Sponsored by:
Sponsored by: CARiD
Customized MEVI?
Old Jan 13, 2006 | 05:00 PM
zander's Avatar
Customized MEVI?
Is it possible and has anyone done it? Is it worth it if it has been done. Things like thicker gaskets or different mevi tops (whatever the correct term is)
Old Jan 13, 2006 | 05:06 PM
NmexMAX's Avatar
dot dot dot ...
What would you 'customize'? Anything can be done with the right amount of money.
Worth it in the end...
Old Jan 13, 2006 | 05:22 PM
s0ber's Avatar
I think he wants to add like a spacer (bigger gasket?) and the top, im assuming he means a fancy cover for the MEVI.
Old Jan 13, 2006 | 05:44 PM
zander's Avatar
no I mean tweaking the mevi
Old Jan 13, 2006 | 05:52 PM
NmexMAX's Avatar
dot dot dot ...
Explain 'tweak'
Old Jan 13, 2006 | 05:53 PM
nismology's Avatar
Can you be any less descriptive?
Old Jan 13, 2006 | 05:55 PM
s0ber's Avatar
He wants to modify the MEVI for little to no low end torque loss without a decrease in high rpm performance.
Old Jan 13, 2006 | 06:00 PM
nismology's Avatar
So he wants the high-RPM torque to stay the same while losing a little low-end?? Damn...why didn't i think of that??
Old Jan 13, 2006 | 06:01 PM
s0ber's Avatar
He will be awaiting your genius answer to his question....
(Only "tweaking" I can think of anyways)
Old Jan 13, 2006 | 06:31 PM
JClaw's Avatar
What you want is a 00 VI.
Old Jan 13, 2006 | 10:36 PM
zander's Avatar
I know the 00vi is better but I wondered if anyone messed with the MEVI. Since it is what I own. And by tweak I mean just that. Anything to make it any different from the stock mevi. Oh well I guess its up to me to figure anything out. Thanks anyway
Old Jan 13, 2006 | 11:14 PM
Alex_V
Im sure hitting it with a hammer would make it diffrent, and if it cracked flow better too. But those 1 or 2 cyls would be a lil lean...
~Alex
Old Jan 14, 2006 | 06:26 AM
nismology's Avatar
Well he can always paint the top of the resonance chamber and the MEVI cover pink.
Old Jan 14, 2006 | 09:02 AM
Kevlo911's Avatar
Kevlo for President
Extrude Hone the MEVI
Old Jan 14, 2006 | 02:30 PM
GodFather's Avatar
Made in Taiwan
yes...Extrude hone and make the chamber's static volume bigger to gain torque and aid high end flow's. other than that, there's no point "tweaking" it. but back to think in reality, extrude honing this puppy is going to cost ya, and you might as well go with a 00vi setup which knocks off all weaknesses of the mevi and stock intake manifold.
Old Jan 19, 2006 | 12:14 PM
hacim105's Avatar
Yes extrude hone and if possible move the butterfly plates down closer to the runner. I don't know if this would help but it seems logical.
Old Jan 19, 2006 | 12:44 PM
scrhale's Avatar
Whatever happened to that dude who claimed he made a MEVI better then 00VI and then never explained any of it.
Old Jan 19, 2006 | 07:30 PM
GodFather's Avatar
Made in Taiwan
whom? may I ask? I want to know as I am phasing into doing the 00vi setup in a couple of months. I don't want to waste my mevi.
Old Jan 20, 2006 | 02:53 PM
zander's Avatar
Once I put the MEVI back on im gonna try some things. If they work I'll let you know, if not oh well.
and it will probably be a while with school and being broke and everything.
Old Jan 22, 2006 | 10:08 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by GodFather
whom? may I ask?
japmaxSE or something to that extent.
Old Feb 3, 2006 | 02:28 PM
xloki77x's Avatar
I just picked up a new cnc machine and have it sitting in my basement. I was planning on making a set of spacers for my max (throttle body and intake manifold). I have a MEVI right now but the spacers that I'm designing would work with both the MEVI and also stock intake plenum. Obviously i would run dynos before and after installation but i s wondering would anyone else be interested?
Old Feb 3, 2006 | 06:07 PM
grey99max's Avatar
LandShark has Cosworth
Yeah - make me a 1" aluminum spacer for the top cover plate on the MEVI, and I'll buy it if reasonable.
I built one from industrial closed-cell foam, but mainifold vacuum crushed it down. I probably should have used plywood, but the foam was blue.
When you hit the throttle, the entire top of the MEVI cover is pushed down by atmospheric pressure. You could see the foam being compressed. I wanted to see if more volume in the top chamber would help 1/4 mile times, but never got to test it. Actually, if you could cut three 1/2" spacers, I could try tuning in 1/2" steps......
Old Feb 3, 2006 | 07:51 PM
xloki77x's Avatar
Well, what I can do is make the spacers for the bottom of the upper intake manifold and also make spacers for the top of the MEVI because I could R&D it on my car. I still have to get the cnc up and running but that that will definitely be my first priority on that thing. I have to wait on a new controller for the whole thing because the machine is about 15 years old and I am updating all the motors and tooling so i can cut titanium. The cost of machining an aluminum spacer for the MEVI may be high because of the material that I'd be cutting out of the middle, but I would still be interested to see what kind of gains would be possible. I should have it up and running in a week or two. I will keep you posted. Also, what else could be machined that could make gains for a vq...Ive been racking my brain for weeks! Thanks guys.
Old Feb 3, 2006 | 08:43 PM
Larrio's Avatar
The Definitive AE Master
I believe if you add a spacer between the lower IM and the MEVI, you will be lengthening the runners which aids to mid range power
You'll have to shorten the runners by chopping and rewelding the MEVI if you want more top end power. Hence the variable nature of the MEVI and DE-K IM's are so beneficial
Old Feb 3, 2006 | 10:42 PM
japmaxSE's Avatar
Go Get a Life!
Yes it was me I had it done well almost. I took the butterfly's out turned it into something like the kenetics one in reverse (short runners). I had mad vacuum leaks were I had some spot welds in some spots of the TB mounting area. Honestly I have no idea what kind of power to expect but it sure had way more low end then top end. Now it sits in a box, until I figure out what other car to put it in. I would take pics but I think I'm on to something well for another type of manifold not for the VQ . I wish not to reveal yet.
Old Feb 3, 2006 | 10:48 PM
japmaxSE's Avatar
Go Get a Life!
Damn you guys are on the right track as far as the spacer goes.
But the prob is there isn't enough area to actually gain. Such as the one for the 350Z has a much wider range of added area which results for more noticble power. I doubt your going to see any gains from the spacer. Been there done that but my MEVI was totaly differebt than a stock MEVI. It wouldnt hurt to try tho.
Old Feb 4, 2006 | 06:35 AM
nismology's Avatar
A worthwhile modification would be to make the butterfly valves sit flush with the runners. That little existing space is what causes the turbulence and lowers mid-range torque.
Old Feb 5, 2006 | 09:31 AM
zander's Avatar
Has anyone relocated the butterflys? I tried searching but it didn't really help. Also, has anyone used an electric motor to open the butterflys, as opposed to the vacuum method? I noticed the butterflys will open quick but they don't disengage quick enough, so if I'm hitting red line in a couple gears its basically open all the time.
Old Feb 5, 2006 | 11:08 AM
Hoooper
its likely to be open all the way anyway because your rpms wont drop below into where it is closed.
Old Feb 5, 2006 | 03:06 PM
GodFather's Avatar
Made in Taiwan
adding spacers to the upper manifold will raise the hight, but egr connection wouldn't match up right. also, the 2 supporting brackets behind the manifold wouldn't be able to catch at the right hight. did you guys overcome these problems, how? also, coolant routes may have to be extended, but it's no big deal. but i really would like to know how to match the supporting brackets and the egr spots.
if you just ghetto fit it altogether, then the manifold would sit somewhat of a slant to the back. i really don't like that idea. makes me wonder...
Old Feb 5, 2006 | 06:25 PM
vsamoylov
sell mevi get vi and dont waste any more time and money
Old Feb 5, 2006 | 07:02 PM
GodFather's Avatar
Made in Taiwan
i agree, but now with VI available, who's going to buy mevi? if so, it'll be sold at a pretty low price, then we lost too much. it's about giving up and getting new stuff. Worth???
I would go with the new VI, but wouldn't want to just waste MEVI like that. That's why I am also interested in redo-ing Mevi for a tweaked performance.
Besides, Mevi with JWT cams gives no low end torque whatsoever. It's more like driving a honda civic. But it supports high ends like crazy. Even with a 00VI, I really would like to tweak and keep this mevi to see what I can do to juice it up. And sentimentally, it's actually what got me started with modding my car.
Old Feb 6, 2006 | 07:04 AM
japmaxSE's Avatar
Go Get a Life!
Everything is custom made, I know I couldn't tell you exactly how to mod your MEVI because it's just to detailed and it would come down to how your going to alter it yourself. There are so many different ways so many different designs you can make up. I started off trying to help make the MEVI better ended up with a completely different design.
Old Feb 6, 2006 | 07:13 AM
Ninos_Maxima's Avatar
be the change u want2C
SECRET SAUCE!!!
Old Feb 6, 2006 | 08:55 AM
zander's Avatar
I wanna see this super special MEVI, I hear about it all the time, but no hard facts...
Old Feb 6, 2006 | 09:25 AM
hacim105's Avatar
It's actually not a MEVI but a the 3.5 VI that was made special.
Old Feb 6, 2006 | 04:57 PM
the guy wont share...
Old Feb 6, 2006 | 05:07 PM
GodFather's Avatar
Made in Taiwan
what's your point? it's his business and his decision. live with it.
Old Feb 6, 2006 | 07:34 PM
nismology's Avatar
This is exactly what i felt like saying. He has no obligation to anyone on this site to share his secret. That's like expecting technosquare to hand over the code they use in their ECU upgrades.
Old Feb 7, 2006 | 12:47 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
If you saw the manifold you would know what he did. I haven't even seen it or talked with him in depth about it and I know what it is. If you can't figure it out for yourself, then you shouldn't be attempting it. 2 other guys on the board, Stephen Max and Tilley figured it out too. They removed their posts out of respect for Matt.
