Sponsored by:
Sponsored by: CARiD
Finally done 01-DEK Engine in my 97 (Video)
Old Apr 1, 2006 | 09:47 AM
DcMaN's Avatar
well its finally done and it cranked on the first try. Let me know what you guys think, comments and suggestions welcome.
http://media.putfile.com/01-DE-k-in-my-97
Old Apr 1, 2006 | 10:40 AM
MaxGordon7's Avatar
haha joined the club, took you long enuff and asked so many question. Very clean set up and looks good.
Old Apr 1, 2006 | 02:34 PM
95maxrider's Avatar
Lightly modded
Good to see another person in the club....
Old Apr 1, 2006 | 03:29 PM
mforrest100's Avatar
How do you view?
Old Apr 1, 2006 | 04:35 PM
DcMaN's Avatar
my engines got a little jump to it like its misfiring.... Ive unplugged every coil pack one at a time to see which one didnt affect the idle. None of them did, i just changed the plugs. Its still a bit jumpy. The idle seems to be a little bit jumpy. And i always have this Hissing noise coming from the IACV vacuum line that is quite annoying. Its not leaking but you can hear the air coming from it. If anyone has any suggestions id appreciate it
Old Apr 1, 2006 | 09:07 PM
gtr_rider's Avatar
192.168.1.1
Check to see if your TPS is adjusted 100%, and also I got the same annoying hiss from the intake area.
Old Apr 1, 2006 | 09:26 PM
MDeezy's Avatar
that hissing sounds like it can get very annoying. Do you guys need to run that line to the iACV?
Got anything to control that VI yet?
Old Apr 1, 2006 | 09:31 PM
MaxHind's Avatar
very nice, good job
Old Apr 1, 2006 | 09:32 PM
DcMaN's Avatar
not yet lol this engine killed the pockets :P . Between the iacv adapter all the little stuff, synthetic tranny fluid, hose, clamps, oil, coolant. I cant afford the Vi at the moment but soone enough i will hehe
Old Apr 2, 2006 | 09:01 PM
JeEvE's Avatar
Congrats on the swap. I see you have the grounds on the valve cover, do you have any problems with the engine shutting off? For me, it was a bad ground so it to a different ground.
Old Apr 3, 2006 | 10:08 AM
DcMaN's Avatar
no the grounds on the valve cover are fine, however you needed to sand down the area where the bolt would make contact in order to provide a sufficient ground.
Old Apr 3, 2006 | 10:22 AM
JeEvE's Avatar
I made sure that I did that and it seemed that the valve cover gasket and each of the bolts for the valve cover had a gasket so there was not really that great of contact with the head. After the car would warm up, the ground got worse and it would eventually throw the sensor off and cause it to stall.
Old Apr 3, 2006 | 10:23 AM
LudeAEM's Avatar
Is this swap a straight swap? I know it bolts up of course, but wiring, ecu, etc?
Old Apr 3, 2006 | 11:18 AM
nismology's Avatar
Yea it's a bad ground location since the valve cover gasket is rubber and insulates it from the head.
Old Apr 3, 2006 | 11:48 AM
MDeezy's Avatar
You'll need to wire up the injectors.
Old Apr 3, 2006 | 11:29 PM
matty's Avatar
It really didnt take him all that long. I bought mine a week ago and it wont be in the car for probably another month ...
-matt
Old Apr 3, 2006 | 11:31 PM
matty's Avatar
Everything matches execpt for a few odds and ends. A couple of the sensors need to be swapped over from your DE to your DEK. You can't use the DEK EGR valve since its electronically controlled and the 4th gen unit is vaccum controlled, and youll need to wire up 6 new injector clips to accomidate the top feed 5th gen injectors. Other than that its a pretty good swap out. I have my motor with 8500 waitint to be tossed in
-matt
Old Apr 4, 2006 | 07:01 AM
LudeAEM's Avatar
is there a writeup i can look at?
Old Apr 4, 2006 | 02:00 PM
DcMaN's Avatar
haha the only reason it took so long to do the swap cuz i was waiting for MATTY to send me the injector clips :P . Haha
Mar 12, 2020 12:06 AM
spazma7ik
Jan 12, 2017 09:38 PM
seesole
Sep 14, 2015 12:38 PM
bennuss
Sep 11, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
