Sponsored by:
Sponsored by: CARiD
Kinetix IM for FWD VQs
Old May 9, 2006 | 02:02 PM
  #121
maxS
the only difference between a stock 287hp lower part of the plenum and the mrev 2 is that the mrev 2 is a "Standard lower collector with modified Intake Runners for reduced pressure drop "
"If you already have a spacer, all you need to do is modify the lower collector and it will make more torque and more horse power! In addition to area under the curve, it will kick up the peak HP by about 4-5 HP."
modify the lower collector in which way?
Old May 9, 2006 | 02:07 PM
  #122
Jime's Avatar
Go and read the 350Z threads it will tell you all you need to know. You modify it by sending it to Motordyne paying them money and getting back a modified lower collector like I did.
Actually they are milling the front runners down like in the MREV+ and now they are doing additional milling which gives additional HP in the MREV++ or as it is now called the MREV-2.
Old May 9, 2006 | 02:08 PM
  #123
Jeff92se's Avatar
I'm needing a caw
Jime, when you get your MREV++, take some pics of it for us. I'd like to see the additional machining.
Old May 9, 2006 | 02:22 PM
  #124
Jime's Avatar
Will do Jeff, I know people were asked at first not to post pics but I haven't been told anything in that regard. I should have my upper back on Thurs too from the welder so will try and post both.
Old May 10, 2006 | 04:21 PM
  #125
Jime's Avatar
Here are the pics of my upper 350Z plenum with the TB flange welded to plenum with elbow removed.
I have some dremeling to do but basically he did a pretty good job, won't take much to smooth it out on the inside.
Old May 10, 2006 | 04:52 PM
  #126
Nismo3112's Avatar
Custom User Title
^^^ Looks good!!!
Old May 10, 2006 | 06:17 PM
  #127
maxS
Originally Posted by Nismo3112
^^^ Looks good!!!
not really.
Old May 10, 2006 | 06:49 PM
  #128
stephenlc's Avatar
not really.
Thats looks pretty good, its really hard to weld cast aluminum.
Old May 11, 2006 | 03:53 PM
  #129
Buck96's Avatar
Not bad, not bad at all. Nice tig welding. A little clean up a little polishing and it will look stock
Old May 16, 2006 | 07:55 AM
  #130
Jime's Avatar
MREV 2 pics. Brand new lower was returned with 5/16" spacer and latest MREV.
It appears some additional machining was done on the inside of all 6 runners plus what you can see here.
Its also brand new vs the old one I sent them.
Fairly substantial weight difference too. Upper and lower 350Z = 19 lbs vs 13 lbs for the Maxima.
Old May 19, 2006 | 06:06 AM
  #131
Jime's Avatar
not really.
The guy that welded this is a Master welder with 30 years experience who also welds high pressure for the federal govt so I don't think I would pass judgement on his work. TIG welding cast aluminum is a very difficult task.
Old May 19, 2006 | 08:38 AM
  #132
SR20DEN's Avatar
VQ Wizard
LOL @ somone judging alumunum welds who's never even operated a mig welder.
Old May 19, 2006 | 08:44 AM
  #133
Jeff92se's Avatar
I'm needing a caw
Jime thanks! I wonder what those 6 little grind spots are on each runner? I see the usual MREV+ machining but where is the additional machining on each runner? Visible on the underside of the manifold?
Old May 19, 2006 | 10:43 AM
  #134
Jime's Avatar
I should have taken a picture of the old one before I sent it in. Not sure if those grind spots were there or not. The work in the runner is very difficult to get a picture of but it looks like he either made them a bit larger or maybe just made them all equal. Its on visible on the underside at all just on the inlet to about where it starts to curve.
Old May 19, 2006 | 04:52 PM
  #135
Nismo3112's Avatar
Custom User Title
Those are I believe from the molding:
Old May 31, 2006 | 01:20 PM
  #136
vsamoylov
you get it installed yet? also you have the 5/16th spacer. any pics of that?
Old May 31, 2006 | 06:42 PM
  #137
Jime's Avatar
Its installed with the MREV-2 and 5/16" spacer and the hood closes. I will snap a couple of pics tomorrow.
The hardest part was the throttle cable, but once I figured that out it was very simple to do. I will snap a pic of that too. I started to polish the upper plenum but couldn't wait to install so it will have to wait for winter. Its shiny but rough.
Old May 31, 2006 | 07:31 PM
  #138
mforrest100's Avatar
Very nice how you ran the TB cable. You need to produce. Have a group deal for like 5 people and they will buy. I put myself on the list first....(LOL)
Old May 31, 2006 | 08:16 PM
  #139
Nismo3112's Avatar
Custom User Title
Nice!! I have no idea how you fit the plenum, plus a spacer under there and closing the hood...
Old May 31, 2006 | 10:22 PM
  #140
In addition, for those that were wondering about the gains on the IM in this link:
http://chicagoz.com/v-web/bulletin/b...r=asc&start=45
If you read at the bottom where I posted, they are saying this will only beneficial to cars trying to push 500 or more whp. So I guess I will be moving towards the 350z IM.
Old May 31, 2006 | 11:16 PM
  #141
steven88's Avatar
Need A Light?
Jime, i see that your running the breather filter on the front valve cover....you haven't had any problems with it? Most people say it messes up your car...rough idle, misfiring, etc...just wondering
how much did you get it for btw?
Old Jun 1, 2006 | 09:39 AM
  #142
Nismo3112's Avatar
Custom User Title
I was running a breather for quite some time.. No probs with it.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Dave B
Mar 30, 2001 07:08 AM
Frank Fontaine
Dec 13, 2000 03:21 PM
