VIAS timing
VIAS timing
i figure someone has asked this before, but i cant find it anywhere.
is there any way to change the timing on the VIAS valve? i would like to see the difference if it were to open at 4000-4500 rather than 5000. i figure the only time i bring it over 4000 is when i need a bit of giddy-up. i would like to dyno tune this and see where it is best (which may end up being at 5000 anyway)
or if you wait a couple of weeks I will dyno test and finally release something that will perform the functions of a S-AFC and RPM switch as well as advance/retard ignition timing.
Originally Posted by 98SEBlackMax
You can cut the wire on the VI harness (the green and yellow wire, to the right of the harness if your facing the engine) and splice that into a RPM switch to control different opening and closing settings.
Exactlly. The RSM has a rpm activated switch. using that wire I can send a signal earlier.
