Sponsored by:
Sponsored by: CARiD
00VI VIAS Question
Old Dec 7, 2005 | 10:14 AM
Tyrexx's Avatar
00VI VIAS Question
Is there a way to test that it's working (VIAS) before installing everything?
I might be getting a IM thats been sitting out in the weather with no hood, It's all discolored, has anyone run into any problems besides the "arm" snapping loose?
How is this wired? From what I've read when the VIAS gets no power it's on the long runners (low end) and when it gets power it switched to the short runners (high end)
Is it as simple as 12V to the R/Y Wire or what?
Also take a look at this from the FSM:
Thanks!
Old Dec 7, 2005 | 11:20 AM
gtr_rider's Avatar
192.168.1.1
Remove the VIAS cover on the driver side (3 screws) and check if the cup is still connected to the rod.
Old Dec 7, 2005 | 01:04 PM
s0ber's Avatar
stfu noob...
lol j/p
Old Dec 7, 2005 | 02:14 PM
vipervadim's Avatar
I like Maximas
be careful with those soft-headed vias bolts, replace them with steel hex bolts if you can might be a good idea to have jbweld handy, since you're opening up the vias, you might as well do the fix..
Old Dec 7, 2005 | 03:20 PM
gtr_rider's Avatar
192.168.1.1
Originally Posted by s0ber
stfu noob...
lol j/p
bannnnnn
Old Dec 7, 2005 | 11:24 PM
Tyrexx's Avatar
Thanks for the input guys buy I was asking if there was anything that can go wrong besides the "arm" snapping loose. How would I test to see if it works? Thanks
Old Dec 7, 2005 | 11:31 PM
Tyrexx's Avatar
Here's the pics showing the weather discoloration. : Do you think I should buy it? It's $160
Linked because of size:
http://www.tyrexx.com/Uploader/filezz/1/00vi_001.jpg
http://www.tyrexx.com/Uploader/filezz/1/00vi_002.jpg
http://www.tyrexx.com/Uploader/filezz/1/00vi_003.jpg
http://www.tyrexx.com/Uploader/filezz/1/00vi_004.jpg
http://www.tyrexx.com/Uploader/filezz/1/00vi_005.jpg
http://www.tyrexx.com/Uploader/filezz/1/00vi_006.jpg
Old Dec 9, 2005 | 03:14 AM
Tyrexx's Avatar
bump .
Old Dec 9, 2005 | 05:40 AM
Stephen Max's Avatar
My 00vi was pretty weathered looking when I got it. I gave it a good cleaning and painted it with satin black paint, and it looks great.
Old Dec 9, 2005 | 06:37 AM
s0ber's Avatar
although not the blingest engine bay out there, something about it makes it sexier than the rest, FUNCTION !
Old Dec 9, 2005 | 07:02 AM
DandyMax's Avatar
3.5 in the works
Looks to me like that discoloration is just sun bleaching. If everything else is in good condition it's probably no problem; nothing a nice coat of paint wouldn't cure.
Old Dec 12, 2005 | 07:18 PM
KNYFE's Avatar
When you painted, did you prep at all? Did you use high heat paint?
Old Dec 13, 2005 | 04:48 AM
I gave it a thorough cleaning and degreasing with acetone. I can't remember exactly, but I think I did use a paint that can withstand engine heat. The 00vi itself doesn't really get too hot, but it can get up to 150 F and maybe more under the hood.
Old Nov 25, 2006 | 10:54 AM
Tyrexx's Avatar
Bump for edited post.
Old Nov 25, 2006 | 11:12 AM
Tatanko's Avatar
Bacon Lover
I also painted my manifold before install. It isn't nearly as nice as matty's because it got a little roughed up during the install, though.
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Socalstillen
Sep 26, 2015 12:01 PM
