Sponsored by:
Sponsored by: CARiD
Making NA history March 11th
Old Mar 3, 2005 | 07:49 AM
plurco's Avatar
well it is my first attempt anyway. March 11th, with Ben's help, will be the first running of my stripped/all track 4th gen.
Here is a quick rundown of all mods.
ACT stage 1 or whatever they call it clutch.
Custon ram air intake with POP charger and oversived K&N filter.
Budget Y pipe.
Straight 3" exhaust dumping into axle compartment.
RVM UDP
Racing fuel cell (most likely won't be in by the 11th)
26" MT slicks.
EXTREME weight reduction.
I have several goals. My first is to be the first 4th gen in the 13's with stock ECU.
Second, to be the fastest NA 3.0 4th gen.
Last to be the fastest NA 4th gen.
Not trying to call anyone out, but competition breeds progress.
Old Mar 3, 2005 | 08:03 AM
mzmtg's Avatar
Minister of Silly Walks
Um...that mod list seems kinds long...
Old Mar 3, 2005 | 08:05 AM
plurco's Avatar
why did you steal my UDP?
Old Mar 3, 2005 | 08:26 AM
plurco's Avatar
Ben?...........
Old Mar 3, 2005 | 09:21 PM
krismax's Avatar
Father of the 00 VI
God i sure hope you dont get beat by maximas that are street driven and have full interior.
Old Mar 4, 2005 | 05:21 AM
plurco's Avatar
I don't think you have anything to worry about there. After Ben and I did the first round of weight reduction we took the car out and it was pretty nasty. I am looking for a high 13 the first time out to tell you the truth.
Old Mar 4, 2005 | 05:52 AM
stephenlc's Avatar
Why dont you post after you actually make "History"?
Old Mar 4, 2005 | 06:41 AM
Blu's Avatar
Blu
the tits
I think you should have waited until after March 11th to make this post. Also whats the actual weight, or have you even had it on the scales?
Old Mar 4, 2005 | 06:46 AM
mzmtg's Avatar
Originally Posted by plurco
Ben?...........
No I didnt take anything off the car except some more trim parts.
gtr_rider's Avatar
192.168.1.1
So let me ask you, why would you put a 3" exhaust on an NA?
Old Mar 4, 2005 | 07:12 AM
jmeister's Avatar
Wishful thinking maybe? Future plans?
Old Mar 4, 2005 | 07:31 AM
mzmtg's Avatar
http://www.turbofast.com.au/Drag.html
Old Mar 4, 2005 | 07:47 AM
Stephen Max's Avatar
Originally Posted by mzmtg
Cool. I'm in the low 12's.
Old Mar 4, 2005 | 08:04 AM
NismoMaxman2's Avatar
The only 4.5 gen in da 956
Thats it?, wow i wish you luck... No cams, no light flywheel, no ecu upgrade, 3inch exhaust?, maybe 2.5 would of been better, no high flow cat? well if you do it, I want to see a vid...
Old Mar 4, 2005 | 08:37 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You just jinx'd yourself...good luck getting low 14s now~!
Old Mar 4, 2005 | 09:31 AM
$tillenmax2k
Lightbulb
Seems like you're just relying on stripping the car to make it fast. 3" won't be helping, and it must be annoyingly loud. Do i smell a CRX/Maxima?
Have you weighed the car? What altitude/track will you be running at?
Old Mar 4, 2005 | 09:33 AM
plurco's Avatar
cause this forum was seeming kinda dead and I wanted to post something.
plurco's Avatar
Not yet. I am hoping to get it down to around 2500.
Old Mar 4, 2005 | 09:34 AM
plurco's Avatar
I do not subscribe to the "backpressure" theory.
Old Mar 4, 2005 | 09:35 AM
plurco's Avatar
Seems about right. 180ish hp 2500ish lbs.
Zack342's Avatar
good luck man
JClaw's Avatar
Don't drag the body in the trunk before it's killed... or something like that.
What's the point of racing with a family sedan unless it's for the sleeper kick? I suggest you follow the examples of krismax and japmax, where wild weight reduction and lots of power coexist with full interiors...
Old Mar 4, 2005 | 09:39 AM
plurco's Avatar
The car was totaled with very light frontend damage. It is just a toy now.
Old Mar 4, 2005 | 09:40 AM
plurco's Avatar
Originally Posted by NismoMaxman2
no high flow cat?
No cat at all, and after I measured this ss pipe I noticed it is only 2.75" It is only going to be 3' long or so.
Old Mar 4, 2005 | 09:46 AM
Jeff92se's Avatar
I'm needing a caw
Good. But a very short 3" exhaust will have no exhaust velocity. You might be able to get away with this if you ONLY run in a very high rpm range (where a 3" shortie exhaust "might" resonate) but I highly doubt it. I hope you don't bog anywhere on the launch or shifts.
I do wish you luck on the 11th. Let us know how it works out either way.
plurco's Avatar
yeah pretty much. that whole power to weight ratio thing
It is not a strret car, just a toy
that is an insult to Maximas everywhere
Not yet, running at liek 100' above sea level I think.
Old Mar 4, 2005 | 09:48 AM
plurco's Avatar
Thanks man, I hope I can get everything together by the 11th. I will be running slicks so I will be launching off the rev limiter, and power shifting.
Old Mar 4, 2005 | 10:00 AM
Nealoc187's Avatar
SLOW
I wish you luck with your runs. The other goals are definately up for grabs, but the one highlighted above has already been accomplished.
Old Mar 4, 2005 | 10:19 AM
plurco's Avatar
Really? by you?
Sorry, I thought you ran all your 13's with a JWT ECU.
I did not mean to misspeak.
Old Mar 4, 2005 | 12:10 PM
Nealoc187's Avatar
SLOW
My first 13 was with stock ecu. I ran a 13.999 on slicks. After that the season ended and the next spring I had ECU so I never ran with stock ECU again. It was barely a 13, I cut it as close as you can hehe.
Old Mar 4, 2005 | 12:17 PM
plurco's Avatar
well that is all I am hoping for. Do you have any idea your HP/weight at that time?
Old Mar 4, 2005 | 12:51 PM
emmas97's Avatar
my 13.87 was run on stock ecu....
Old Mar 4, 2005 | 12:54 PM
plurco's Avatar
with a 3.0? I just noticed I did not clarify that in my first post.
Old Mar 4, 2005 | 01:08 PM
Larrio's Avatar
The Definitive AE Master
Post
Wow, 4th gens just keep getting crazier all the time!
I believe the first goal is void, as it's been done before.
The second and third goals may be quite difficult, given your limited power mods. Possibly quickest 3.0 4th gen, but others with more power will most likely be faster.
Old Mar 4, 2005 | 01:14 PM
plurco's Avatar
Well I never said I was not going to add any more power mods. I have a set of heads that I am about to start working on, and I am also looking for a good deal on a 00VI. You are right about the one goal being void. I will alter that to "fastest 3.0 with stock ECU" As for others having more power, this is very true. The 3.5 has more potential. I am counting on the power to weight ratio being on my side. If someone comes along with a race trim 3.5 then so be it. As I said, competition breeds progress.
Old Mar 4, 2005 | 01:23 PM
Blu's Avatar
Blu
the tits
geez this is turning into the supra forums with all the record categories...
Old Mar 4, 2005 | 01:27 PM
plurco's Avatar
yeah well, I am just trying to make myself feel important.
Honestly when 3.5's started to show up in 4th gens it formed different categories. I don't want to be put up against them just yet.
Old Mar 4, 2005 | 01:29 PM
Nealoc187's Avatar
SLOW
Race weight was 2925. I dynod 183whp 170tq around that time but that dyno supposedly reads a bit low.
Old Mar 4, 2005 | 01:34 PM
emmas97's Avatar
13.87 w/ the hybrid motor
Old Mar 4, 2005 | 02:39 PM
krismax's Avatar
Father of the 00 VI
For you striping that max 2500lbs isnt light my car with pass seat out will weigh 2500's
If you dont beat neal it will be a nonevent. IMOP
