Sponsored by:
Sponsored by: CARiD
Yet another, 00VI question
Old Feb 18, 2005 | 12:46 PM
98I30t's Avatar
Well a couple, so humour me please. First, I'm an auto, so i relize I'm gonna have to shift manually to ever see the higher end of the VI. I have questions toward the RPM switches though. One being, if I get a summit switch, can this be "set" to keep open? Or is it a open/close universal setting? And since I'm a auto, when I switch gears, specially from first to second, my rpms' are gonna drop to somewhere around 4200-4400(not sure, cause I don't have the rev limit changed yet). If I get the Apex-i V-AFC II, I've read a couple members that this can be set to stay "on" on the v-tec setting, which the members are using to keep the VI open, would be worth it to keep it open, even at my lows of 4400RPM? Thanks for help in advance guys.
Old Feb 18, 2005 | 01:06 PM
Kevlo911's Avatar
Kevlo for President
Just get a Summit RPM switch, make it open at 4600. So WHENEVER the car hits 4600rpms, the VI will open.
Old Feb 18, 2005 | 01:10 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you could get a vafc 2 as well. you can chance the switchover and do some dyno tuning for a little extra power.
Old Feb 18, 2005 | 05:55 PM
DAVE Sz's Avatar
Hooooooonda.....
If you don't have an extended rev limit manually shifting won't get you anywhere. Am I right?
Old Feb 18, 2005 | 07:03 PM
Blu's Avatar
Blu
the tits
will the 00-01 Autos you will run quicker manually shifting. The dek's make power all the way to redline so its best to tach the car out to run the fastest. From my experiences riding in a friends car the 01 Autos shift at like 6k if you leave in in D/OD. So if done right the car will run faster manually shifting.
Old Feb 18, 2005 | 08:36 PM
Maximum96's Avatar
isnt 4600rpms a little too soon to open the VI??
Old Feb 18, 2005 | 08:43 PM
chuckie311's Avatar
no the are takling about the oovi not the mevi.. the oovi opens sooner . the mevi opens between 5200-5400 rpms for best results
Old Feb 19, 2005 | 06:23 AM
sloppymax's Avatar
i hope to be able to do some dyno testing with a vafc2 and see where my optimal switchover is. im auto so i will still have to manually shift even if i get the extended redline because of the tcm. but blu is right, the auto shifts at or just before 6 if left in d so to get everything out of it even stock, you have to manually shift it.
Old Feb 19, 2005 | 01:16 PM
DAVE Sz's Avatar
Hooooooonda.....
My auto never shifter before redline if I was WOT, never. What I was trying to say is that without an ECU you still can only go to redline anyway not 7200rpm like you would with an ECU upgrade.
Old Feb 20, 2005 | 01:36 PM
sloppymax's Avatar
correct. not sure on the 3.5 but every 2k/2k1 auto i have been in or driven has always shifted at 6k. i know there is some error to be accounted for so my basis is off reading of my ob2 software.
Old Feb 20, 2005 | 01:47 PM
chris'smax's Avatar
i run on average about 3 tenths faster at the track when manually shifting.
Old Feb 21, 2005 | 07:20 AM
upstatemax's Avatar
my 00 VI opens at 5200 rpms, the mevi opens earlier, i thought?
Old Feb 21, 2005 | 08:07 AM
sloppymax's Avatar
i thought most people running a mevi were running a harlan or summit switch close to 5000-5200. i have heard a few people opinion that it should be lower around 4600 but i hope to do some testing on my own just to confirm.
Old Feb 21, 2005 | 09:13 AM
krismax's Avatar
Father of the 00 VI
My 00 vi is open at idle
Old Feb 22, 2005 | 02:42 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You don't even have a power valve to be "open" probably.
Old Feb 22, 2005 | 03:09 PM
Kevlo911's Avatar
Kevlo for President
Mine is wired up to a switch, I can open whenever I want
Old Feb 22, 2005 | 03:34 PM
5spd99seL's Avatar
[QUOTE]my 00 VI opens at 5200 rpms, the mevi opens earlier, i thought?
The MEVI set to open before 5200-5400 is useless. There have been dynos posted and I have tried adjusting mine lower, resulting in a noticable drop in power. Just trying to save people some time.
Old Feb 22, 2005 | 03:40 PM
IceY2K1's Avatar
DEK = 4600rpm unless you have headers, then the stock 5000 is damn close.
MEVI = 5200+rpm
Old Feb 22, 2005 | 03:48 PM
Kevlo911's Avatar
Kevlo for President
Why 5000 if you have headers? Any dyno's, I wanna see
Old Feb 22, 2005 | 04:53 PM
sloppymax's Avatar
i would be interested too. that would save me getting the vafc since i already have headers and having the stock 5k switchover. if that is the case ill just pick up a used safc and tune with that.
Old Feb 22, 2005 | 11:03 PM
Maximum96's Avatar
what do the headers have to do with the switchover point?? dynos have shown 4600rpm for the 00 vi is the best switchover point and one said he ran his fastest track times with 4600 point. i have SR headers and a 01vi just waiting to dyno..
Old Feb 23, 2005 | 05:33 AM
sloppymax's Avatar
i think he was giving the optimal points for the switchover. if you dont have headers then it should be lower. i could be reading it wrong but thats what i got.
Old Feb 23, 2005 | 06:00 AM
deezo's Avatar
I don't feel that I would need to go to 7100 in first gear so I'm going to stick with the computer handle that shift at 6500 but I'll just switch to 3rd manually.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
