Sponsored by:
Sponsored by: CARiD
2k2 VI control options
Old Mar 2, 2006 | 07:11 PM
Charcoal95GXE's Avatar
From some reading i did, and im pretty sure it was (Meximax? )that posted the initial thread, about leaving the 02 Vi open from 0-4k closed till 5.5ish then open back up. What is going to be the most cost effective way to control the VI? is all im getting at.
-brian
Old Mar 3, 2006 | 06:43 AM
SonicDust187's Avatar
Emanage would be simple but expensive, however having two window switches would do the same thing and very cheaply.
Old Mar 3, 2006 | 08:32 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You don't need two RPM switches....
The MSD 8969 has a normally closed wire also, which "will remove the ground source at your desired ON rpm and complete the ground circuit at the set OFF rpm.".
I've seen these around in Classifieds for $70ish.
Old Mar 3, 2006 | 08:37 AM
IceY2K1's Avatar
Also, if you have the older "pill" version RPM switch, you just add a relay to do the same thing.
Old Mar 3, 2006 | 10:25 AM
How hard should window switch install be? should just be one wire off of the ecu, correct?
Old Mar 3, 2006 | 10:34 AM
IceY2K1's Avatar
Power, ground, tach, output wire(s).
http://www.msdignition.com/pdf/8956_frm24819.pdf
http://www.msdignition.com/pdf/8969_frm25515.pdf
Old Mar 3, 2006 | 11:58 AM
Glude's Avatar
Wouldnt leaving it open just cause a tremendous loss of low end tq? Ive heard its not worth doing because of that reason.
Old Mar 3, 2006 | 12:05 PM
IceY2K1's Avatar
Not per meximax's dynos.....
http://forums.maxima.org/showthread....highlight=dyno
Old Mar 3, 2006 | 12:35 PM
Glude's Avatar
Thanks for the link, I didnt notice that the first time I looked at that thread.
Old Mar 4, 2006 | 06:54 PM
SR20DEN's Avatar
VQ Wizard
This oddity of his isn't useful on the car it was designed for. Try it anyway and you will see.
Old Mar 4, 2006 | 07:45 PM
nismology's Avatar
Because of the VTC system im guessing? Makes sense.
Old Mar 4, 2006 | 08:05 PM
SR20DEN's Avatar
VQ Wizard
Pretty much. But either way his results make no sense to me.
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
