still dont understand why you want to weld o2 bungs on there. Wont you just get a CEL anyway since you will have absolute no cats in your car? Or are the o2s upstream of the precats? Cant remember sorry. At any rate, o2 simulators seem like the best way to go.
Old Jan 5, 2005 | 02:13 PM
chris'smax's Avatar
No i agree with using the o2 simulators. I just didn't even think about using them
Old Jan 5, 2005 | 03:23 PM
IceY2K1's Avatar
The front O2s are before any cats, so they'll be fine with headers. Rears with no precats or main cat will require O2-simulators to keep from throwing a CEL.
Old Jan 5, 2005 | 06:55 PM
chris'smax's Avatar
now here comes the re-occuring and very aggravating question "Does anyone have any soundclips of the hotshot headers?" . All of the links that i found did not work becuase they are old.
Chris
Old Jan 5, 2005 | 06:56 PM
chris'smax's Avatar
Thanks bro, you da man. BTW how do you know so much maximas?
Old Jan 5, 2005 | 08:59 PM
Broaner's Avatar
2060lbs and falling...
The definative EGR thread. http://forums.maxima.org/showthread.php?t=351657 All your answers are present and accounted for. Removing EGR isn't bad and doesn't seem to effect fuel mileage.
Old Jan 5, 2005 | 09:09 PM
chris'smax's Avatar
I read the thread but i didn't see a definitive answer on whether or not removing the EGR raised engine temp and if performance suffered during closed loop ecu operation
Old Jan 6, 2005 | 08:18 AM
Broaner's Avatar
Really? Hmmm...
Originally Posted by Nismo3112
So far with 180k on the motor:
Egr has been removed for about 6000 miles.
I get NO codes, I left the solenoid and temp sensor connected.
I did not feel any decrease in performance in the midrange. Still hauls like a ****.
Also, this was posted in the "Who's the lightest Max on the org??" thread:
Originally Posted by Aaron92SE
I've removed my EGR system. I don't want exhaust flowing back in my intake manifold! It heats it up and makes it dirty! I know it only opens at partial throttle to help emissions, but I got rid of that a long time ago. I don't have to worry about emissions.
later...
Trick the ECU? haha I have OBDI stuff! So I simply removed my EGR, fabbed up a block plate and installed it and sealed off my RH exhaust manifold tube. My gas mileage didn't change one bit!
and...
Originally Posted by Krismax
Nope cars was stilling pulling 30mpg + on the way to tilleys.With the egr out ,the cels are nonexistent but after i get the car back it will be fulley tricked and the mpg is from my super low weight .When im done with my car it will prob be around 35mpg
There you have it. EGR is there only for emissions on these cars. The fact that it will hurt fuel mileage is a myth. What it does to CC temps is only postulation at this point but it doesn't matter with an N/A car anyway.
Old Jan 6, 2005 | 08:30 AM
IceY2K1's Avatar
They sound good on VQ35s, however the Cattmans' are supposedly "euphoric" on VQ30s. Not sure on the SC's though. You should have StephenMax make you a clip, since he's about as close as you'll get. However, he has an Apexi or something exhaust too.
Chris
Old Jan 6, 2005 | 08:40 AM
Stephen Max's Avatar
I think the word used was "euphonic", but euphoric is not too far off, especially above 4000 rpm at WOT, heh heh.
Sorry, I don't have any way of making a sound clip at the moment.
My only complaint is that the headers greatly increased drone at 2500-3000 rpm, whereas drone was almost nonexistent with the stock headers. I recently put the cat back on in an attempt to reduce it, but that had very little effect.
Old Jan 6, 2005 | 08:43 AM
No postulation about it. That is it's sole purpose. But since it only operates at partial throttle it doesn't do anything to lower the much higher CC temps at WOT.
Old Jan 6, 2005 | 08:44 AM
IceY2K1's Avatar
Eh? I wasn't referencing you...another 5th gener who recently put them on.
Anyways, toss that Apexi for a Flowmaster or full Cattman catback. I've never heard an Apexi exhaust that didn't sound bad.
Old Jan 6, 2005 | 08:53 AM
I know. I thought he said euphonic, but maybe I misread.
Old Jan 6, 2005 | 08:56 AM
IceY2K1's Avatar
Are you saying you can read my PMs?
Here's his PM:
Originally Posted by frankieduxAE
I also have to resolder one of my extended o2 wires, one of the solders came off and now the SES light is on.
Other than that the car runs perfect. You must get the Cattman headers/exhaust, the sound is euphoric.
I LOVE driving my car now.
- Frank
Old Jan 6, 2005 | 10:09 AM
chris'smax's Avatar
Yeah well i am boosted so i kinda have to worry about that stuff.
And yes i saw all of those comments, but i thought i also saw arguments from people who had it disconnected that said it hurt performance
Old Jan 6, 2005 | 10:15 AM
chris'smax's Avatar
damn it, i am going insane here. I want to order these sons a b!tches today but i wan't to make the right choice .
Ice, you know what that $300 saved by buying the hotshot headers is going towards (ATP exhaust cuttout). THis thing is going to sound nucking futts at WOT
Old Jan 6, 2005 | 10:25 AM
Here's his PM:
He said the same thing in a 5th gen forum thread: http://forums.maxima.org/showthread....light=euphoric
Somehow I misread it as euphonic. I guess it made more sense to me that way, but I gotta agree with euphoric as well.
Old Jan 6, 2005 | 10:32 AM
IceY2K1's Avatar
Holy sh2t....good memory SM. I never read that thread, just his PM.
MaxLife17
Jun 27, 2019 01:37 PM
The Frye
Feb 3, 2019 08:34 AM
MaxLife17
Sep 8, 2015 02:36 PM
16_SR
Sep 7, 2015 06:47 AM
ef9
Sep 5, 2015 11:18 PM
