need basic info on 3.5 swap 56k to slow to surf
Originally Posted by MaxObesset
its crankin over but not starting and theres no fuel goin through?
i was just wondering how are the stillen headers i just found a set online
http://cgi.ebay.com/ebaymotors/2002-...81321629QQrdZ1
could u use these if u did a vq3.5 swap anythign have to be done?
http://forums.maxima.org/showthread.php?t=264127
got the car started
its runing excellent it was the stupid sensors
i have a stock 4th gen fuel pump do i have to upgrade ?? to what??
Could you be a little more specific in telling us what the problem was? I'm just curious because I'm considering doing this project in the future and I'd like to know what can go wrong.
Here's a thread that has some pictures related to wiring up the Summit switch
http://forums.maxima.org/showthread....5&page=1&pp=30
Basically, red wire goes to 12V source, black to ground, white to tach signal and yellow to VSS. A 12V source should be connected to the other pin of the VSS.
Easiest place to get a tach signal is the TAM screw in the dash. I usually use the aux power wire in the console for 12 V.
ok thanks
i think im gonna have to go back to the 3.0 oil pans my cars runing fine buts it feels like its backfiring and bucking
i keep gettin the same code cam/crank sensor po 1336 code from autozone
what do you guys think i should do
Mar 12, 2020 12:06 AM
MaxRPM6
Sep 11, 2015 06:56 PM
