Sponsored by:
Sponsored by: CARiD
Guys with anything to read knock (SAFC, R500, anything else) do you get knock at idle
Old Oct 12, 2005 | 03:19 PM
Nealoc187's Avatar
SLOW
Just wondering if you guys get any knock reading whatsoever at idle? I just hooked up the knock feature on my PLX R500, it is set up just to give a raw voltage output (0.0-5.0V). I just started the car and I'm getting no reading whatsoever. 0.0V still. Is this normal or should there be at least some activity?
Old Oct 12, 2005 | 03:58 PM
Kevlo911's Avatar
Kevlo for President
FSM says it should say 2-3v. But I have read that most people dont get any usable data from the KS using SAFC and things similar to that.
Old Oct 12, 2005 | 05:40 PM
eng92's Avatar
When I first got my TS ecu with the increased timing advance, I ran with my DVM plugged into the ecu harness measuring knock sensor ouput relative to ground. Once the engine was warmed up, it would stabilize at 2.39 V and never fluctuate.
Old Oct 12, 2005 | 06:47 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=424609
Old Oct 12, 2005 | 11:15 PM
Nealoc187's Avatar
SLOW
Hmm i wonder whats going on with my 0.0V then.
Old Oct 13, 2005 | 07:48 AM
DandyMax's Avatar
3.5 in the works
I agree with eng92. I've got my KS inputted to my EU and it stays right around 2.3v. If you're not getting any signal, it's either the unit you're using or something's not hooked up/set up properly.
Old Oct 13, 2005 | 12:03 PM
Nealoc187's Avatar
SLOW
I'm going to try running a long wire directly to the wire coming off the KS. Right now I've got it tapped at the KS wire on the ECU harness. Maybe the wire is disconnected somewhere and I just don't know it.
Old Oct 13, 2005 | 01:04 PM
DandyMax's Avatar
3.5 in the works
Just a suggestion but you could check the circuit with a continuity tester or multimeter first... it would tell you the same thing without having to run wires. Or at least physically measure the voltage on the tapped wire at the ECU. That would tell you if the KS circuit's good and the PLX is not reading or displaying it properly...
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
maxipower
Aug 21, 2015 11:10 AM
doobadoo
Aug 15, 2015 06:43 PM
