Sponsored by:
Sponsored by: CARiD
00VI swap question
Old Mar 21, 2006 | 10:55 PM
NYC32798's Avatar
00VI swap question
Got 2 00VI swap questions. From what i've read 4th gen IACV is located on the manifold and the 5th gen is located on the throttle body. I doubt the connectors are the same. Is there a way to use the IACV on the 5th gen TB instead of the 4th? If not how do you go about rigging the 4th gen IACV to work? I also read that people with the 00VI swap are using some type of RPM switch to "activate" the 00VI. Does this mean I must get this RPM switch in order to get the gains from the 00VI?
Old Mar 22, 2006 | 05:53 AM
Jason R's Avatar
aka UNCDooD
your best bet would be to donate and search.
Old Mar 22, 2006 | 06:36 AM
MDeezy's Avatar
It would be pointless to install a VI and not have something open it at a given RPM. So yes you'll need something to open it up at a higher RPM so it can breath better and contiue to make power.
Most I've read have fab'ed up a way to reuse the 4th gen IACV.
Old Mar 22, 2006 | 06:43 AM
Jason R's Avatar
aka UNCDooD
5th gen IACV plugs are different anyway. Even if you tried rewiring it like I think BSwithTF did it still won't work because the 5th gen IACV won't read the 4th gen ECU's signals properly.
Old Mar 22, 2006 | 07:32 AM
SDot82's Avatar
Not true mines works perfectly and I am using the 4th gen plug and 5th gen IACV.
Old Mar 22, 2006 | 07:33 AM
Kevlo911's Avatar
Kevlo for President
How is your cold start?
Old Mar 22, 2006 | 07:37 AM
Jason R's Avatar
aka UNCDooD
interesting. just so happens i got a 5th gen IACV sitting right here and I just so happen to know it'll work in my PF TB. hmmm..
Old Mar 22, 2006 | 07:39 AM
SDot82's Avatar
Cold start is 1500 rpms then slowly goes down to 700-600 rpms as it warms up, so basically like it was with the 4th gen IACV.
Old Mar 22, 2006 | 07:51 AM
Jason R's Avatar
aka UNCDooD
hmmm...I might give this a try myself.
Old Mar 22, 2006 | 08:18 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yeah, more details/pics on how you wired it please.
Old Mar 22, 2006 | 08:24 AM
SDot82's Avatar
I'll try and get some pics tonight because it's kind of hard to explain without them.
Old Mar 22, 2006 | 08:55 AM
MDeezy's Avatar
*awaiting pics*
Old Mar 22, 2006 | 09:03 AM
IceY2K1's Avatar
+1....so the 5th gen IACV fits fine in the PF TB?
Old Mar 22, 2006 | 09:45 AM
speed racer's Avatar
This will be real helpfull b/c I was planning on fabricating those adapter plates. Let us know. It will save us alot of headacke for alot of us.
Old Mar 22, 2006 | 01:26 PM
SDot82's Avatar
Pics are below first I forgot how it goes into the 4th gen IACV so if some can post a pic of it, since I don't have one, would be helpful. I first cut/broke the outer plastic housing far enough that it would go into the 5th gen IACV see pics 1&2. Next I did NOT do any rewiring of the 4th gen IACV plug see pics to match wiring (pic 3 white/blue strip is on top right with yellow on the left, white/green strip is on bottom right with purple on the left). Now on the 5th gen IACV I had to SLIGHTLY bend the outer pins so the 4th gen plug would go in. So just bend the pins little by little until you can get the to go in, this way you will not break a pin off and be pissed. Next the plug goes in with the yellow and purple wires facing you will the yellow on top and purple on bottom . Then just tape it up so it won't go anywhere.
Old Mar 22, 2006 | 01:28 PM
SDot82's Avatar
Old Mar 22, 2006 | 01:32 PM
IceY2K1's Avatar
Haha...I like it.
Old Mar 22, 2006 | 01:36 PM
Biggs_02's Avatar
so are you saying that for this might apply to the 3.5 swap? I could use the 5th gen iacv and attach that the pf tb and would have to avoid making an adapter for the 4th gen iacv?
Old Mar 22, 2006 | 01:43 PM
IceY2K1's Avatar
Exactly, you wouldn't need the IACV adapter, so you'd only need the PF->IM adapter.
Old Mar 22, 2006 | 02:08 PM
Biggs_02's Avatar
wow.....pulling my 3.0 on friday and dropping in the 3.5. I gotta make the adapter and this would be one less adapter to make.
Old Mar 22, 2006 | 02:10 PM
NYC32798's Avatar
Thanks for the info. That's just what I needed to know.
Old Mar 22, 2006 | 03:31 PM
cw96's Avatar
SDot82 Thanks for the info. I am changing out my intake this weekend and was planning on having to do alot of cutting and splicing on the wiring harness to the iacv.I bought an adapter so I could use my old throttle body but now I'll just leave the 5th gen throttle body on.Saved me alot of headache! Thanks!
Old Mar 22, 2006 | 03:38 PM
IceY2K1's Avatar
If someone has the 5G male connector, could you try to remove the pins one-by-one and swap in the 4G pins? Just curious....
Old Mar 22, 2006 | 10:40 PM
gtr_rider's Avatar
192.168.1.1
I dont see why you COULDNT do that, I thought about doing that, but regardless it wont fit under the 00' TB
Old Mar 23, 2006 | 06:35 AM
Jason R's Avatar
aka UNCDooD
yea i was looking at that yesterday evening and noticed that the piece that bolts to the TB that houses the IACV won't fit. At least not on my '95 it won't.
Old Mar 23, 2006 | 06:41 AM
gtr_rider's Avatar
192.168.1.1
It looks as if he completely bent the EGR valve bracket out of the way to fit that
Old Mar 23, 2006 | 07:05 AM
SDot82's Avatar
Yeah to make it fit you have to remove 2 brackets one for is are for all the air hoses and fuel line and the other is an egr compenot forgot the name of it but looks like a disk. I am getting rid of the hose bracket soon as it gets warm and just re-run new hoses.
Old Mar 23, 2006 | 07:15 AM
gtr_rider's Avatar
192.168.1.1
The disk is the EGR Valve itself, so I assume you just blocked the hole for the EGR guide tube under the manifold? I guess a IACV plate is in my list of things to do..
Old Mar 23, 2006 | 08:00 AM
SDot82's Avatar
no I still have a working egr, I removed it from its bracket but did not remove it.
Old Mar 23, 2006 | 08:30 AM
gtr_rider's Avatar
192.168.1.1
Wow interesting..
Old Mar 23, 2006 | 08:54 AM
Great info. Damn though, I wan't to use my egr still. I'm going to have to think of the pros and cons on this one. Great write up.
DandyMax's Avatar
3.5 in the works
Actually that disc is not the EGR valve itself. It's the EGR-BPT valve... and yes it can be relocated without too much trouble if you need to do so.
Sdot I have a question: it appears as if you only used the main IACV connector. On the 4th gen there are 3 though.. the extra 2 used to adjust idle speed when the A/C or P/S are in use (ie bump up idle speed so the rpms don't drop too low)... So do you have any problems with your idle speed dropping a lot when the A/C and or P/S are drawing heavy loads on the engine (like steering at a stand still in a parking lot for example)?
Old Mar 23, 2006 | 09:14 AM
gtr_rider's Avatar
192.168.1.1
I really want my car to work as factory with all EGR, and things intact.. I also noticed that you didnt connect the other two harnesses in place.
Old Mar 23, 2006 | 10:12 AM
SDot82's Avatar
The idle is bumped up when I use either the a/c or power steering when I am at a stop.
Old Mar 23, 2006 | 11:32 AM
IceY2K1's Avatar
Sorry to pester, but could you take a pic or two of the lines/brackets you said you moved/bent out of the way so the IACV would fit below the TB?
Old Mar 23, 2006 | 02:51 PM
MaxGordon7's Avatar
i thought the 5th gen ivac was under the tb, that one looks on the side. is that a Pathfinder TB?. Thanks.
Old Mar 23, 2006 | 03:50 PM
Jason R's Avatar
aka UNCDooD
pathfinder TB has the IACV in the same location.
Old Mar 23, 2006 | 03:58 PM
Kevlo911's Avatar
Kevlo for President
He did a DEK swap IIRC.
Old Mar 23, 2006 | 04:38 PM
SDot82's Avatar
I'll post it tomorrow.
Old Mar 24, 2006 | 03:52 PM
scrhale's Avatar
Personally, I have done a LOT of research on 3.5 and 00VI and I have never seen anything about using 5Gen IACV without having idle problems. This should definately change a lot of stories with the swap. Now we don't have to worry about blocking off the A33 TB and making a mounting location for A32 IACV provided that we buy an A33 TB. I believe it should become unheard of to use the A32 TB and IACV given this information. Not only would it make the swap easier and faster, but it would also be the same price since you won't have to purchase an IACV adaptor plate or create/buy a mounting bracket for the A32 IACV.
Great information!
