Sponsored by:
Sponsored by: CARiD
How much more timing with step colder plugs?
Old Sep 15, 2005 | 01:20 PM
Deckdout2's Avatar
Play with my balls
I have 1 step colder NGKs. Can I safely advance more than 17 degrees? I asked another member but he wasn't sure.
Old Sep 15, 2005 | 01:25 PM
NmexMAX's Avatar
dot dot dot ...
What other member?
You have a local member that should be able to answer this
Old Sep 15, 2005 | 01:29 PM
Deckdout2's Avatar
Play with my balls
Originally Posted by NmexMAX
What other member?
i know, we were on the phone the other night, and forgot to ask him. I asked sloppymax, and he said to be safe I should stay at 17. Which is fine but I wanted to see if I could push the envelope a little. If not then 17 will do, seeing that I'm sitting at 14 I think.
Old Sep 15, 2005 | 01:36 PM
NmexMAX's Avatar
dot dot dot ...
I think that avatar is the ebst I've seen in a while ...
There was someone in a 5th gen(3.0) that advanced it to 20*, and it's 'within' spec (+/- 5*) But still
Old Sep 15, 2005 | 01:49 PM
Deckdout2's Avatar
Play with my balls
great thanks for the info.....
i laughed the first time i saw the pic, and i knew i had to use it.
Old Sep 15, 2005 | 01:53 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i can ask him tonight. we doing some manifold work.
Old Sep 15, 2005 | 01:56 PM
NmexMAX's Avatar
dot dot dot ...
Old Sep 16, 2005 | 06:25 AM
sloppymax's Avatar
sr said the highest it will go is 17btdc. the 01 ecu and some 00s will advance up to 20 after the idle air learn procedure but 17 is the maximum for the 5.5th gens.
Old Sep 16, 2005 | 11:12 AM
mtrai760's Avatar
'Trynna' is not a word
You know a step colder plug will cause you to lose some power right? Why not run the stock plugs? That would be a better solution than advancing your timing further.
Old Sep 16, 2005 | 11:54 AM
sloppymax's Avatar
he got a good deal on the iridiums and has plans to put the bottle back in.
Old Sep 16, 2005 | 12:01 PM
mtrai760's Avatar
Then he certainly would not need his timing advance running nitrous.
Old Sep 16, 2005 | 12:10 PM
sloppymax's Avatar
hopefully we still have the ability to use the consult 2 at our leisure which would be easy to plug up and change timing. beats changing plugs anyday.
Old Sep 16, 2005 | 02:36 PM
Deckdout2's Avatar
Play with my balls
+1 yep that's the plan.
Old Sep 16, 2005 | 02:37 PM
Deckdout2's Avatar
Play with my balls
I plan to pull it back some when i throw the bottle back in.
Old Sep 16, 2005 | 02:38 PM
Deckdout2's Avatar
Play with my balls
that's true, rather change timing, then plugs everytime.
Thanks for the help guys.
lowpost99
22
Sep 2, 2015 04:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
mikekay
Aug 10, 2015 12:52 PM
kirkhilles
Aug 8, 2015 10:53 AM
