Sponsored by:
Sponsored by: CARiD
? on SAFC tuning
Old Nov 8, 2005 | 10:32 AM
  #41
Velicos's Avatar
I've talked to 98SEBlackMax and he was extremely helpful last night, we concluded that the SMT6 has to go and I should considering investing in the EU.
Old Nov 8, 2005 | 11:43 AM
  #42
virgilio7's Avatar
in vq35 altimas the smt6 only let you retard timing which is only usefull for nitrous. other than that the safc2 should do the rest.
Old Nov 8, 2005 | 11:51 AM
  #43
NmexMAX's Avatar
dot dot dot ...
All SAFC-ii can control is A/F...
Old Nov 8, 2005 | 12:00 PM
  #44
SR20DEN's Avatar
VQ Wizard
Don't forget my method of making it advance the ignition timing.
Old Nov 8, 2005 | 12:01 PM
  #45
maxmale's Avatar
Originally Posted by SR20DEN
And yours still isn't finished.
this is correct i should hopefully be able to pull out a few more ponies.
Old Nov 8, 2005 | 12:06 PM
  #46
SR20DEN's Avatar
VQ Wizard
www.p1auto.com
Old Nov 8, 2005 | 12:18 PM
  #47
joebangaa's Avatar
oh believe me i do understand the advantages of tuning with a mustang dyno over an inertia based setup. but they spread slander about DJ's, that's all..
Old Nov 8, 2005 | 02:19 PM
  #48
SR20DEN's Avatar
VQ Wizard
That goes both ways. I like and support them both. But at least DJs are fairly consistant throughout the country. The same can't be said at all for Mustang Dynos. The numbers you produce on a Mustang are relative ONLY to that specific dyno.
Old Nov 8, 2005 | 02:32 PM
  #49
SonicDust187's Avatar
SR: How much fuel do you think I need to add on stock 4th gen injectors to retard the timing a bit for high shots of juice? I want to run 125 on 93 octane.
Old Nov 9, 2005 | 09:36 AM
  #50
Starchild2K2SE's Avatar
Does anyone have the write up or a wiring diagram for the vafc? I want to purchase, but im not going to purchase and try to install it and mess up the wiring harness in the process. I know a few vq35 guys installed the vafc, help a brotha out....
Old Nov 9, 2005 | 10:47 AM
  #51
s0ber's Avatar
read the installation manual, has all you need.
Old Nov 9, 2005 | 11:26 AM
  #52
Nismo3112's Avatar
Custom User Title
By leaning the A/F out right?
Old Nov 9, 2005 | 11:32 AM
  #53
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
either use bigger injectors or use an fpr to bump pressure and then back it out with an afc or whatever you would use.
Old Nov 9, 2005 | 03:47 PM
  #54
So it will have the wiring up to use the vafc with a vq35 right? i dont wanna buy and have my product sitting catching dust...
Old Nov 9, 2005 | 03:52 PM
  #55
NmexMAX's Avatar
dot dot dot ...
There are ECU codes referencing VQ35's and their diffrent applications, don;t know th e SAFC off hand... But Jime has a diagram for it in 5g how to's(SAFC) and mines been collecting dust for ~3 mos
Old Nov 9, 2005 | 05:51 PM
  #56
MaxObesset's Avatar
i have a 97 max with a 3.5 i want to tune it what way should i go that is the best way and can tune it to whatever ?
Old Nov 20, 2005 | 04:35 PM
  #57
HotshotVQ35's Avatar
use the info on jimes page, i bought the V-AFC-II per recomendations, have pretty much all of it figured out, check here for some of the details..
http://forums.maxima.org/showthread.php?t=441029
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
