Sponsored by:
Sponsored by: CARiD
Port and polish pics
Old Dec 16, 2005 | 01:52 PM
japmaxSE's Avatar
Go Get a Life!
Well I never got the chance to take pics of it done before so here it is after 890 miles.
Old Dec 16, 2005 | 01:56 PM
japmaxSE's Avatar
Go Get a Life!
I'm shocked on how clean it is, it looks the same as installed.
I think the EGR block off helped 100%
Old Dec 16, 2005 | 05:13 PM
GodFather's Avatar
Made in Taiwan
nice, did you ever get a chance to figure out the before and after gains from port and polishing?
Old Dec 16, 2005 | 07:31 PM
Tatanko's Avatar
Bacon Lover
Did you notice any losses in gas mileage from blocking off the EGR?
Old Dec 16, 2005 | 08:13 PM
japmaxSE's Avatar
Go Get a Life!
No not really, never put more than a 1/4 tank of gas.
Old Dec 16, 2005 | 08:19 PM
japmaxSE's Avatar
Go Get a Life!
I did all my mods at one time. So the before and after gains would be huge. If somone has pics of stock 3.0 heads to compare that would be great. As far as I can remember it was a huge difference.
Old Dec 16, 2005 | 09:08 PM
Tatanko's Avatar
Bacon Lover
Alright...so...have you just not taken notice, or have you actually calculated and know that it's not made a noticeable difference? I don't mean to nit-pick or sound snotty, it's just that my car is a daily driver and I have several reasons for wanting to eliminate EGR. However, if it's going to reduce my gas mileage by atleast 1 MPG, I'm not going to remove it.
Old Dec 17, 2005 | 05:28 AM
japmaxSE's Avatar
Go Get a Life!
Sorry I thaught you would know that it was a weekend car.
I never really noticed any increase in millage it was actually worse. My car wasn't a daily driver, from local meets and back home. I was also using
1/4 > 110* mix with the pedal to the floor.
The only thing I know is that the EGR block off made the TB to IM all the way down spotless.
Oh and it made my car run a little richer than usual at idle. Which would indicate an increase in chamber temps. Because The EGR is designed to cut down on Nox, helps cool down the combustion chamber by recirculating exhuast gases. So with the added octane level I was running way less rich at idle.
Old Dec 17, 2005 | 05:33 AM
japmaxSE's Avatar
Go Get a Life!
Theres a thread I made on the EGR block off. I'll try and find it.
Old Dec 17, 2005 | 05:38 AM
japmaxSE's Avatar
Go Get a Life!
Ok here it is some usefull info.
http://forums.maxima.org/showthread.php?t=351657
Old Dec 26, 2005 | 01:05 AM
claudiusmaximas's Avatar
thanks .
Old Dec 30, 2005 | 12:00 PM
Broaner's Avatar
2060lbs and falling...
Without PCV and EGR there is nothing at all to make it dirty except for the extremely low amount of dirt that gets by the filter.
Old Jan 8, 2006 | 03:52 PM
michaelnyden's Avatar
did they flow test it before and after the P&P by any chance? to see what kind of a increase they made? and how much did you pay to have it done?
Old Jan 9, 2006 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
Nope. .
Old Jan 9, 2006 | 06:41 PM
japmaxSE's Avatar
Go Get a Life!
I did it myself took me 63hrs about 3days. Never had it bench tested I couldn't afford to do it. I did the work at my friends machine shop according to them I did one heck of a job but all credits go to Jim he helped me through the whole job. I have no idea how much more power it gave me since I did the whole job all at once.
Since then broke the Auto tranny first, 5spd in broke brand new driver side axle "snap", blew synchros and reverse while doing a test launch on
100* shot spray in 2nd then I called it quits... FWD sucks........
Old Jan 9, 2006 | 06:55 PM
JClaw's Avatar
FWD sucks only as much as the tires you're using.
Old Jan 9, 2006 | 10:32 PM
japmaxSE's Avatar
Go Get a Life!
The 4thgen tranny I had really sucked, I mean when I launch a car and go through gears I'm really banging it hard that's just how I drive. I can't help it but when the adrenaline is kicking in you can't help but give it all she's got. The best time I had was that same day I blew the tranny I killed a 12sec supercharged Fox body with 100*shot and on 18" Khumo Ecsta's by half a car length and two car length on the second run. That night I was getting ready for Morroso Drag strip for the coming up Wed and put on the M/T slicks that I borrowed from a buddy. First test launch without NOS second with and that's all she wrote. I Honestly had fun but my pockets just got completely empty.
"YOU GOTTA PAY TO PLAY"
Old Jan 9, 2006 | 10:43 PM
japmaxSE's Avatar
Go Get a Life!
Now that I remember I did have mad Wheel Hop, I should have invested in the JBARS. I used the Heavy Duty Tie Wraps from Home Depot about 5 each side helped a little bit. When it accrues I usually feather the clutch in that relieves some of the jerkiness then quickly pop it in, whatever that means. But it did help some bit. I think when I was going into second I let off too hard and banged it into gear. I knew it before that split second something was going to give.
Old Jan 10, 2006 | 07:45 AM
Broaner's Avatar
FWD still sucks no matter how good a tires you use. You use slicks and you can't turn. You use R compounds and you can't launch but you can turn like the devil.
Old Jan 10, 2006 | 07:56 AM
japmaxSE's Avatar
Go Get a Life!
Check out the ACT clutch.
And they say it can handle 360 ft lbs
Nah it held up nice but I did throw a couple shots of spray at it, I would say prob close to 300whp+
Old Jan 10, 2006 | 02:02 PM
JClaw's Avatar
That's why most people use slicks only at the dragstrip.
Nitrous = very very violent. A VQ35 + a 100 shot is certainly putting down more than 300fwtq. More like 350 at the wheels. Nitrous dynos look like that, all tq.
You should have gone clutchnet.
Old Jan 10, 2006 | 06:22 PM
japmaxSE's Avatar
Go Get a Life!
Has anyone seen worse? I mean this is all in a couple of days.
The shop I went to said this was an example of extreme Heat build up which I indicated circled in red...
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
JonBlz
Oct 5, 2015 06:02 PM
bigfrank
Oct 1, 2015 12:51 PM
