00-01 engine swap into a 4th gen ???
Exactly what i've been doing here:http://memimage.cardomain.net/member...777_5_full.jpg
(a 2k engine in my 98 max)
those are 2000 gas and cruise cables, original ones still could be used, but they looked bent too much to me... the other things are... like 2 rear ign. coils (cyl. 3 and 5) had to be grinded and now are retained in place by one screw only (each); pcv would not fit unless relocated; i reworked all the vacuum lines (for egr and all that stuff) because of the stupid extra hose in 2k cooling system...
So the mounts and everything are the same, did you use some of the 4th Gen components on the engine? or does it sit just a little different? I'm wondering why the ig coils would need to be shaved if they were already on the motor, and all the wiring harness and everything plugged right up?
Fakie J Farkerton
10-14-2015 06:25 PM
Finkle
09-27-2015 09:53 PM
ViciousVQ30
08-05-2015 05:40 PM
