Sponsored by:
Sponsored by: CARiD
Can we Adapt a 350z Intake Manifold to a VQ30DE
Old Jul 8, 2005 | 10:36 AM
  #41
SR20DEN's Avatar
VQ Wizard
And I want everyone to have one so we can make more Honda owners respect our AutoritI.
Old Jul 8, 2005 | 07:51 PM
  #42
JClaw's Avatar
Most of 'em already have trouble following our untuned/stock IM 4.5 gens...
Paradoxally, the 15-second Honda owners seem to be the most arrogant ones, doing huge overkill burnouts on their way to a 2.434 60 foot and 3 revlimiter-bouncing shifts. I've talked to a few all motor and turbo 12 & 13 second Honda owners and they seem alot more mature than the average I/E Si with a fartcan...
Old Jul 19, 2005 | 09:32 AM
  #43
maxmale's Avatar
do you think the kinetix would be pretty much a direct bolt on for the 04 max?
Old Jul 19, 2005 | 09:36 AM
  #44
NmexMAX's Avatar
dot dot dot ...
No.
If it was then it be "pretty much" a direct bolt on for any 02+ Maxima.
Old Jul 20, 2005 | 10:10 AM
  #45
maxmale's Avatar
where do you think the problems would be at.
Old Jul 20, 2005 | 10:59 AM
  #46
NmexMAX's Avatar
dot dot dot ...
Why don't you read through the fuggin post. And use links provided Don't be lazy
Old Jul 20, 2005 | 04:43 PM
  #47
Mr_Red's Avatar
Originally Posted by SR20DEN
I am too chicken to put it in regular production and it's more difficult for me to get them done now since I don't work at an auto shop anymore.
However, I have some ideas to make it even better to the point that everyone would want one over anything else. If I can find a way to pull it off I'll open the flood gates.
How complex are we talkin?
I own a manufacturing company - we do custom and OEM. send me what info you feel comfortable giving out and I'll see how feasable it would be for me to mfg for you.
Old Jul 27, 2005 | 11:50 AM
  #48
Hitmanforprez's Avatar
Sorry to hijack the thread
Would the 350z IM bolt right onto a 4th gen with a vq35 swap from a 2002 max?
Old Jul 27, 2005 | 12:06 PM
  #49
Stephen Max's Avatar
It would, because the intake bolts onto the lower intake manifold, which is the same for the Maxima and the 350Z VQ35s. Lack of hood clearance is the problem.
Old Jul 27, 2005 | 01:44 PM
  #50
DandyMax's Avatar
3.5 in the works
Exactly how much are we talking about? Anyone measured it?
Old Jul 27, 2005 | 05:01 PM
  #51
slimer's Avatar
A couple of Blaxxx's? Lawls.
whats wrong with making a Max LIM to Z UIM adapter plate. I know about the hood clearance, but wouldn't that take out some of the headache and increase VE?
Old Jul 27, 2005 | 05:10 PM
  #52
plurco's Avatar
I could care less about hood clearance. I can fix that. Is there any benifit for a VQ30 with the 350Z? I do not know how it would perform on a smaller engine.
Old Jul 27, 2005 | 06:06 PM
  #53
Plurco: How can you fix the hood clearance without making a gap around the edges?
Old Jul 27, 2005 | 06:53 PM
  #54
plurco's Avatar
by cutting out all the bracing in the hood. That will give me another 2" or so. My car is 100% race, so looks are not as big of an issue for me.
Old Jul 27, 2005 | 07:38 PM
  #55
Royal_T's Avatar
SR20DEN,
If you make it I'll be the first one to buy it off from you. SO get on the ball and see what you can do.
Old Jul 27, 2005 | 08:11 PM
  #56
krismax's Avatar
Father of the 00 VI
350z upper will not work on max 3.5 lower ,you need 350z lower also
Old Jul 27, 2005 | 08:20 PM
  #57
cloudy's Avatar
Ok didnt really bother to read anyones post after first couple ones, so if this has already been said, then sorry. But here it is,
For the Kinetix plenum you are talking about the new one from them, the SSV correct? Kinetix SSV is MUCH smaller then a crawford plenum. On the Z the kinetix fits under the stock strut bar, and IMO is crap. It gives horrible #s, some ppl did not even see a gain in it. In all honesty it is all show no power. Now the crawford is noticeable gains and power. It does not fit under the stock strut, which is why they sell the strut for it, which goes to the side of the intake manifold, instead of going over it. The crawford is much bigger and if a kinetix plenum will not even fit, the crawford will def not fit.
Old Jul 28, 2005 | 05:01 AM
  #58
Nissan FAST shows different part numbers for the LIM and the IM gasket, so I guess you're right. I stand corrected.
I wonder what the difference is, though. The intake ports in the heads are the same, maybe it is only a height difference.
Old Jul 28, 2005 | 07:33 AM
  #59
Here's a pic of a 350Z LIM. Anybody have one of an A34 LIM?
Old Jul 28, 2005 | 07:37 AM
  #60
SR20DEN's Avatar
VQ Wizard
Originally Posted by Royal_T
SR20DEN,
I am so busy with work(s) now that I can't even get the regular ones done on time. Hopefuly soon I'll be able to start on it.
Old Jul 28, 2005 | 07:39 AM
  #61
Royal_T's Avatar
PM me once you get them done, also keep us updated on it.
Edafe
Old Jul 28, 2005 | 07:50 AM
  #62
NmexMAX's Avatar
dot dot dot ...
Top is A34, bottom is A33(02+)
More pics
Old Jul 28, 2005 | 02:34 PM
  #63
krismax's Avatar
Father of the 00 VI
Originally Posted by NmexMAX
The ports do not line up when compared to FWD IM .. They're semi-zig zag(FWD), and the Z are in a striaght line.
Is that correct krismax? I've seen this on my350z, and altimas.net
And if there's a height difference, hoefully it's in our favor.
ok its the other way the 350z are zig zaged and the 02 max one i have is pretty much in a perfect straight line.And every other hole on the max one has a chamfer . these lowers are made for each upper.
Old Jul 28, 2005 | 02:56 PM
  #64
SR20DEN's Avatar
VQ Wizard
And the 350Z LIM is the better one of the bunch, especially if one were to make a compete custom upper.
Old Jul 29, 2005 | 04:45 AM
  #65
I know that I have repeated the concern about hood clearance problems with installing the 350Z intake manifold onto a Maxima VQ35 engine, but does anyone know this for a fact?
The reason I ask is that when the 5th gen Maxima arrived on the scene, people said exactly the same thing about installing the 00vi onto a 4th gen VQ30.
Old Jul 29, 2005 | 09:20 AM
  #66
steven88's Avatar
Need A Light?
didn't emax test fit the 350z IM onto his 2k2? and indeed found out that there was a hood clearance problem?
Old Jul 29, 2005 | 10:58 AM
  #67
NmexMAX's Avatar
dot dot dot ...
I don't think he ever bolted it up .. or used the z LIM ..
Old Jul 31, 2005 | 11:25 AM
  #68
Jar's Avatar
Jar
other than having to cut the hood or pound it up or whatever (only saying that as to remove the concern) is there any other issue with the 350z IM on the 3.5?
Old Aug 1, 2005 | 06:40 AM
  #69
The 350Z IM puts the throttle body in an awkward place.
Old Aug 1, 2005 | 02:01 PM
  #70
aznsap's Avatar
that's what i guessed too since the engine orientation is different. i wonder if there's a way around that so we can modify them somehow to fit our cars better.
Old Aug 1, 2005 | 05:53 PM
  #71
plurco's Avatar
It would not be that bad.
Old Aug 1, 2005 | 06:17 PM
  #72
Jar's Avatar
Jar
I wonder if it would crimp the throttle cables too bad??
Old Aug 1, 2005 | 08:53 PM
  #73
Nismo3112's Avatar
Custom User Title
I would cut the curve off and weld on a plate to adapt a throttle body onto it.
Old Aug 1, 2005 | 09:22 PM
  #74
aznsap's Avatar
actually that curve wouldn't be too bad... you could run an intake down to in front of transmission if the underbody panel is removed
Old Aug 1, 2005 | 10:28 PM
  #75
Jar's Avatar
Jar
from the above pic it almost looks like it would be better to have an adapter to exten forward and just a bit to the drivers side, wouldnt be that far away from the stock position, anyone else see that?
Old Jan 15, 2007 | 10:39 AM
  #76
xraver_px's Avatar
More pics
i have a 2k2 maxima, i was comparing the 350z lim(top pic) to the A33 02+ manifold(bottom pic*what NmexMAX posted*) i think they will line up but im not sure if the two bolts on the corners of a A33 manifold will line up if installing 350z lower plenum unless u need the 350z lim to install the lower plenum. i have been researching but some information is missing
Old Jan 15, 2007 | 10:46 AM
  #77
Kevlo911's Avatar
Kevlo for President
This has already been done please search instead of bumpin old threads
Old Jan 15, 2007 | 11:11 AM
  #78
Nismo3112's Avatar
Custom User Title
Been there done that. You need the Z33 LIM if you want to install a Z33 plenum.
Old Jan 15, 2007 | 11:33 AM
  #79
VQ'ed's Avatar
Why don't you guys go full upper sheet metal with velocity stacks, vacuum adapted with adapter plate with nipples, lower IM with the upper flange trimmed and retrofitted to the upper sheet metal. A bit like individual throttle bodies with the oem upper and lower manifold flanges??
A bit of fab but you guys over the states have done a lot of R&D.
My idea...
Old Jan 15, 2007 | 12:35 PM
  #80
TDotMax's Avatar
Took me 2 seconds using free search
http://forums.maxima.org/showthread.php?t=460317
