Sponsored by:
Sponsored by: CARiD
Is there a height difference between DE and DE-K lower IM?
Old May 6, 2005 | 06:21 AM
Stephen Max's Avatar
I know the VQ35 Lower Intake Manifold is substantially taller than the DE LIM, does anybody know if the DE-K LIM is, too?
Old May 6, 2005 | 07:56 AM
DandyMax's Avatar
3.5 in the works
I was wondering the same thing too. For example, if installing a 5th gen upper with a 4th gen lower causes interferences with the coil pack bosses and PCV valve etc, - is that because the 4th gen LIM is shorter? Or is it also related to the 5th gen UIM and rear valve cover design, not just the lower?
I'd think someone who has both LIM's in their possession would have to measure them (off the car) in order to provide a definitive answer. But I'm curious to know this as well.
Old May 6, 2005 | 08:02 AM
Ironically, I have both in my possession, but the DE-K LIM is on my wife's car and I can't get a good measurement that way.
Old May 6, 2005 | 08:45 AM
DandyMax's Avatar
3.5 in the works
Hehe. Well you might just have to convince her to make alternate transportation arrangements for a day or two.
Old May 9, 2005 | 05:41 AM
krismax's Avatar
Father of the 00 VI
i used the 00 dek lower and on my 96 coil packs cleared perfect just like if i used my stock upper.
Old May 9, 2005 | 06:07 AM
Thanks, Krismax.
I was able to measure the height of the DE-K lower IM on my wife's car this weekend. It was a bit difficult to get a good view of the scale, but it looked to be the same height as the DE lower IM.
Old May 9, 2005 | 10:37 AM
Larrio's Avatar
The Definitive AE Master
does your de-k lower intake manifold have a swirl valve actuater?
Old May 9, 2005 | 10:54 AM
MAXimumHP's Avatar
I have both and they are out of the car. I'm pretty sure they are the same, but can measure them tonight if needed.
Old May 9, 2005 | 10:55 AM
I am not sure. I didn't look close enough. It is a 2000 Fed spec.
Old May 9, 2005 | 11:04 AM
nismology's Avatar
Then it doesn't. The 2000 Cali-spec and all 2001's have the swirl valves.
Old May 9, 2005 | 11:30 AM
Larrio's Avatar
so do the 99 cali spec 4th gens
Old May 9, 2005 | 11:33 AM
krismax's Avatar
Father of the 00 VI
yes mine HAD that stuff.
Old May 9, 2005 | 12:20 PM
Kevlo911's Avatar
Kevlo for President
Mine also cleared the coil pack w/o any problems. I do not have the swirl valves.
Old May 9, 2005 | 12:59 PM
SDot82's Avatar
Mines didn't clear the coil pack (had to do some grinding) and took off the swirl valves.
Old May 9, 2005 | 01:50 PM
Kevlo911's Avatar
Kevlo for President
Maybe it is a Mitsu/Hashin coil difference.
Old May 23, 2005 | 07:42 AM
DandyMax's Avatar
3.5 in the works
Mind doesn't clear either (2000 fed spec LIM)... maybe it is the coils but then the valve covers have to be different because it's hitting the bosses themselves. I haven't checked the part #'s to see.
Old May 23, 2005 | 07:56 AM
Kevlo911's Avatar
Kevlo for President
Hmm this is interesting. How come mine, Chris's, and Joe's clear but some of yours do not?
Old May 23, 2005 | 08:26 AM
Mine didn't clear either, and neither did Slamd98SE's.
Old May 23, 2005 | 08:47 AM
DandyMax's Avatar
3.5 in the works
Also, I compared the 4th gen and 5th gen LIM's when I had them off the car this weekend... just took some basic measurements but I believe they're the same height (concurs with what others have observed).
Old May 23, 2005 | 09:57 PM
maxS
got 00vi lim/up and it did not clear 2 rear coils (#3 and #5 cyl)
imported_Nismo_max
Feb 17, 2016 03:39 AM
Starrider
Dec 18, 2015 04:43 AM
Turbonut
46
Oct 21, 2015 08:28 PM
beerman1378
Sep 8, 2015 02:19 PM
