Sponsored by:
Sponsored by: CARiD
SAFC-II benifical being N/A??
Old Aug 2, 2005 | 06:33 AM
sean05's Avatar
idk if this is a stupid question or not, but would the SAFC be benifical being N/A? I have a MEVI comming and a Apexi WS exhaust. I know the exhaust isnt worth much if anything on the dyno, but i would like to get the MEVI tuned. Wold i be able to do this with the safc? Im also looking for an ecu. Does the emanage with 4th gens? Ive searched around but couldnt find anything.
Old Aug 2, 2005 | 06:42 AM
s0ber's Avatar
im sure theres always some room for tuning, even NA...
Only way to know for sure is to get on the dyno and check out your stats :d
Old Aug 2, 2005 | 06:45 AM
sean05's Avatar
ya i want to get to a dyno but i need to find one around here. Can you tell me the difference in the SAFC and the VAFC?
Old Aug 2, 2005 | 06:56 AM
SDot82's Avatar
They do the same thing except the VAFC can control when a VETC engages or can activate our VI's.
Old Aug 2, 2005 | 06:59 AM
sean05's Avatar
so the VAFC would be more benefictial for me. Does anyone know what the SMT6 does? http://www.perfectpower.com/products/smt6.asp i saw it posted in another thread but wasnt much details on it.
Old Aug 2, 2005 | 07:09 AM
SDot82's Avatar
Can fine tune your A/F ration better plus adjust your timing as well. There are other features but don't know if they work on our cars.
aznsap's Avatar
ya i would get teh VAFC if i were you to control the opening of the mevi.
the SMT6 i think is a more hardcore version of an AFC. i think in addition to air/fuel ratio it can make adjustments to the timing.
Old Aug 2, 2005 | 07:30 AM
sean05's Avatar
i was reading the apexi site but they dont do much explaining.
Originally Posted by From Apexi's Site
The highly anticipated release of the new A'PEX VAFC II marks a new revolution in piggy-back style fuel controllers. Building upon the world wide success of the previous VAFC, the new VAFC II has taken the proven technology of the last VAFC to the next level. For optimal fuel control, the VAFC now allows for 12 point fuel manipulation in 100 RPM increments. The VAFC II also allows for the VTEC engagement point to be manipulated from 3000-7000 RPM, including the new i-VTEC systems. The redesigned case features a center push button with a rotating outer switch for easy and precise data input. To protect data maps from being tampered with, the new VAFC II features a password protection system.
Like the Super AFC II, the VAFC II displays data in three different modes: Numerical, analog, and graph. Numerical mode allows the user to monitor up to four different values in numerical format and also shows peak hold values on demand. The analog mode displays up to two values in an easy to read meter style display. Peak hold is included in analog mode as well. The graph mode offers real time graph plotting with a built in ghost map trace feature. The graph can relay movement up to 60 seconds.
New Features Include:
- New case design with center push button and rotating outer switch
- VTEC engagement control from 3000-7000 RPM in 100 RPM increments
- 12 point fuel control for LOW and HIGH VTEC maps (total of 24 points)
- i-VTEC compliant
- Monitor i-VTEC VVT movement in real time
- Password protection
- Red LED light indicated cam switchover point
- EEPROM chip for maximum data storage
- VTEC Match/Unmatch correction for smooth VTEM engagement modification
- Versatile mounting bracket
Old Aug 2, 2005 | 07:33 AM
NmexMAX's Avatar
dot dot dot ...
What more explaining do you need?
Old Aug 2, 2005 | 08:39 AM
sean05's Avatar
i dont understand what any of that means. oh well
Which one would be more benefictial with the mevi? i have a summit racing switch so i really dont need it to engage the vi for me.
Old Aug 2, 2005 | 08:44 AM
NmexMAX's Avatar
dot dot dot ...
Cliff notes...
VAFC does everything the SACF does, but with the option of controlling VTEC, or in your case, MEVI activation point.
The VAFC can control in increments of 100 rpms, more precise than SAFC's 200 rpm increments, but they both only offer a 12 point map .. so ... even with 200 increments, you will have to skip some rpms and are not able to take advantage of the 100 rpm increments if tuning to fuel cut.
Get the cheaper one .. not sure on price difference of the 2. Since you're going MEVI, an extended rev limiter is a must, so get the JWT first, and then dyno and see where your A/F is.
Although JWT does tune it(a/f), it's crude, and not vehicle specific ... but still better than stock.
Old Aug 2, 2005 | 08:49 AM
sean05's Avatar
thanks. Im trying to find an ecu but just no luck. Ill keep scanning the classified. So i defiently need the extended rev limiter. Would you recommend the JWT or TS?
Old Aug 2, 2005 | 09:01 AM
NmexMAX's Avatar
dot dot dot ...
W/a MEVI, you really need the extended rev limit. I have JWT, and I know it works etc, but they have both been proven, so it's up to you. I waited 7 weeks for mine, and paid ~700 w/core ECU and reporgram + shipping ... w/TS there's not so long of a wait, but not sure if they've cracked the rev limit code on all ECU's.
Check www.car-part.com for some cheap ECU's to send in for a core.
Old Aug 2, 2005 | 09:07 AM
sean05's Avatar
by core you mean just one that you can send why yours get reprogrammed?
edit: what do you have your rev limiter set at? It there another way to get around using an ecu? Can the greddy emanage be used on the VQ30DE? And do you have any information on the SMT6?
Old Aug 2, 2005 | 09:08 AM
NmexMAX's Avatar
dot dot dot ...
Old Aug 2, 2005 | 09:18 AM
sean05's Avatar
edit above...
Old Aug 2, 2005 | 09:24 AM
NmexMAX's Avatar
dot dot dot ...
No info on SMT-6 but check these forums.
I have 7200 rpm ....
Old Aug 2, 2005 | 09:26 AM
sean05's Avatar
were there any links posted? i dont see any
Old Aug 2, 2005 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
Browse ...
Old Aug 2, 2005 | 09:38 AM
sean05's Avatar
Browse ...
by these forums did you mean maxima.org? i just i misunderstood.
Old Aug 2, 2005 | 09:41 AM
Kevlo911's Avatar
Kevlo for President
Look through out the All Motor forum, you will find a few threads about it.
All SMT bugs are not worked out yet, a fix is in the works--we will find out soon if it works
Old Aug 2, 2005 | 09:44 AM
aznsap's Avatar
there's some info on the SMT-6 in this all motor forum. also for the ecu, you can put an auto or 5speed ecu in your car (as long as you don't mind a temporary cel) and send your original ecu into jwt or ts, then swap when you get your original ecu back.
i actually have an auto ecu for sale from my '95 if you're interested.
Old Aug 2, 2005 | 09:45 AM
Kevlo911's Avatar
Kevlo for President
Auto ECU's can be used in manuals, not the other way around.
Old Aug 2, 2005 | 10:08 AM
sean05's Avatar
does the auto ecu make the car perform any difference in a 5 speed car. Sounds weird?
Old Aug 2, 2005 | 10:38 AM
DandyMax's Avatar
3.5 in the works
No. You just get bogus CEL's.
Old Aug 2, 2005 | 10:46 AM
NmexMAX's Avatar
dot dot dot ...
And a slight rev match/mismatch .... Check the 4th gen forums, theres a recent thread in there that explains the differences.
Old Aug 2, 2005 | 10:51 AM
sean05's Avatar
thanks guys
Old Aug 2, 2005 | 11:04 AM
plurco's Avatar
Several threads on the subject. Here is one where a member got gains from his SAFCII.
http://forums.maxima.org/showthread....highlight=safc
Old Aug 8, 2005 | 08:51 AM
joebangaa's Avatar
is a vafc useful for 5.5 gens...say to control our own VI or is this just a stupid thought
Old Aug 8, 2005 | 09:00 AM
s0ber's Avatar
you wouldnt really need to control the VI, your VI opening rpm is fine, little to no dip in power so nissan got that right.
Old Aug 8, 2005 | 09:30 AM
joebangaa's Avatar
so is that little dip when it switches over negligible? i see it in every 5.5 gen dyno
Old Aug 8, 2005 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
Yes negligible .... Happens @ 3.8k slight dip .....
Old Aug 8, 2005 | 03:27 PM
killerVQ30DE's Avatar
Unless you have factory MEVI that activates at 5700rpm instead of more optimal 5200rpm
Old Aug 8, 2005 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
He's referring to the 3.5L VI
MaximaDrvr
Aug 19, 2015 08:20 PM
