Sponsored by:
Sponsored by: CARiD
Lower plenum butterfly valve removal?+ -
Old Apr 12, 2006 | 01:46 PM
vortechpower's Avatar
What are the pros and cons of removing the lower plenum butterfly valves on the DE-K? (Super charge application,2.87)
Gas milage?
Low end?
Top end?
Old Apr 12, 2006 | 04:09 PM
sonicrunch's Avatar
I think you know the answer.
Old Apr 12, 2006 | 04:24 PM
Is there really a benefit though? I took the ones out of my 99 cali spec and didnt notice too much difference
Old Apr 13, 2006 | 06:41 AM
NewLoveI30's Avatar
With your FI application it would definitely benefit you to keep your VI opperating correctly.
... I guess it's good N/A as well, but the gains are only compounded with boost.
Old Apr 13, 2006 | 07:00 AM
nismology's Avatar
He's not talking about the VI. He's talking about the swirl valves in the intake manifold.
Old Apr 13, 2006 | 07:15 AM
sonicrunch's Avatar
Sure fooled me. I thought he was talking about the VI as well.
Old Apr 13, 2006 | 07:30 AM
"lower plenum"
Old Apr 13, 2006 | 07:47 AM
nismology's Avatar
Since when do '99 cali-spec's have a VI.
Old Apr 13, 2006 | 07:50 AM
matty's Avatar
I would take them out. Ive heard of a huge difference when the engine is cold, they are supposidly closed completly. As the motor warms up, they begin to open. There is still restriction there even when their open.
I vote to take them out for sure
-matt
Old Apr 13, 2006 | 09:36 AM
My 99 cali spec motor had the "swirl valves" in it. I swapped the lower plenum with a 96 lower plenum.
One would think it would be better not to have the swirl valves but has anyone proven this theory?
Old Apr 13, 2006 | 09:50 AM
nismology's Avatar
I know exactly what you mean(t). I was just showing sonicrunch that one could deduce that you were referring to the swirl valves based on what you had previously posted.
Old Apr 13, 2006 | 10:57 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
No one needs to prove it is better to have less turbulence/restriction.
Are the gains worth the work to remove them is a better question.
Old Apr 13, 2006 | 11:03 AM
sonicrunch's Avatar
"lower plenum"
DOH!
Old Apr 13, 2006 | 11:06 AM
IceY2K1's Avatar
FSM description on their purpose makes it pretty clear....
This system has a swirl control valve in the intake passage of each
cylinder. While idling and during low engine speed operation, the swirl control
valve closes. Thus the velocity of the air in the intake passage
increases, promoting the vaporization of the fuel and producing a
swirl in the combustion chamber. Because of this operation, this system tends to increase the burning speed of the gas mixture, improve fuel consumption, and increase the stability in running conditions.
Also, except when idling and during low engine speed operation,
this system opens the swirl control valve. In this condition, this
system tends to increase power by improving intake efficiency via
reduction of intake flow resistance, intake flow. The solenoid valve controls swirl control valve’s shut/open condition. This solenoid valve is operated by the ECM.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
