Sponsored by:
Sponsored by: CARiD
Rebuild
Old May 20, 2005 | 12:30 PM
Sounbwoy's Avatar
Rebuild
I need some general info on rebuilding the VQ engine. I'm approaching 230,000 miles and I intend to keep the car and soon make it track-only...I don't want to go crazy b/c I want the car to meet SCCA guidelines for IT...so no wild cams or different intakes or stuff like that.
question is, do rebuilds confuse the computer? Can the block be bored to .40 over without things going crazy? In general, what kind of money has any of you paid to do a basic rebuild (honing, blueprinting) stuff like that?
Like I said, just looking for general info.
Old May 20, 2005 | 12:41 PM
Stephen Max's Avatar
I don't think a rebuild is going to have any affect on the ecu, unless you do things that affect cam and ignition timing.
With VQ30s being so cheap and plentiful, it is much more cost-effective to swap in a lower mileage used engine rather than rebuild your old one.
Old May 20, 2005 | 12:48 PM
Jeff92se's Avatar
I'm needing a caw
A rebuild to factory or close to factory specs will not confuse the ecu
The block cannot be bored as uses an aluminum block with steel sleeves. You can get thinner sleeves that will increase the bore. But not by 0.40. That's a pretty big change.
Your best best as stated, is to find a low miler used engine and swap.
Old May 20, 2005 | 01:35 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You can also swap in a VQ35 lower which would put your CR around 11.5:1. The added displacement and CR would really be perfect for a track only car with a JWT advanced ECU.
Old May 21, 2005 | 05:45 AM
Sounbwoy's Avatar
Thanks for the info. Can you give me an estimate of cost of VQ's and what would you consider "low" mileage on these engines?
The 3.5 swap is intriguing but would make my car illegal for the class I'd put it in...Thanks tho...
BTW-"IT" as I refer to in the original post means "Improved Touring"..a regional only SCCA road race class...I used to race a 1985 Honda CRX in that class...
Old May 21, 2005 | 06:38 AM
Nealoc187's Avatar
SLOW
Like $300-400... www.car-part.com is your friend.
I'm confused as to what the rules say that would allow you to have larger displacement by way of block boring, aftermarket pistons, etc, but wouldn't just allow the usage of a 3.5L untouched block? Is it just a cap on the displacement or something else?
And jeff I think he meant .040" not .40" hehe. Doesn't the VQ have ductile iron sleeves?
Old May 21, 2005 | 10:53 AM
Sounbwoy's Avatar
[QUOTE=Nealoc187]Like $300-400... www.car-part.com is your friend.
IN SCCA IT, the original engine type that the car was produced with must be used. Even tho the 3.5 is a VQ designation (right??), it's a different engine size with more HP and would not be allowed. There is some flexibility in backdating stuff, (such as if you were running a base Maxima but wanted to use the limited slip from a higher line model, that would be allowed, or using the larger tire size from a 5th Gen on a 4th Gen), but the 4th Gen models are so similar in all ranges, that you wouldn't gain anything by switching parts from one 4th Gen to another.
There are enough differences between the car and the engine that would make a 3.5 swap a NO-NO in SCCA. In NASA tho, a 3.5 swap probably could be done with no issue. That's where the Hybrid Hondas are running.
Old May 21, 2005 | 07:26 PM
subs1000w's Avatar
how would they even know oyu were using a 3.5 block since its visibly the same as a 3.0
Old May 21, 2005 | 08:21 PM
JClaw's Avatar
Yeah. If you put 3.0 valve covers with the "Nissan V6 3000" cover and say, a 00 VI, they will think you are running a VQ30 with a 00 VI, while everyone scratches their heads.
Old May 23, 2005 | 08:10 PM
Sounbwoy's Avatar
It's a risk thing. One could get away with it. You'd have to know how to cheat. In other words, if I raced that swap, then I go out and whup EVERYONE and do things like walk a BMW 325IS down the back straight, that would raise some eyebrows, then I could get protested, just like at an autocross. I'd then have to prove that the swap is legal, AND depending on the region, they might even tear down the engine to make sure, and I'd have to pay to tear it down, and they AIN'T putting it back together. It's not worth it to me. Besides, SCCA is amateur racing. No prize $$$ involved.
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Pied
Sep 26, 2015 03:29 PM
