Sponsored by:
Sponsored by: CARiD
questions about using 00VI upper with the 4th gen lower
Old Jul 19, 2005 | 03:31 PM
maximazation's Avatar
I am going to be using the 00VI upper plenum and using it with the 4th gen lower plenum, I have drilled the hole on the upper plenum so the screws on the outer will go through, yet with the 4th gen gasket (which is quite thick), it only leaves a few threads for the bolt, what can I do about that?
Also with the long 8mm bolts that go into the lower plenum, the brass sleeves on the 00VI upper plenum are too small to fit an 8mm bolt, what did some of you guys do to accomidate the 8mm bolt?
Old Jul 19, 2005 | 03:45 PM
Kevlo911's Avatar
Kevlo for President
Use 00gasket.....
Old Jul 19, 2005 | 11:19 PM
eckohb's Avatar
enlarge the two holes that line up with the 4th gen lower so you can use 8mm bolts, or install keenserts/helicoils
Old Jul 19, 2005 | 11:34 PM
Originally Posted by Kevlo911
Use 00gasket.....
is the 00 gasket the one that goes around the ports on the manifold? if it is, it seems somewhat thin and looks like it will leak.
Old Jul 19, 2005 | 11:35 PM
enlarge as in enlarging the brass sleeve?
Old Jul 20, 2005 | 05:56 AM
Stephen Max's Avatar
If you want to use the 8 mm holes in the LIM, then you have to enlarge the brass sleeves in the upper IM.
Conversely, if you want to use the oem 5th gen 6 mm bolts you will have to install inserts (e.g. Helicoils, Keenserts, Timeserts, etc.) to bring the hole diameter down.
I prefer doing the latter.
Old Jul 20, 2005 | 03:54 PM
Where can I purchase these inserts, all hardware stores around my area discontinued sale of helicoils and they only thing they sell now are tap & die sets, which i already have
Old Aug 19, 2005 | 10:47 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
this is a dumb question but iicc if you use the 4th gen LIM you can use the sidefeed injectors still.
Old Aug 19, 2005 | 10:57 AM
That's right.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
