Sponsored by:
Sponsored by: CARiD
Can we Adapt a 350z Intake Manifold to a VQ30DE
Old Jul 1, 2005 | 12:00 PM
SpeedCrazie's Avatar
I know many are going to say just use a 00-01 VI or a MEVI. However I don't really care for either I really want to adapt this intake manifold not only for the coolness factor but the gains, I guess gains range from about 12hp N/A and about 30-40hp with F/I.
Kinetix
If hood Clearance is the only issue I really don't care as that can be easily taken care of.
Thanks Guys!
Best Regards,
JP
Old Jul 1, 2005 | 12:15 PM
Stephen Max's Avatar
If that's what you want to do, go ahead and lead the way.
Old Jul 1, 2005 | 12:38 PM
Tatanko's Avatar
Bacon Lover
Yes, please try. BTW, your link doesn't work, nor does copying and pasting the URL.
Old Jul 1, 2005 | 12:39 PM
JClaw's Avatar
Hood clearance is only an issue with the STOCK 350z/G35 intake manifold. Kinetix and Crawford's plenums are smaller and more compact, and according to both of them, fit under the hood of 02+ Altimas, so it should fit in a VQ35-powered 4th gen.
Old Jul 1, 2005 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
http://www.forums.maxima.org/showthr...0824&highlight
http://www.nissanclub.com/forums/sho...d.php?t=193864
Old Jul 1, 2005 | 03:52 PM
krismax's Avatar
Father of the 00 VI
it will bolt on with the 350z lower and actually bolt to the 3.0 heads but it will not line up to the heads right .
thatsb the IM i have in mind for my car or maybe the other one the other companys gonna produce that will be pure NA IM.
Old Jul 1, 2005 | 11:29 PM
vipervadim's Avatar
I like Maximas
interesting
http://www.kinetixracing.com/index.a...ProdID=12&HS=1
Old Jul 2, 2005 | 12:52 AM
krismax's Avatar
Father of the 00 VI
You would also have to have your intake pointing toward the pass headlight and youll have to either get a 3.5 TB or pathy TB and make a adapter plate for it.
Old Jul 2, 2005 | 10:02 AM
Are you talking about the piece for the throttle body pointing towards the passanger headlight? If so thats okay because my chage pipe goes that way anyways.
Hmm...Couldn't I just make an adpater plate for our Stock Throttle body?
Also you said it would bolt to the heads but would not line up correctly anyway to remedy this?
Thanks Guys, I appreciate the help.
JP
Old Jul 2, 2005 | 03:26 PM
krismax's Avatar
Father of the 00 VI
JP
maybe you could widen the 3.0 to 3.5 head specs. I wouldnt try.
And with the TB if your gonna use the smaller 3.0 TB i wouldnt even bother with the intak manifold because why choke it with a TB but pay good money for it.
Old Jul 2, 2005 | 03:47 PM
japmaxSE's Avatar
Go Get a Life!
Damn you guys are right on the button with this one I already know...
Old Jul 2, 2005 | 03:50 PM
japmaxSE's Avatar
Go Get a Life!
Why not..?
Old Jul 2, 2005 | 04:04 PM
krismax's Avatar
Father of the 00 VI
Originally Posted by japmaxSE
Why not..?
because some of that head area is cast thin and for that trouble with that nice manifold i would just use 3.5 heads which i have
Old Jul 2, 2005 | 04:52 PM
Krismax,
I understand what you are saying and I am curious if I can retain the VQ30 Bottom End and adapt the VQ35 Head.....ahhh....what to do....
Old Jul 5, 2005 | 04:56 AM
Originally Posted by vipervadim
There have been some before and after dynos presented in my350z.com which show no gains after installing this IM. Looks pretty, though.
Old Jul 5, 2005 | 08:56 AM
NmexMAX's Avatar
dot dot dot ...
Expensive shiny piece of crap then ... It looks like ours w/o the dual chamber stuff.
Old Jul 5, 2005 | 09:16 AM
JClaw's Avatar
Why can't somebody just design a good IM for us? It's not hard, just produce a FWD version of the 350z IM that fits under our hoods. They'd sell like crazy. Altimas, 5th and 6th gen maximas and 4.5 gens would be all over it. They'd make tons of dough.
Old Jul 5, 2005 | 09:55 AM
Nismo3112's Avatar
Custom User Title
^^ I'd get one.
Old Jul 5, 2005 | 10:00 AM
NmexMAX's Avatar
dot dot dot ...
Work in progress
Even if the Kinetix showed no gain on the 350z, it might show a gain on the 02+ Maxima/Alt etc.. But what do I know .. exactly nothing.
Old Jul 5, 2005 | 02:39 PM
JClaw's Avatar
A stock 350z intake manifold has a muuuuuch better powerband that our IM. It's basically like comparing a 95-99 3.0 manifold to the 00-01 VI. Night and day.
Old Jul 5, 2005 | 02:47 PM
nismology's Avatar
The 350Z intake manifold is an engineering marvel. I don't see how ANY aftermarket company could significantly improve on it. 105% volumetric efficiency at 5600 RPM will be EXTREMELY tough to beat.
Old Jul 5, 2005 | 02:56 PM
JClaw's Avatar
They don't need to beat it, they need to match its power and make it suitable for FWD applications. The gains would be significant. SR20DEN's Secret Sauce Intake manifold already gives big gains over the original IM, and I doubt his modded IM is better than the stock 350z IM.
Old Jul 5, 2005 | 03:19 PM
nismology's Avatar
Very true. I agree. I was just saying that in response to aftermarket companies trying to improve on it, that's all.
With all this said, i think SR20's manifold should go into regular production...
Old Jul 5, 2005 | 03:21 PM
krismax's Avatar
Father of the 00 VI
once a pure NA IM comes out for FWD or RWD its gonna be mine but a prob with useing 350z IM is you need the 350z lower also that holds the injectors because its not the same as the 3.5 FWD lowers.
Old Jul 5, 2005 | 03:24 PM
JClaw's Avatar
I wouldn't mind buying a 350z lower intake manifold.
Old Jul 5, 2005 | 03:28 PM
krismax's Avatar
Father of the 00 VI
I think there $220 new without rails or injectors but thell swap over from maxima
Old Jul 5, 2005 | 03:33 PM
krismax's Avatar
Father of the 00 VI
And just to let everyone know you will need a powerbulge in your hood a couple inches and it will be offset on the hood
Old Jul 5, 2005 | 03:35 PM
NmexMAX's Avatar
dot dot dot ...
This is referring to the 4th gen or 5.5g? Or both? Or do you know if it's the same for the 5.5g?
Old Jul 5, 2005 | 03:41 PM
krismax's Avatar
Father of the 00 VI
this is from pics ive seen of one tried on a 5.5 gen max . i would say that for 4th gen its not known 100% but i would bet its the same ,TB neck is the main prob.
Old Jul 5, 2005 | 03:47 PM
JClaw's Avatar
Yes, but the kinetix/Crawford manifold is considerably smaller than the original z IM.
Old Jul 5, 2005 | 03:52 PM
NmexMAX's Avatar
dot dot dot ...
Smaller footprint, but what about height?
Old Jul 5, 2005 | 06:27 PM
SR20DEN's Avatar
VQ Wizard
I am too chicken to put it in regular production and it's more difficult for me to get them done now since I don't work at an auto shop anymore.
However, I have some ideas to make it even better to the point that everyone would want one over anything else. If I can find a way to pull it off I'll open the flood gates.
Old Jul 5, 2005 | 06:34 PM
JClaw's Avatar
Whenever you're ready, we got the cash in hand, tons of us.
Old Jul 5, 2005 | 06:53 PM
SR20DEN's Avatar
VQ Wizard
Well the one I have now is easy to copy (for those who have the right equipment) and that is what scares me. However the one I want to sell would be too complicated for anyone else to consider, and It would make the car go down the track even faster.
Old Jul 5, 2005 | 06:57 PM
JClaw's Avatar
How much were you thinking of selling them (roughly)? If your price is fair AND the thing is complex no one will want to go through the trouble of copying them.
The aftermarket 350z IM's cost like 1g's. It would be funny if the Z/G guys ended up being jaleous of your FWD manifold
Old Jul 5, 2005 | 09:33 PM
NmexMAX's Avatar
dot dot dot ...
Most Z guys just have too much money and spend it on the latest product, little of them actual do tinkering/engineering on their own to improve a product. That's what makes the small Maxima community that does this unique..IMO.
I'd like to see what the Gen II SSIM is all about too. .
Old Jul 5, 2005 | 10:14 PM
steven88's Avatar
Need A Light?
Hmmm...I wonder how a Vq35 powered 4th gen with a secret sauce GenII would perform? and some tomei cams w/cattman headers and 7500 rev limiter
Old Jul 5, 2005 | 10:28 PM
NmexMAX's Avatar
dot dot dot ...
Who makes the 272 cams .
And don't forget the rod bolts.
Only time will tell.
But for now, we can just work with what we have.
Old Jul 6, 2005 | 05:56 PM
krismax's Avatar
Father of the 00 VI
Give me one and ill test it on the dyno with my 00 vi ,ill prob dyno in 3 weeks. And ill respect all secrets .
Old Jul 8, 2005 | 08:41 AM
aznsap's Avatar
i'd be willing to wait for an sr20 IM
i guess i'll just sit back and hope =)
