Sponsored by:
Sponsored by: CARiD
i regret doing the vi swap
Old Sep 18, 2005 | 05:20 AM
mad-max98's Avatar
i no longer regret doing the vi swap<UPDATE>
ever since i did the swap and i hate my car, the way it drives,idles and hesitates when wot , why!!!!! i don't know ,, i'm using the vi00 with 4th gen lim and 4th iacv , it actually idles fine after playing with the idle screw however it hesitates and today it won't rev past 2000rpm and bogs down then it overheated really fast right after,,, the only thing that i'm trying to take care of is the freakin' egr but i don't have experience with them , right now it's open to the engine bay <stupid i know> ,, anybody experienced something like that
Old Sep 18, 2005 | 07:24 AM
Kevlo911's Avatar
Kevlo for President
You prob have vaccum leaks. All your electrical connections are prob not good either.
Old Sep 18, 2005 | 08:15 AM
nismology's Avatar
The fact that you're experiencing hesitation and the motor not revving past 2000 RPM sounds like the MAF sensor is dying or dead.
Old Sep 18, 2005 | 08:25 AM
Kevlo911's Avatar
Kevlo for President
Yeah, it might be the MAF or TPS. I prob forgot to plug in the MAF
Old Sep 18, 2005 | 10:21 AM
Stephen Max's Avatar
An overheating engine will send the ecu into fail safe mode, resulting in a 2000 rpm rev limit.
It sounds like you have cooling problems, maybe a stuck thermostat. The 00vi won't cause engine overheating.
Old Sep 18, 2005 | 01:43 PM
Weimar Ben's Avatar
Helicopters! Money!!!
once you get these issues figured out, you'll love your max more than you ever did.
Old Sep 18, 2005 | 03:54 PM
mad-max98's Avatar
stephen i think you're on the money because it won't do that unless it's hot but i didn't know that the ecu was supposed to do that when hot,,,,does anybody have a common on the egr part thnx
Old Sep 18, 2005 | 07:24 PM
MAXimumHP's Avatar
Why don't you just get the 2000 EGR guide tube and run it the way it's meant to be. I think I only paid 17 bucks for the thing. Call up DAVEB, he can hook you up.
Old Sep 18, 2005 | 07:30 PM
chillin014's Avatar
sorry to go off topic but how hard is it to do this modification? i'm pretty interested since its said to be better than the MEVI and usim.
on the dynos i saw the mevi was below torque/hp considerably all the way until like very high RPM. that seemed like a downgrade to me (i dont have traction problems). so is the vi similar? where it puts more hp at very very high end and sucks out power from the lower range?
Old Sep 18, 2005 | 08:16 PM
chillin014's Avatar
nvm, my bad i overlooked some stickies.
Old Sep 19, 2005 | 12:27 AM
mad-max98's Avatar
no vacuum leaks , tps and maf are good
Old Sep 19, 2005 | 11:23 AM
vipervadim's Avatar
I like Maximas
the 2000rpm rev limit is either MAF or TPS.
which throttle body did you use 4th gen? 5th gen? PF? VQ35?
unplug the TPS connectors and see if it revs past 2000. if it does, then you have to properly set up your TPS (with multimeter) the haynes manual/FSM describe the process in detail.
recently a friend's maxima had the TPS issue, same symptoms as yours.
Old Sep 19, 2005 | 11:32 AM
Dave B's Avatar
Not DAVEB the parts guy
Verified how? The overheating could also be caused by air in the cooling system. Doesn't the install of the 00VI require some fab work with the TB coolant line?
Old Sep 19, 2005 | 04:57 PM
mad-max98's Avatar
i plugged both coolant pipes,,, and it does rev past 2000 rpm but after driving for a while it starts overheating and revlimiting,,
Old Sep 19, 2005 | 04:59 PM
mad-max98's Avatar
and the reason i'm not doing the egr thing is because it's gonna take forever to get and there is no junk yards around here
Old Sep 19, 2005 | 07:29 PM
1chewabacha1's Avatar
yeap..... This is why many choose to go for the MEVI swap, like me, sure there's not as much power gains..... but it's so easy to do compared to the 00VI!
I would love to go for the extra power gains as long as I knew every single step for a sure install.
Does anyone know where to find a detailed step by step guide of how to install an 00VI? Maybe you should do a very detailed write up of how you set it up StephenMax.
Old Sep 19, 2005 | 07:35 PM
chillin014's Avatar
i agree, there needs to be a HOW TO for this. being told to research is getting a little old.
i jsut started a thread to get more info about this, and i've been told there is many ways to do it. well im certainly not familiar with any of it so that leaves me pretty lost if everything is up in the air as far as what is needed.
Old Sep 19, 2005 | 08:17 PM
mad-max98's Avatar
you only need to know the hoses routings and common sense, the vacuum routings is what screwed me up and my manual says little to nothing about them,,, oh and you need a reliable source of tools on demand
Old Sep 20, 2005 | 05:27 AM
deezo's Avatar
I've seen a few installs in person and it shouldn't be rocket science to know what is what in order to make the irght connections with the vacuum hoses. There's really not much to it.
Old Sep 20, 2005 | 05:34 AM
You do have to disconnect the coolant lines to the TB and to the back of the USIM and either block them or splice them to make a bypass. That probably introduces a wee bit of air, certainly not enough to cause cooling problems.
Old Sep 20, 2005 | 07:50 AM
SDot82's Avatar
I looped my coolant lines so it would continue the flow maybe thats your problem. You may want to give it a shot.
Old Sep 20, 2005 | 10:17 PM
mad-max98's Avatar
for the coolant lines i had to block 3 lines if anybody can verify that number,, if you guys had to block more then i have a coolant leak which i can't see however my radiator is losing coolant fluid hmmmmmmmm!!!!! stephen where's the line that goes to the back of manifold !!that might be the one!!!!
Old Sep 20, 2005 | 10:20 PM
mad-max98's Avatar
that's what i did with 2 of the hoses which are the small ones that are welded together next to the vacuum line going to the FPR.... i wish i had a camera so i can show you
Old Sep 21, 2005 | 10:38 AM
SDot82's Avatar
I only blocked off 2 coolant lines, I'll see if I can take a pic.
Old Sep 21, 2005 | 10:46 AM
Curt's Avatar
............i had to block 3 lines ..........
3 lines?? I usually think in pairs: a supply and a return. Maybe that "3rd" line is the culprit in your coolant loss problem!
Old Sep 21, 2005 | 08:55 PM
mad-max98's Avatar
bump..................
Old Sep 22, 2005 | 10:00 AM
scrhale's Avatar
I so want to hear all about your 00VI once you get everything ironed out.
You may want to get a package of depends in your car just in case
Old Sep 22, 2005 | 05:08 PM
mad-max98's Avatar
for me or for the car ??? LOL
Old Sep 22, 2005 | 06:40 PM
scrhale's Avatar
LOL Both ... your @$$ is going to be ****ting bricks when you enter redline
Old Sep 22, 2005 | 08:19 PM
eckohb's Avatar
trust me, once the VI is working how its supposed to, you will love it to death. I went through hell with mine, and if we had to do it again, it wouldnt be so bad, but once everything was ok, it was awesome. You will indeed be sh!tting bricks feeling power all the way to 6600, depending on your ecu
Old Sep 22, 2005 | 10:04 PM
mad-max98's Avatar
yea i'm gonna take some pics and show you guys the third hose i had to block and i can't find a pair for it which i think is the reason i'm losing coolant fluid,, i don't think i'm gonna have enough time to experience the all motor power because i'm going turbo right after , i have all the stuff waiting for me to start working but i'm not about to do it till i taKE care of the overheating prob. ,i'm so pissed off
Old Sep 23, 2005 | 07:43 AM
MAXimumHP's Avatar
I think these are the two that need to be looped. Someone correct me if I am wrong since I am doing this from my desk without looking at the car.
Old Sep 23, 2005 | 07:56 AM
SDot82's Avatar
Yeah those should be the ones you loop.
Old Sep 23, 2005 | 05:48 PM
mad-max98's Avatar
i can't figure those pics out
Old Sep 23, 2005 | 05:50 PM
mad-max98's Avatar
i have a question does anything go to the back of the manifold closer to the firewall
Old Sep 24, 2005 | 01:01 PM
s0ber's Avatar
EGR, and the support brackets
Old Sep 24, 2005 | 05:00 PM
mad-max98's Avatar
what about coolant hoses????
Old Sep 25, 2005 | 10:27 AM
SDot82's Avatar
There are some big coolant hoses that go to the firewall but you shouldn't have messed with them during the swap. The only coolant lines that should have been removed lead to the throttle body and egr guide tube. In the engine drawing above there are two (red) highlighted hose. This is a pic for the highlighted hose on the rightside
And for the left highlighted hose
The two hoses are next to the fuel rail and lower manifold on the rightside of the car. If you can't find were the hole is just fill your radiator with water and let your car run and find out where it is.
Old Sep 25, 2005 | 05:00 PM
mad-max98's Avatar
i blocked that hose in the 2nd pic but there is no return line for it that i can see ..i'm going to use a pressure tester for the rad. to find that son of *****
Old Sep 25, 2005 | 08:06 PM
SDot82's Avatar
That's the return line for the one in the first pic.
