Sponsored by:
Sponsored by: CARiD
Apexi AFC information needed
Old Mar 1, 2006 | 05:40 PM
03maxima1's Avatar
I want to get one of the Apexi AFC’s but don’t want to rush into another expensive mod without some research. After you install this unit and tune it, does the car remember the settings. Or will the controller loose the settings if you reset the ECU, unplug the battery, etc. and then have to tune it again. I am sure this might be an elementary question to some but I really want to learn how this works before I get it. Can someone help me understand how the above works?
Old Mar 1, 2006 | 05:46 PM
steven88's Avatar
Need A Light?
Naw the unit will not lose memory....so don't worry about it getting erased or deleted
its $250 or so on ebay...another $100 or so tuned....depending on what your AFR looks like, you will gain some hp....I suggest you drop in money into this AFC if you plan to get headers...it will be worth it
Old Mar 1, 2006 | 06:05 PM
03maxima1's Avatar
I have Headers thats why I was looking into this. So your saying tunning shold not cost more then $100 and you only need to do it one time unless other motor mods are done? I thought it would be alot more.
Old Mar 1, 2006 | 06:08 PM
steven88's Avatar
Need A Light?
which kind of headers do u have? and what other mods?
$100 is just an estiimate...i know it varies from shop to shop....my local one over here charges me $150/hr for tuning....I just threw that $100 cuz I believe its the "average" # I have seen....
Yeah it should only require once....if the shop is good enough, they will get the AFR to 13.0-13.5:1
Old Mar 1, 2006 | 06:26 PM
03maxima1's Avatar
Injen CAI - HotShot - Greddy
Was it worth it after you tuned it?
Old Mar 1, 2006 | 06:30 PM
steven88's Avatar
Need A Light?
I haven't gotten it tuned....its just sitting on my dash hooked up and everything...right now it's just a light show....I'm waiting till spring break to get it tuned...I know for sure I can squeeze HP out of this mod....I get 3hrs on the rollers and I'm tuning it myself....so the AFR will be flat...best believe dat homeboy....get cho' shine on!
Old Mar 1, 2006 | 06:55 PM
jmeister's Avatar
3hrs at $100-150 an hr. Made of money?
If it takes you any longer than an hr you have problems.
Old Mar 1, 2006 | 07:02 PM
steven88's Avatar
Need A Light?
actually $50 for 3hrs...the dyno shop hooks my homie up...
and if I can get my AFR flat within 10 minutes...then ****, it will only be a few bucks....
Old Mar 6, 2006 | 02:20 PM
Chief Brody's Avatar
You could also get a wideband for around 250 and tune that baby yourself.
Old Mar 6, 2006 | 04:55 PM
aznsap's Avatar
any recommendations for a wideband? and what other equipment would you need to tune it yourself? (laptop and software?)
Old Mar 7, 2006 | 08:06 AM
Subzero's Avatar
What kind of horsepower will a 99' a/t with bolt ons attain? And do you know what the factory a/f is, don't they run pretty rich? I just want to know if it is worth the money, don't want to spend that much for 5 hrpwr.
Old Mar 7, 2006 | 08:28 AM
Puppetmaster's Avatar
I think the best way to figure this out is to get a dyno with AF and see if you even need to adjust the maps. Every car is different, esp when you consider the effects of different bolt-ons. I actually haven't heard of 4th Gens needing AF adjustment too badly, it is typically the 5th/5.5 Gens with the screwed up AF.
smplyamzng
Dec 13, 2015 01:19 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
TonyJr
Aug 20, 2015 12:14 AM
Hawkeye61
Aug 12, 2015 06:45 PM
Team STILLEN
Aug 10, 2015 04:29 PM
