Sponsored by:
Sponsored by: CARiD
Need VI assistance stat please..
Old Mar 2, 2006 | 07:00 PM
gtr_rider's Avatar
Alright, basically im installing a VI and I need some help with all the vacuum and fuel lines on a 95 Fed spec.. Also I am confused on what to do with the coolant lines.
Here is some video of how it is setup currently, any insight please...
http://www.vqpower.com/tmp/PICT0208.avi
Old Mar 3, 2006 | 05:11 AM
Curt's Avatar
BEFORE YOU START.......as you disconnect each and every electrical, vacuum, coolant and fuel hose, sequentially number and tag/label it as to where it went and what it was connected to. It's a generally idiot-proof way of making sure you get everything properly hooked back up, with the emphasis on "everything" and on "properly."
Then again, there are those guys who can do this kind of stuff with their eyes closed in a dark place after a six-pack! They can (and I'm sure will) ignore this suggestion.
Old Mar 4, 2006 | 12:38 PM
gtr_rider's Avatar
Everything was set properly, and car is screaming of fury
Old Mar 4, 2006 | 12:46 PM
Jason R's Avatar
aka UNCDooD
oh my. hopefully mine will be screaming well above the stock redline this evening as well.
Old Mar 4, 2006 | 03:48 PM
gtr_rider's Avatar
Its really not that hard to comprehend when installing, just need to check and double check EVERYTHING, sometimes even triple check. Good luck
Old Mar 5, 2006 | 08:04 AM
speed racer's Avatar
If you don't mind me asking but what parts did you use and which portion of the install you found the most difficult. I'm gathering all the parts now and will do this in the spring.
Old Mar 5, 2006 | 08:25 AM
gtr_rider's Avatar
00 Fuel rail, 00 injectors, 00 valve cover, 00 EGR guide tube, 00 manifold, 00 coil packs. The most difficult part of the install would have to be removing the old EGR guide tube because of where it sits.. After that its cake, also make note of EVERY hose you will be removing, as you will be completely confused afterward.
Old Mar 5, 2006 | 08:46 AM
Curt's Avatar
Originally Posted by gtr rider
........also make note of EVERY hose you will be removing, as you will be completely confused afterward.
Like I said-
Guys don't want to believe me. They're the same guys who have to pee on the electrified cattle fence to find out for themselves!
Old Mar 5, 2006 | 09:26 AM
VQuick's Avatar
Chassis Freak
Refresh my memory...the rear valve cover has to be a DE-K valve cover or can it work with the DE rear VC? And if you decide to use DE-K injectors are DE-K coil packs required? Thanks.
Old Mar 5, 2006 | 10:43 AM
DandyMax's Avatar
3.5 in the works
Ah bringin back memories. That first test drive after the swap is very nice isn't it..
Old Mar 5, 2006 | 04:32 PM
gtr_rider's Avatar
Not necessarily, you can use the stock DE rear VC but you will need to shave down the two front ignition coil posts(closest to Throttle body) so that the manifold can sit properly. As for the DE-K injectors and coil packs, you can interchange the DE and DE-K coil packs because they are pretty much the same thing. As someone said in another thread, a coil is a coil is a coil. (Ie. I am using two DE-K coils, with a DE coil)
Old Mar 5, 2006 | 04:35 PM
Jason R's Avatar
aka UNCDooD
awesome. mine cranks and cranks but won't turn over.
Old Mar 5, 2006 | 04:52 PM
gtr_rider's Avatar
did you give vaccuum too all the ports on top of the mani? and also check your ground.
Old Mar 5, 2006 | 05:08 PM
Jason R's Avatar
aka UNCDooD
yea, all ports on top of the manifold are getting vacuum. i think my ground might be an issue. where did you ground your's to?
Old Mar 5, 2006 | 06:15 PM
gtr_rider's Avatar
I used part of my grounding kit to ground it to the timing chain. When ground wasnt applied the car wouldnt even prime *in acc*
Old Mar 5, 2006 | 06:22 PM
nismology's Avatar
To the timing chain??
Old Mar 5, 2006 | 06:23 PM
Jason R's Avatar
aka UNCDooD
its running now but idling really rough. gonna go retry some vacuum lines right now.
Old Mar 5, 2006 | 06:36 PM
gtr_rider's Avatar
LMAO, timing cover..
Old Mar 5, 2006 | 06:37 PM
gtr_rider's Avatar
did you make the plate for the IACV, and also did you get the relocation kit or adjust the idle speed to compensate for no IACV?
Old Mar 5, 2006 | 06:49 PM
Jason R's Avatar
aka UNCDooD
yea i got the IACV adapter plate from Stephen Max
Old Mar 5, 2006 | 07:12 PM
Cool. I remember when I was cleaning my egr guide pipe of how dificult it would be to remove the large egr pipe. I think I recall in the past of people using a crowfoot to unloosen it. I'm thinking of fabricating the plates but that depends on money and time. I think Stephen max makes it so that the plate goes behind the TB and connects to the existing 4th Gen IACV. If not its goning to be a remote location.
Old Mar 5, 2006 | 07:14 PM
gtr_rider's Avatar
Sorry i meant the plate for the throttle body, for the 00VI if that is what you are using
Old Mar 5, 2006 | 07:19 PM
Jason R's Avatar
aka UNCDooD
yea, got the PF TB adapter plate from him too.
Old Mar 5, 2006 | 07:54 PM
gtr_rider's Avatar
COuld you send me a picture of the IACV plate?
Old Mar 5, 2006 | 08:16 PM
Jason R's Avatar
aka UNCDooD
i'm actually in for the night so it'll have to wait until tomorrow evening. but it looks just like the ones on the cars Stephen Max has done.
Old Mar 6, 2006 | 07:15 PM
JamesNH's Avatar
gtr_rider you still runing the stock rev limit?
Old Mar 6, 2006 | 07:25 PM
vsamoylov
not true. the part that is true is yes they are all coils but the part that isnt true is that they are the same. yes they will plug in but the resistances is different but i wont get into electrical with you guys
Old Mar 6, 2006 | 07:33 PM
gtr_rider's Avatar
Yes, I am..
If the glove fits..
Old Mar 7, 2006 | 06:07 AM
Kevlo911's Avatar
Kevlo for President
How did you find out that the resistances are different? The FSM shows the same stuff for the 4th gens and 00
Old Mar 7, 2006 | 08:32 AM
gtr_rider's Avatar
Hey you have any IACV plates?
Old Mar 7, 2006 | 08:51 AM
Kevlo911's Avatar
Kevlo for President
Nope sold last one a while back. I'll see if I can find one
Old Mar 7, 2006 | 08:55 AM
gtr_rider's Avatar
Hotness.. LMK
Old Mar 7, 2006 | 11:02 AM
vsamoylov
what happens when you hook up a 3.5 coil on a vq30? missfire. so the statement of a coil is a coil is a coil needs to be revised.
Old Mar 7, 2006 | 11:35 AM
gtr_rider's Avatar
Who in the world is talking about 3.5 Coils...? Seriously, slow down.
Old Mar 7, 2006 | 11:50 AM
s0ber's Avatar
IB
10char..
Old Mar 7, 2006 | 12:23 PM
Kevlo911's Avatar
Kevlo for President
Who said we were talking about 35 coils?
Plus the 35 coil are ALOT shorter than the 30 coils IIRC.
Old Mar 7, 2006 | 06:28 PM
nismology's Avatar
Seriously though...wtf did he get 3.5 coils from?? lolz
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
97_GXE
20
Sep 17, 2015 08:12 PM
Maxxx10
Sep 13, 2015 03:16 PM
