Sponsored by:
Sponsored by: CARiD
Can any of these codes be NA power robbing?
Old Jun 21, 2005 | 04:37 PM
plurco's Avatar
I checked my codes and at first I got.
1. ignition signal circuit 0201
2. fuel tank temp sensor 0402
3. rear 02 0707
4. vac. cut balve bypass valve 0801
5. evap canister purge valve 0807
6. evap canister vent valve 0903
7. fuel pump control module 1305
I cleared the codes and let the car idle a while, and I rechecked. I got these.
1. fuel tank temp sensor
2. vac. cut balve bypass valve
3. evap canister vent valve
The only one I think may rob a little power it vac. valve. Any thoughts?
Old Jun 21, 2005 | 05:58 PM
jmeister's Avatar
What happened to throw all those at once?
The fuel related ones are rather strange...
Old Jun 21, 2005 | 06:30 PM
plurco's Avatar
Well the car has been liberated of nearly everything not needed to run down the track.
Old Jun 22, 2005 | 12:13 PM
plurco's Avatar
so does nobody have any ideas about these?
Old Jun 22, 2005 | 12:15 PM
plurco's Avatar
also what purpose does the evap system serve?
Old Jun 22, 2005 | 01:54 PM
DandyMax's Avatar
3.5 in the works
Evap recirculates fuel vapor from the tank and sucks it into the engine.. not sure if the ECU adjusts a/f slightly to allow for this or not..
Old Jun 24, 2005 | 08:22 AM
GodFather's Avatar
Made in Taiwan
you've removed your electronic EVAP assmebly to cause all that. I personally think it doesn't do any power robbing at all. I have a 95, running a canister EVAP. bought a 96 JWT ECU, which runs a electronic EVAP. I have the same codes you have, and the car still runs "JWT" strong...
Old Jun 24, 2005 | 08:51 AM
Dubbya's Avatar
VK56 Inside
I think EVAP problems just give worse gas mileage.
Old Jun 25, 2005 | 12:48 PM
liqidvenom's Avatar
brotherhood of tq
i have the fuel temp one also since i cut the wire by mistake when i cut the one for the bens ecu mod. if anything my car felt better driving since i had it cut and thats y i never went back to fix it. weird huh
shilov
Feb 19, 2024 09:40 PM
jchronis2552
Sep 21, 2015 05:52 AM
Bluenissan
Sep 20, 2015 08:54 PM
Steven Orozco
Sep 12, 2015 10:41 PM
AT978
Sep 6, 2015 10:31 PM
