Sponsored by:
Sponsored by: CARiD
00-01 ECU in a 4th gen w/3.5 swap
Old Aug 20, 2005 | 01:11 PM
Weimar Ben's Avatar
Helicopters! Money!!!
I've been contemplating the 3.5 swap and was thinking that a 00-01 ECU may be the best if you don't want E-gas. This would be better than a 4th gen ECU since you can advance the timing and may be able to eliminate the need for an RPM switch.
The fuel maps for the higher RPM's for the 00-01 ECU are prolly superior to that of the 95-99ECU.
The question would be with the wiring and connectors....Is the 00-01 ECU wiring more like the 95-99 or more like the 02-03?
Old Aug 20, 2005 | 01:48 PM
tedo007's Avatar
faster than you think
When you get the timing advanced in a 5th gen it is only the base timing, not the timing at WOT.
The ECU harness is similar from 00-03.
It would be better to get an 01 ECU and get technosquare to flash the 00-03 Program on it.
Kevlo911
Old Aug 20, 2005 | 01:54 PM
Weimar Ben's Avatar
Kevlo911
Just went to the TS website and it looks like they don't have a ECU for the 00-01. Can you have a 01ECU and flash it with the 00-03 program and have VTC functionality?
Old Aug 24, 2005 | 10:46 AM
2kGLE's Avatar
TS does have the 2001 cali spec ECU cracked and they have a program, its just not on the site for some reason. I spoke with Brian at TS a while ago about running a 3.5 with a 01 ECU, with or without VTCs, and he didnt really know. They were down to try it, but were guarantying anything.
Old Aug 24, 2005 | 01:15 PM
NmexMAX's Avatar
dot dot dot ...
How would it eliminate this?
Again, how/what is your logic to come to this conclusion?
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 10:17 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
