Motor Prep
Motor Prep
Well im about to put in a slightly newer vq30 in my 4th gen, and was wondering what kind of things I should do to the motor itself before I put it in. I have already took off the headers to clean up a bit and same with intake manifold, throtlebody, and valve covers. Anything else I might want to do?
I was thinking of removing the EGR system, also I would like to get some large pipe cleaners and put them on the end of a high speed drill and clean the intake manifold. As for pulgs, filters, hoses, ect, I had that in mind. Just wanted to get strickly motor related things that would improve performance and such.
you either dont' do any performance prep or do it all at once. Doing a few mods won't get you satisfied if you want performance. So before the motor goes in, you either go the whole 9 yards or don't walk the road at all. That's just my suggestion. I went 10 yards before I finally dropped the VQ in the bay.
Listen to Godfather - he knows what he's talking about.
I'd remove the EGR altogether (if emissions laws permit), replace headers, 00vi lower/upper/290ccinjectors swap, Adj. FPR, cams, new tensioners, 3 angle valve job, and change the Clutch/ and cryo tranny gears. Install polyurethane motor mounts too.
And afterwards drop it the engine. It is so MUCH easier to work wen the engine is OUT! (i did my mods with engine in the bay -- PITA!!!)
Thats the way im going with this project. I have a NEW 5 speed VLSD tranny, 5th gen clutch, pressure plate, SS clutch line, throwout bearing, slave cylinder, ect. As for 00VI i was thinking about it but havent tracked down all the parts yet, so that might be a down the road kind of thing, and the headers im not willing to spend the money on right now if im not FI or going with the 3.5 swap. I have been toying with some 3.5 or FI setups but thats for another thread.
Originally Posted by nismology
Why not suggest high-compression pistons, nismo oil pump and extrude honed manifolds while you're at it??
Originally Posted by Larrio
depending on the mileage of the motor, maybe a new water pump and VQ35 oil pump also
Well here it is, I blew my tranny, bought a new one, also found a good motor for a great price bought that too. Snice I had no car and winter was coming soon in CT I bought a 4x4 "my truck". Now I want my car running so Im putting in the vq30de and new trans. Ive been looking for a 3.5 around New England but cant find one at a good price, when I do Ill be going all out. But untill then I just want my car back on the road.
www.car-part.com
If I can find a relatively cheap one around Montreal, anyone can, even if you hypothetically lived in some ultra-backwoods-redneck state.
Ive found alot of good stuff on car-part, and after just taking a look I found one not to far away for $800 with 65k. I think my next day off Ill be in Southington, maybe buying a 3rd motor.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
