Sponsored by:
Sponsored by: CARiD
G35 Manifold fitment issues
Old Feb 27, 2006 | 10:20 PM
tavarish's Avatar
fwd gone rwd cr00
Hey, i'm doing my 3.5 swap soon, and I can get a good deal on a G35 manifold (upper and lower) for $200. Does anyone know by how much the hood wouldn't clear?
I'm thinking about either using hood spacers or grinding down the hood frame, or both.
I don't really want to use a hood scoop, but I might have a custom hood setup if the fitment is way off.
Let me know, i'm interested in doing it, as the G35's and Z's make so much more HP, and if I add a plenum spacer, even more. I think sacrificing the hood would be worth it.
-Freddy
Old Feb 27, 2006 | 10:43 PM
1FSTMX
Measure the manifold height of both a G35 and your maxima. Go from there.
SEmy2K2go's Avatar
Go BUCKS!!!
Why don't you just post with your other username, El? Instead of post whoring with a new one?
Old Feb 28, 2006 | 07:59 AM
tavarish's Avatar
fwd gone rwd cr00
question's still not answered, and I don't know anyone with a 3.5 or G35.
I looked at a few threads, and no one really said by how much it didn't fit, and since i'm using both the upper and lower, bolting on wouldn't be an issue.
bump.............
Old Feb 28, 2006 | 10:06 AM
l3ftonm3's Avatar
since i dont think anyone has done this yet, your going to have to measure it and see for yourself. I say take the plunge could always resell them. But you would have some bragging rights if you were the first 3.5 4thgen with both manifolds and a spacer. I drool over this setup.
Old Feb 28, 2006 | 10:25 AM
maxmale's Avatar
umm, i hope you can get this to work, i'd be interested in this as well.
Old Feb 28, 2006 | 10:32 AM
il99max's Avatar
A little off topic, but I think Nismo3112 is going to be experimenting with something similar. I think in one of his posts he had gotten his hands on a 350Z intake plenum. I didn't think it was possible to swap the intake manifolds off of rwd cars (Z, G35) with a 4.5 gen.
Old Feb 28, 2006 | 10:40 AM
Jeff92se's Avatar
I'm needing a caw
I guess it depends on what G35. The 03-04 are rated at 260hp.
-Freddy
Old Feb 28, 2006 | 10:43 AM
Jeff92se's Avatar
I'm needing a caw
I guess it depends on what G35. The 03-04 are rated at 260hp. And from the dynos I see here, the 3.5 maxima seems to be dynoing at around the same #s.
The 05+ Gs and Zs depending on the model, some got the rev up engine and VTCs on the exhaust as well as the intake cam? So that's where the extra hp comes from?
-Freddy
Old Feb 28, 2006 | 11:48 AM
tavarish's Avatar
fwd gone rwd cr00
it says the 03 G35's are rated at 280hp.
http://www.edmunds.com/used/2003/inf...767/specs.html
Also, the FX35 manifolds would be the same, correct, as they're also the RWD 3.5's rated at 280hp.
i can't afford the 300hp version, and it's super hard to find.
i don't think the fitment would be that much of an issue, and maybe i'll pay a visit to my local nissan dealer and take some measurements.
Old Feb 28, 2006 | 11:53 AM
Jeff92se's Avatar
I'm needing a caw
03 autos were rated at 260. I'm not sure if the auto/manual manifolds were diff. I've not seen any manifold differential disscussion on the G boards UNTIL the 05 6MT rev up engine (298hp) is mentioned. Slightly diff lower (lower of the 2 upper pieces) portion.
But even then, the G/Z manifolds seem to suffer from 3 front bank leaness. Thus the invention of aftermarket plenums and spacers.
Also from the limited info I've seen, the 3.5 maximas and the 03-04 G sedans seem to dyno similar.
Old Feb 28, 2006 | 12:00 PM
tavarish's Avatar
fwd gone rwd cr00
ahh....i see what you mean, the sedans were rated at 260hp. the coupes were 280. i doubt there were any real manifold changes, but i'll do my research, as i still have lots of time for this setup.
Old Feb 28, 2006 | 12:27 PM
Nismo3112's Avatar
Custom User Title
I got plenums from a 287 hp Z. I will let you guys know how it turns out once Spring break comes around the corner.
Here is a quick comparo between the 300hp version of the plenum (left) and the 287hp version. I have seen dyno's where the 287 version actually has more area under the curve.
Old Feb 28, 2006 | 12:49 PM
tavarish's Avatar
fwd gone rwd cr00
very cool, i'll be looking forward to doing this...maybe we can start a club of maximas with weird hoods.
If hood clearance is really an issue, you can most likely make a fiberglass hood with a bit of a flare, not a scoop, but just an accenting flare. It wouldn't look too much different from stock.
Or, if you want to keep the stock hood, i was thinking you can just use some hood spacers (like some Z guys do), or add washers to the bolts in the crossmember, lowering the engine. (I dont know how safe that would be, however. )
Old Feb 28, 2006 | 12:52 PM
Jeff92se's Avatar
I'm needing a caw
The Rev up lower has shorter runners for more high end power. But at a loss of low end torque.
Old Feb 28, 2006 | 01:26 PM
diymaximakid's Avatar
well if you did a hood scoop you would have kinda intake manifold intercooler type thing.thats a plus to that.but nismo how high is the manifold from top to bottom
Old Feb 28, 2006 | 01:48 PM
chris'smax's Avatar
I cant wait to try out one of these manifolds. I think i may sneak in the garage tonight and gank the IM off my moms G35
Old Feb 28, 2006 | 02:09 PM
Hoooper
im guessing part of the reason the g35 dyno's about the same as a max is parasitic loss. being that a g is rwd, they probly have a higher parasitic loss which would explain the dynos being closer than expected.
Old Feb 28, 2006 | 02:34 PM
vsamoylov
nismo3112 quick question. i nthat pic that you have posted is that the lower and upper plenum from a 350z/g35? also which lower part of the plenum are you going to use? The reason for that question is that the revup plenum is good for top end but the regular plenum is good all around the curve. if you want serious top end you want to use the revup version. if you are going to use the regular version get a spacer and call it a day.
and about the hood clearance, that is nto a big problem. Just get a scoop and cut a hole in your hood.
Next is the placement of the tb. It will face the other way and the highest point is the tb and the part of the plenum next to the tb. So the piping will have to run towards the coolant overflow tank.
also did anybody notice that the front valve cover is different as well?
here is a pic of a photoshop i did.
Old Feb 28, 2006 | 02:55 PM
Nismo3112's Avatar
Custom User Title
[IMG]http://img.photobucket.com/albums/v720/vsamoylov/DSC00961.jpg[IMG]
Im not sure if it was from a Z/G, but I am using the standard 287hp version. I am going to see how the plenum sits and then decide if I will get a spacer or not.
Old Feb 28, 2006 | 02:57 PM
vsamoylov
what lower are you using? injectors?
Old Feb 28, 2006 | 03:02 PM
Nismo3112's Avatar
Custom User Title
Here are some pics I snapped:
And this is top to bottom including the lower.
Old Feb 28, 2006 | 03:05 PM
Nismo3112's Avatar
Custom User Title
350Z lower. It is very different from the 5.5 gen lower, it also looks like the 5.5 gen fuel rail will bolt on, but i'm not sure, I will know for sure in a few weeks when I start the project.
BTW, I will be using DE-K injectors.
Old Feb 28, 2006 | 03:40 PM
nismo,im gonna keep in contact with you.I'll prob be attempting this the same time you will be.
Old Feb 28, 2006 | 04:09 PM
tavarish's Avatar
fwd gone rwd cr00
why not use the Vq35 injectors?
vsamoylov
maxima and 350z are different
Old Feb 28, 2006 | 04:10 PM
chris'smax's Avatar
They are the same
Old Feb 28, 2006 | 04:32 PM
no not true completely. dek and rwd injectors are the same and fwd maxima injectors are different.IIRC
Old Feb 28, 2006 | 05:15 PM
Nismo3112's Avatar
Custom User Title
Exactly. This way I can flow more fuel without touching the fuel psi vs. running stock VQ35's.
DE-K injectors = more fuel than FWD 3.5 jectors at the same given fuel psi.
Old Feb 28, 2006 | 05:19 PM
vsamoylov
so when is spring break?
Old Feb 28, 2006 | 05:29 PM
SR20DEN's Avatar
VQ Wizard
I see someone already dug up the old Emax thread from the grave.
Yes this was attempted about four years ago and the hood does not clear.
However I am going to be testing one on the dyno soon now that I finally got my car back from the body shop.
Old Feb 28, 2006 | 06:39 PM
Nismo3112's Avatar
Custom User Title
Mine starts the 11th.
Old Feb 28, 2006 | 06:40 PM
Nismo3112's Avatar
Custom User Title
I am just going to cut the hood where need be, and let it stick out of the hood. And if it doesn't look too outrageous i'll keep it like that.
Old Feb 28, 2006 | 06:41 PM
vsamoylov
that would remind me of that dude that has the vq30 in his 240sx. his im wouldnt clear either so he cut a hole in the hood and he drives it like that. summer is comming anyway.
Old Feb 28, 2006 | 07:32 PM
SR20DEN's Avatar
VQ Wizard
And extend the TB wires @ MAF wires?
Old Feb 28, 2006 | 07:46 PM
Nismo3112's Avatar
Custom User Title
Yeah. This won't interfere with the MAF and TPS output voltages will it?
Old Mar 1, 2006 | 07:32 AM
tavarish's Avatar
fwd gone rwd cr00
i hope not...
Old Mar 1, 2006 | 07:45 AM
Larrio's Avatar
The Definitive AE Master
well, solder supposedly adds resistance to the electrical current. (IIRC)
Old Mar 1, 2006 | 08:14 AM
tavarish's Avatar
fwd gone rwd cr00
what about crimp connectors?
Old Mar 1, 2006 | 09:12 AM
Nismo3112's Avatar
Custom User Title
Well I just read in a few different past threads that you shouldn't have a problem with extending the MAF wires as long as you use the same or larger guage wire with low impedance.
