Sponsored by:
Sponsored by: CARiD
If I went back to stock manifold, would I still need a tune as badly?
Old Sep 8, 2005 | 07:43 PM
AsthmaMax11's Avatar
Hey yall,
I drive a 98 5-speed with JWT ECU, MEVI, Y & B pipes, UDP and intake and I was wondering if getting a SAFC-II would be as necessary if I switched back to the USIM manifold.
Bruce
Old Sep 8, 2005 | 07:50 PM
Zack342's Avatar
nope not necessary but it can't hurt
Old Sep 8, 2005 | 08:13 PM
sweet. Hey Zach I dynoed tonight. I'll try to send you the files. The JWT ECU gave me 6 WHP and 11 WTQ. There is something really wrong with my car though. We had to open the MEVI manually and my #'s were STILL way off! I'd like to hear your comments on them.
Old Sep 8, 2005 | 08:30 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
What did you dyno?
Old Sep 8, 2005 | 08:57 PM
MDeezy's Avatar
Have any graphs of the runs?
Old Sep 9, 2005 | 06:16 AM
I can send my scanned Dyno to whoever can post it. My #'s are at LEAST 15WHP and 10WTQ low with the VI being manually opened. I'm not even going to post the Dynos where the VI didn't open because they are very close to stock #'s.
Something is messed up on my car.
Old Sep 9, 2005 | 09:12 AM
MDeezy's Avatar
I can host the pics. send them to Mdeezy@gmail.com
Old Sep 9, 2005 | 10:27 AM
Zack342's Avatar
zackmax99@yahoo.com. i can compare your run files to mine and post them if you like
Old Sep 9, 2005 | 11:21 AM
I'm gonna go ahead and send them to Mdeezy because I don't have the run files yet, I just scanned the laminated Dyno sheet to JPEG form....it would be a sweet comparison though. I'll see if I can get them.
Old Sep 9, 2005 | 12:07 PM
MDeezy's Avatar
his dyno run - *resized*
link to the full size version
http://img.photobucket.com/albums/v7...Pics/Dyno2.jpg
Old Sep 9, 2005 | 12:28 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Yep, those are typical numbers for a USDM manifold. With your mods and the MEVI, I would say you should be getting 190-200fwhp.
Old Sep 9, 2005 | 12:31 PM
96sleeper's Avatar
Have you checked knock sensor, plugs, coil packs, misc. maintenance items? Your A/F ratio should not be causing that much power loss.
Old Sep 9, 2005 | 02:39 PM
In the last 6 months I have changed spark plugs, coil packs, and fuel filter.
My Knock Sensor was changed right before I bought this car. (50k ago) and I'm not getting a code for it either. Shoot, I don't know what else to check for...
On my dyno:
The top line is with JWT ECU and the bottom is with Stock ECU. Bijan manually opened the MEVI on both runs.
Old Sep 9, 2005 | 05:51 PM
Zack342's Avatar
once you get the run files send them to me i would like to compare them to mine to help you figure out why your car is down about 20whp and 15wtq
Old Sep 9, 2005 | 06:17 PM
I just sent an email to the DynoLab. I know my power is down because before the MEVI and JWT ECU I pulled 178.5 WHP and 190.5 WTQ!!
Anyone care to speculate what is going on with my car???
Old Sep 9, 2005 | 08:17 PM
96sleeper's Avatar
Do you have an air leak around the manifold? gasket installed incorrectly, blocking the path of the air? It could be tons of things. Does the car drive and run perfectly normal under all other conditions?
Old Sep 9, 2005 | 08:41 PM
Nealoc187's Avatar
SLOW
Is this the same dyno as you have made your other dyno runs on?
Old Sep 9, 2005 | 08:51 PM
Nealoc187's Avatar
SLOW
Also have you ever done a compression test?
Old Sep 9, 2005 | 11:20 PM
Zack342's Avatar
Another thing no one has mention and it maybe a long shot but i noticed you are in atlanta what octane gas do you think your getting? With all this hurricane stuff and gas crisis maybe the stuff they are give you guys is garbage
Old Sep 10, 2005 | 12:03 AM
|Bijan|'s Avatar
UCF Lexus
Bruce, dont feel bad, we'll figure this mother out, and make it more powerful.
This video is to serve the purpose of comparison of USIM and my mods vs. his and what problems he may have. See for yourself...
http://www.v6atlanta.com/bijan/iwalkbruce.wmv
Post what you think
Old Sep 10, 2005 | 05:02 AM
96sleeper's Avatar
That is the same dyno that I have gone to every time, it seems to work fine for me.
Old Sep 10, 2005 | 06:57 AM
s0ber's Avatar
Anyone have the AFR?
Old Sep 10, 2005 | 07:04 AM
Kevlo911's Avatar
Kevlo for President
The switch over is too early. Move it to 5000-5200. Car need full tune up?
Old Sep 10, 2005 | 07:33 AM
Just replaced the MEVI gaskets 2 months ago. I had JAY25 help me with it. Somedays it runs ALOT better than others I mean there is like a night and day difference sometimes.
Yeh it's the same dyno, they wanted a $100 for the AFR so I couldn't get that done this time.
I haven't done a compression test but I figured since I put a low mileage motor in last year that it should be ok? I will definately look into it though.
Well that's a possibility but it doesn't "feel" any different than before gas prices went crazy. (I even added one of those "octane boosters" before I dynoed )
Post what you think
haha, Bruce gets walked. that 2nd gear vs 3rd gear run is embarassing!
Old Sep 10, 2005 | 07:15 PM
sean05's Avatar
humm i hope mine is working. ill have to make a video. i mean it opens and all but it doesnt feel much different. Check the hose that goes to the EGR valve. my strut bar rubbed it and ripped it a little. its taped with electrical tape now. maybe i should fix that.
JRod28
Dec 29, 2023 09:56 PM
incubusjohnny
Nov 3, 2015 05:18 PM
tcb_02_max
Sep 11, 2015 12:23 PM
sonic7
Aug 20, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
