Sponsored by:
Sponsored by: CARiD
00VI running lean and aftermarket ECUs
Old Jul 21, 2005 | 08:07 PM
THT's Avatar
THT
Throbbing member
I have the 00VI and a Technosquare ECU. At WOT, the car is supposed to default to preset a/f maps, right? If that's the case, why am I running rich at WOT? I haven't put the car on a dyno to confirm it's running rich but I have to indicators:
1) The car does not pull as hard as when I'm at close to WOT
2) I can smell it
Any thoughts?
Old Jul 22, 2005 | 06:29 AM
Stephen Max's Avatar
So... it's running rich and not lean, like your subject says?
Did TS do anything to your fuel maps?
Old Jul 22, 2005 | 07:03 AM
DandyMax's Avatar
3.5 in the works
Might be a stupid question as I don't remember what your setup is... but did you keep stock injectors or go to DEK injectors? They're larger...
Old Jul 22, 2005 | 08:48 AM
aznsap's Avatar
i think w/ dek injectors you'll tend to run rich @ wot unless you tune.
Old Jul 22, 2005 | 08:52 AM
DandyMax's Avatar
3.5 in the works
That's what I was implying of course.. But he may not have used DEK injectors in which case it'd be something else
Old Jul 22, 2005 | 11:01 AM
s0ber's Avatar
I believe im running rich at WOT as well, used the larger injectors, no tuning at all but stock ECU.
Old Jul 22, 2005 | 12:00 PM
DandyMax's Avatar
3.5 in the works
Then you definitely are, as am I. Check eckohb's recent dyno out in the dyno forum.. he was around 11:1 a/f under WOT.
Old Jul 22, 2005 | 02:23 PM
s0ber's Avatar
Im hitting up the dyno on the 30th to get my untuned baseline run in, I actually HOPE my AFR is rich, just so I can get more power out of it when I tune it when I recieve my VAFCII
Old Jul 22, 2005 | 03:41 PM
THT's Avatar
THT
Throbbing member
Stock injectors and the TS a/f maps are supposed to be leaner than what was originally programmed.
Old Jul 24, 2005 | 07:44 AM
eckohb's Avatar
I was even dipping under 10 at some points on the dyno. Get it tuned, and you will be fine. Get the SAFC-II or VAFC-II, whatever suits you best. Then go to Speedquest in Waukegan, IL. My baseline was 160 whp/ 165 wtq, and we left at 174 whp/ 186 wtq, SAE corrected that is. It will definitely be worth your while.
Old Jul 24, 2005 | 09:21 AM
THT's Avatar
THT
Throbbing member
I'm a dumbass...the title should read "running rich"
Old Jul 27, 2005 | 05:07 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
davi-did you talk to joe? he used to own a max.
ty-if you need help wiring, i have done the safc, twice.
Old Jul 27, 2005 | 05:15 PM
THT's Avatar
THT
Throbbing member
Thanks, Steve. I will wait for word of the GReddy eManage Ultimate unit. If it can really control ignition advance and the rev limiter, I'll pick that up.
Old Jul 27, 2005 | 06:21 PM
slimer's Avatar
ditto for me.
Old Jul 27, 2005 | 08:42 PM
s0ber's Avatar
control timing and REV limiter??? oOooOoOo im interested.
Old Jul 27, 2005 | 09:21 PM
eckohb's Avatar
yeah, we talked to joe. his max got stolen. he said he is looking for an altima now. they gave me a pretty good deal on the dyno tuning. 175 for a little over 2 hours, and he re-did the wiring. Not bad for the gains i got from it. Now if only i could fix my fockin brake problem
MAXSE5SPD
Sep 17, 2022 04:00 AM
t6378tp
Sep 29, 2018 04:27 PM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
