Sponsored by:
Sponsored by: CARiD
tranny fittment?
Old Feb 6, 2006 | 11:35 PM
chris'smax's Avatar
tranny fittment?
Would a 2002 5 speed bolt up to a 2000. I am doing a 5 speed swap eventually and it seems you can get the 2002 5 speeds for cheaper w/ less miles than the 2000.
If the 2002 does bolt up then i would have to use the 2002 shift rod linkage and shifter assembly?
Old Feb 6, 2006 | 11:37 PM
A33 VQ30DEK's Avatar
you mean 2001 5 spd or 2002 6 speed.
the 2002 6 speeds don't use shift rod linkeage.. they use cable lines.
Old Feb 6, 2006 | 11:39 PM
chris'smax's Avatar
Well i thought the 2002-03 only came in a 6 speed manual, but i was just looking on car-part.com and they have a few 5speeds listed under the 5.5gen year modles
Old Feb 6, 2006 | 11:48 PM
then they are wrong. All 5.5 gens are 6 spd.
Old Feb 6, 2006 | 11:49 PM
chris'smax's Avatar
ahhh ok. well then i guess that answers that question
Old Feb 7, 2006 | 04:31 AM
SonicDust187's Avatar
However the 2002 Altimas have a 5spd with the 3.5 motor. And I think they are shift rod operated.
Old Feb 7, 2006 | 05:03 AM
s0ber's Avatar
the altimas are cable as well :\
Old Feb 7, 2006 | 07:29 AM
vsamoylov
ypu like everybody said the 5.5 gens are either auto or 6 speed and the 6 speed are cable operated. the cables hook up to the shifter assembly which directly bolts to the floor.
Old Feb 7, 2006 | 12:02 PM
SPiG's Avatar
SomePsychoGuy
Just about every FWD Nissan tranny from 2002+ is cable shift. The 02+ Maxima 6 speed also has a different mount setup. They are stronger, but from what I have heard it is not an easy install to say the least.
Old Feb 7, 2006 | 12:06 PM
vsamoylov
dont mean to bash on you but the info on the install of a 6 speed mount is very simple. it is bolted to the frame with 2 bolts instead of being welded like the older 5 speed mounts. remove the spot welds on the 5 speed mount, remove the mount, grind and make sure the surface is clean, drill 2 holes and bolt on the mount. if that is not a easy install then what is?
Old Feb 7, 2006 | 01:56 PM
chris'smax's Avatar
What is the problem w/ the 6 speed install? isn't it something w/ the flywheel?>
Old Feb 7, 2006 | 02:14 PM
OOmaxSE's Avatar
I wouldn't say they're WRONG... But maybe we're not considering the fact that there is a 5spd tranny for 2002... 'cept it's AUTO.
Old Feb 7, 2006 | 02:26 PM
SPiG's Avatar
SomePsychoGuy
I suppose that is not the hard part then, but the 2-3 people who have done it said it was too much work and not really worth it. I think tilley was one and maybe someone at NRH or somthing.
The flywheel and clutch are different and weight almost 2x as much as the stock 5 speed.
Old Feb 7, 2006 | 04:20 PM
maxS
i did the swap and it was difficult and for some peopel it is worth it. ok and what are you tring to prove about the weight difference?
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
