Sponsored by:
Sponsored by: CARiD
VAFC-II setup template
Old Mar 12, 2006 | 09:36 PM
SR20DEN's Avatar
VQ Wizard
It has come to my attention that some people could use a little extra help when setting up the VAFC-II for the Maxima. Many are following my recommendations for getting it over the SAFC-II, which I find encouraging, but I suppose I need to clarify more of the details.
The reasoning for getting the V over the S really has nothing to do with it's 'vtec control' or in our case 'rpm switch'. That part isn't a direct wire setup anyway. And it certainly would have nothing to do with attempting to control the VTCs on the VQ35, as some mistakenly suspect.
It's really all about the NE points for setting up the fuel corrections. The SAFC-II has a twelve point by two point map (12x2) which means you can setup 12 rpm points throughout the rev range and 2 throttle points for correction. Anything in between your specified RPM and throttle points is interpolated . The SAFC-II can also be manually switched to a second data file or map to be used with Nitrous or some other more or less aggressive tuning parameters you might need.
The VAFC-II essentially uses both of these 12x2 maps together, effectively making it a 24x2. But it has to be triggered to select between these two maps by a Hvt and Lvt setting (12x2 high vtec, 12x2 low vtec).
Now for the example setups:
So for most of these cars that can only rev to 6500 or 6600, we would set the Lvt to Hvt setting at 4200rpm and the Hvt to Lvt at 4100 (for some reason it wont let you make them the same). Doing this means that the VAFC-II will switch over from one 12 point map to the other 12 point map at 4200rpm. Now you'll need to setup the Lvt NE (RPM) points, obviously you'll want to end the Lvt points at or before 4200rpm because that is where you just set the crossover. If you set Lvt points past your crossover point they just go to waste and you won't make use of the full 24. A good selection would look something like this:
Lvt 1200,1600,2000,2400,2600,2800,3000,3200,3400,3600, 3800,4000
Hvt 4200,4400,4600,4800,5000,5200,5400,5600,5800,6000, 6200,6400
If you have some A/F problems at the crossover point you may need to adjust those settings. I don't think the VAFC-II will interpolate between the Hvt and Lvt maps.
Notice I have listed settings as low as 1200rpm, this isn't really usefull to everyone but those with larger MAF sensors or larger injectors can make use of the low rpm/low throttle settings to keep the ECU fuel trims in check (they really need to be as close to zero as possible).
As for the wiring setup, keep in mind that the VAFC-II only has settings for MAP sensors, but it still needs to be wired to your vehicles MAF sensor. And for display purposes I generally use the setting of +15psi, which does not give by any means an accurate display of air mass flow or MAF voltage, it does somewhat put the MAF output into some discernible perspective. It's also cool to show off to your friends, and those who think you have forced induction anyway.
I realize there is still much left out here but I'll try to answer the questions as they arise. I don't have a VAFC-II to look at, so I am having to do this from memory.
Old Mar 12, 2006 | 09:43 PM
steven88's Avatar
Need A Light?
Just letting you know...I'm running the following INITIAL SETUP settings
1 in & 1 out, 6 cylinder, up right arrow, vtec type 1
no problems so far...anybody else running diff settings?
Old Mar 12, 2006 | 09:45 PM
Nismo3112's Avatar
Custom User Title
Nice writeup. It definitely answered my questions about the VAFCII.
Motion for sticky
Old Mar 12, 2006 | 09:46 PM
Nismo3112's Avatar
Custom User Title
Yeah, what do these settings mean anyways? (besides the V6 part)
Old Mar 12, 2006 | 09:52 PM
steven88's Avatar
Need A Light?
I really don't know...well I know the up-right arrow means something about the TPS voltage...u can test it out manually to see where your at...but from what I know, all maximas have this same voltage...so u pick the up right arrow...
dunno too much about the 1 in and 1 out....and vtec type
Old Mar 12, 2006 | 11:13 PM
rchun08's Avatar
want to wire either a vafc or safc to the sunglass holder...will the wiring for a vafcII reach there? i know they safcII is about 7 feet long...how long do you think the wiring is for the vafc..you think the wiring can be easily made longer
Old Mar 12, 2006 | 11:19 PM
steven88's Avatar
Need A Light?
when I measured my VAFCII....it barely reaches the sunglass holder...but I didn't completely stretch out the wires...I'm sure it would reach if you tried hard enough....
others say it won't reach...but this is from MY personal experience with MY VAFCII....take your pick
Old Mar 13, 2006 | 05:12 AM
SR20DEN's Avatar
VQ Wizard
The last two installations I dealt with would not reach.
Old Mar 13, 2006 | 10:09 AM
d00df00d's Avatar
Old enuf to pick his own gears
Originally Posted by Nismo3112
Motion for sticky
I second that motion, especially if even more info is to come.
Old Mar 13, 2006 | 12:05 PM
rchun08's Avatar
ok...glovebox it is!!
Old Mar 13, 2006 | 02:56 PM
hightuner's Avatar
Nissan maniaco conpulsif
Thanks you
Old Mar 14, 2006 | 02:51 PM
vsamoylov
interesting info
Old Mar 15, 2006 | 01:22 AM
mjk's Avatar
mjk
Head shot!!!
I will definately be posting once mine arrives. thanks for the effort man
sticky sticky sticky
Old Mar 15, 2006 | 07:59 AM
Deckdout2's Avatar
Play with my balls
I have Haydn's manual still if you wanna look at it for more info Matt, or you can play around with mine for the other functions and features.
Here's where mine is mounted. Perfect, and I can still see the clock.
Old Mar 15, 2006 | 06:48 PM
jmeister's Avatar
The in & out settings have to match & that's as much as I know about those. Have mine set at 4. On the VAFCII the vtec type should be set at med to use it as an RPM switch for the VIS. The VAFC will not actuate the VIS, known from personal headaches & wasted $... VAFCII on the way
Nice write up, where were you last year about this time
Here's where I mounted mine
Old Mar 16, 2006 | 10:36 AM
mjk's Avatar
mjk
Head shot!!!
Do we just wire it up per the instruction booklet, I'm asking because all I saw was a bunch of honda examples. thanks
Old Mar 19, 2006 | 06:00 PM
NashCar's Avatar
So I'm a little confused. Maybe I just missed it somewhere. How exactly does this work with a MAF sensor if its made for a MAP sensor?? Like, how does it measure how much air is comming in?
Old Mar 19, 2006 | 06:19 PM
SR20DEN's Avatar
VQ Wizard
It knows nothing about air. All it sees is an input voltage which it translates to a different voltage based on your settings per thottle (voltage) and RPM (frequency).
Old Mar 24, 2006 | 01:42 PM
Puppetmaster's Avatar
Got mine finally installed and set it up as per the info in this thread
My install thoughts/comments are here:
http://forums.maxima.org/showthread.php?t=463709
Old Mar 24, 2006 | 02:11 PM
Nismo3112's Avatar
Custom User Title
[IMG]http://i11.photobucket.com/albums/a190/Puppetmaster1/VAFCII/DSCN4427.jpg[IMG]
That **** doesnt double as a shift light does it?
Old Mar 24, 2006 | 03:24 PM
jmeister's Avatar
If you don't wanna use 12 of the fuel correction points then yes
Old Mar 24, 2006 | 10:36 PM
Ceasars Chariot's Avatar
Old Maxima Legend
great work SR !
Old Mar 27, 2006 | 05:04 PM
SR20DEN's Avatar
VQ Wizard
Here is the wiring template I started working on.
http://vq35de.com:2002/A33x_ECM.pdf
Look it over and offer suggestions or requests.
Old Mar 27, 2006 | 11:43 PM
mjk's Avatar
mjk
Head shot!!!
good job man, makes me wanna start on this, otherwise I was scared
Old Mar 29, 2006 | 11:44 AM
rbrown81's Avatar
But why is teh Rum gone?
Man its going to be painful to the wallet when I get that reflash and the VAFC... but fun
Old Apr 1, 2006 | 01:56 PM
vq356sp's Avatar
El Mas Noob Del Org.
Just got my safcII working yesterday. Here is some pics of where it is mounted. I have to say thanks to all above for all the good info on here it sure helped.
Old May 22, 2006 | 09:10 PM
aznsap's Avatar
i thought that open loop didn't come into effect until 3000 rpm? does that mean we can start the Lvt @ 3000 rpm and go up to redline in smaller increments?
Old May 22, 2006 | 10:04 PM
steven88's Avatar
Need A Light?
yes you could start at 3000 and go in smaller increments...the way sr20den sets his up is becuz he has larger injectors and a larger MAF....if you are stock, then you wouldn't really need to modify the low RPM/low throttle settings...
if you have simple bolt ons, starting at 3k would be just fine as well
Old May 23, 2006 | 01:26 AM
diymaximakid's Avatar
wait a sec.what vtec type does it need to be on in order for vias to work.
Old May 23, 2006 | 02:05 AM
steven88's Avatar
Need A Light?
just use the vtec type 1...i'm using it and have no problems...
Old May 23, 2006 | 05:43 AM
virgilio7's Avatar
1 in and 1 out i think it means the sensor type. sometimes u need to change this if you change of sensor (i think)
Old May 23, 2006 | 10:39 AM
steven88's Avatar
Need A Light?
My Settings are....
1 in and 1 out, 6 cylinder, arrow pointing "up right", and vtec type 1
sup virgillio...hows the kinetix coming along btw?
Old May 23, 2006 | 12:57 PM
aznsap's Avatar
thanks steven88 for the prompt reply
Old May 23, 2006 | 12:58 PM
mine are 4 in 4 out, northeastern arrow, vtec type 1.no problems what so ever.
Old May 23, 2006 | 01:21 PM
steven88's Avatar
Need A Light?
does anyone know what the sensor in and sensor out feature do? i remember reading the owners manual, but it doesn't give u an explaination for why
Old May 24, 2006 | 07:34 AM
virgilio7's Avatar
kinetix can suck the big one. they are going to experience bull**** when nobody buys it. sorry for the threadjack
Old May 24, 2006 | 10:07 AM
its the type of sensor for the maf/map. i'm looking to see if i can find a list
Old May 24, 2006 | 11:10 AM
virgilio7's Avatar
the safc2 manual has a list (i think). it showed an example like if you install a z32 maf you might need to change it from 1 to 1 => 2 to 1.
Old Jun 2, 2006 | 11:06 AM
what is everyone using for the throttle point settings?also is this the low and hi for the narrow and wide correction settings?
Old Jun 7, 2006 | 06:31 PM
aznsap's Avatar
where have you 4th gen guys put these? i'm wondering where people install these. in the glove box? on the dash somewhere?
