Sponsored by:
Sponsored by: CARiD
DE-K Injector harness splicing
Old Sep 22, 2005 | 08:34 PM
maximamaybe74's Avatar
Does anyone know what has to be done to the wires on the injector harness when installing a DE-K engine into a fourth gen. I heard it has to spliced but in what way, and was it hard?
Old Sep 23, 2005 | 06:16 AM
Stephen Max's Avatar
Since the injector harness connectors are different, you have to cut off the 4th gen connectors and solder on the 5th gen connectors. If you have never soldered before, maybe you should find someone to do it for you. It's not hard, but it does require some technique to do it correctly. Don't cut corners and do a cold splice or a crimp. You will end up with problems in the long run.
When you do the soldering, retain the original orientation of the wires relative to the connector. That is, before you cut off the old connector, look at which wire is on the left side and which is on the right side, and keep that orientation when you solder on the new connector.
Also, get some heat shrink tubing from Radio Shack or Home Depot and use that for insulating the solder joint. Electrical tape has a tendency for losing its grip in elevated temps and coming off. Or get some electrician's tape made for elevated temp situations, but the tubing is best.
Old Sep 23, 2005 | 07:43 AM
Thanks alot Stephen, so i shouldnt have to order any special parts, i just have to take the old 4th gen connectors off my old motor and solder them onto the new 5th gen connectors.
Old Sep 23, 2005 | 08:06 AM
Ummm, sorta. You have to take the 4th gen connectors off, and solder the 5th gen connectors onto the wiring harness. Maybe that is what you meant, but just to be sure, you are going to use the 5th gen injectors that come with the DE-K, right?
Old Sep 24, 2005 | 05:10 AM
Yea i figured it out, thanx alot Stephen.
Old Sep 24, 2005 | 01:09 PM
jmeister's Avatar
How's it coming? Soldering the injectors was the worst part for me.
Old Sep 24, 2005 | 03:23 PM
Everything is all wired up and it runs.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
