Sponsored by:
Sponsored by: CARiD
Is it possible to use the 3.5 IM?
Old Apr 24, 2006 | 06:19 PM
SNOMAX's Avatar
PM me for LCA's!
Is it possible to use the 3.5's Intake Manifold on a 3.0? If so, is there a reason to go with the 00VI instead of the 2003+ ?
Old Apr 24, 2006 | 06:21 PM
tavarish's Avatar
fwd gone rwd cr00
no, it isn't. The bolt holes do not line up at all.
Old Apr 25, 2006 | 12:54 PM
SNOMAX's Avatar
PM me for LCA's!
Do the ports line up on the lower manifold? Or is it just the bolt locations?? Anyone have pics ?
Old Apr 25, 2006 | 01:23 PM
Larrio's Avatar
The Definitive AE Master
The heads are different, hence the lower and upper intake manifold will not work.
The vq35 heads have circular inlet ports
The vq30 heads have oval inlet ports
That would be the reason
Old Apr 26, 2006 | 01:26 PM
tavarish's Avatar
fwd gone rwd cr00
no bolts lined up, i tried with the 350z manifold on my parts car engine, just for fun.
Old Apr 26, 2006 | 09:39 PM
aznsap's Avatar
thanks tavarish. that kind of makes me sad. i'd like to get an IM, but i'm not sure if i'd be content going w/ the 00vi.
Old May 3, 2006 | 04:25 PM
NmexMAX's Avatar
dot dot dot ...
Being that the aligment is off, that's your best option.
It came on 2002 also. The 04+ is slightly different. (LIM) The Z33 IM is better than the Maxima 3.5L piece.. so which are you talking about?
Old May 4, 2006 | 05:28 PM
truckman1966's Avatar
does anybody know if the IM off of a murano is the same as a 3.5 Max? if not, what is different? also, If I can't use it on my 4th gen swap, does anyone have a stock IM from a 3.5 Max and the engine cover too?
Old May 4, 2006 | 05:35 PM
NmexMAX's Avatar
dot dot dot ...
It's the same.
Old May 5, 2006 | 06:54 PM
SNOMAX's Avatar
PM me for LCA's!
Okay, let me clarify.... I was talking about the 2002-2003 Max specifically. When I was in the parts dept. of my Nissan stealership, I had the guy pull up diagrams of both upper and lower IM for the 3.0 and 3.5, specifically 1997 and 2002.
The interesting part is the part number for the lower manifold gasket--where the LIM meets the cylinder heads is the same (14035, I think, I cant find my print out right now).
So.... doesn't it seem like they should bolt right up? I'm sure someone has tried this or has pics. But the same part numbers got me thinking...
Old May 5, 2006 | 08:01 PM
eng92's Avatar
You are confusing part codes with part numbers. 14035 is the part code for the LIM/head gasket. That is only the first 5 digits in the p/n.
Specifically:
07/96-06/01 - 14035-38U01
06/01-end of 03 production - 14035-8J101
The 14035-38U01 is also used on the VQ35 in the 01+ Pathfinder
Fbana41
Aug 29, 2016 12:18 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
09maxshawn11
Sep 30, 2015 10:28 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
MaxRPM6
Sep 11, 2015 06:56 PM
