First-timer/noob pulls off 00VI install...
First of all, let me thank the .org and especially the pioneers of the 00vi mod, i was able to pull it off this past weekend with all of the good info available in the threads on this site and the hard work of others that have already done this mod. Took me a few weeks of prep (parts ordering, research, and drilling/prepping the manifolds. I have the following setup:
- 4th gen lower drilled for 1/4-20 threaded rod for middle rear bolts (using existing front middle M8 bolt holes with drilled out upper brass tubes)
- 4th gen tb w/adapters
- 4th iacv remote mount w/adapter
- 00vi fed spec w/5th gen egr tube
- baker electronix ARWS rpm window switch set to 4600
After working on/off for 4 days, it started right up and hauled butt on the first test drive. the power valve is definitely working correctly judging by how easy it is to hit the rev limiter now
My only issues have been:
- boneheaded incident of iacv assembly moving into and binding throttle cams at WOT (fortunately in 3rd gear, shut it off and pulled over safely to fix boneheaded problem).
- my base idle is way high (1200-1500 rpm) and its hunting from 1500-almost 2k while coasting, making for some jerky driveability in traffic. I notice many have had this issue and i'm going to try to sort it out this week.
All in all, it wasn't overly difficult for the first-timer with a (relatively) level head and moderate mechanical skills. A very worthwhile mod for less than $500 total investment and a few days of downtime...
My only issues have been:- boneheaded incident of iacv assembly moving into and binding throttle cams at WOT (fortunately in 3rd gear, shut it off and pulled over safely to fix boneheaded problem).
thanks... update i just fixed the high/hunting idle. It seems like it was just the cold idle cam (i bypassed coolant to TB). I screwed it in all the way and then screwed in the iacv adjustment screw and everything seems normal now (actually maybe a tad low).
congrats, I am lagging man. I have my vi sitting on the floor of my room just waiting for me to install him lol. i just need minor things. I am also going to use the 4th gen lower, but im going to use a helicoil instead of your route. What bracket did you use for the throttle cable? cuz my vi dosnt have the bracket on it.
I used what i had - the 4th gen cable bracket with just one bolt. Its temporary until i either get a 5th gen bracket or make up a small secondary bracket to pick up another mounting boss. I'll probably just do that, it will only be a short peice of aluminum with 2 holes in it (one goes to 4th gen bracket, another picks up nearby threaded boss on manifold). Its just one of many "sorting out" type things I am left with after this swap.
Wow ... that is inspiring. Makes me want to do the mod even more. The only problem is that I have problems justifying the install when a DEK swap is just a tad bit more. I think we need to do a comparison between the two. In other words (and I SERIOUSLY doubt this), would the lighter VQ30DE with VI be better off then a DEK swap since the DEK weighs more?
The scariest part to me about the swap is removing the upper intake manifold and drilling the lower. Of course you can pay someone 75 bucks plus core swap ... but forget that.
Great to hear you got everything on with out a hinch. Working on the final steps of doing this myself. Doing as much prep work, b/c I plan on having a day and half of down time only.
Since when does the DE-K weigh more? It's the same engine, practically
If anything, it's lighter than the USIM-equipped DE since the upper manifold is made of lighter materials. Either way, it's negligable.
TomV great to hear about the swap. I have been thinking of doing this sometime this summer. Where did you get all of the parts to accomplish this? Also did you buy a 2nd lower manifold in case you messed up the drilling?
Originally Posted by VQuick
Seems to me that a complete DE-K swap is the way to go:
- engine will probably have lower miles
- slightly improved internals
- 5th gen injectors and everything
Just waiting for parts.8,500 miles
Progress...
Originally Posted by matty
My sweet DEK is going in, in about 2 weeks
8,500 miles
Progress...
Progress...
Yea that first pic is how it came from the Salvage yard, but thats after cleaned. The Headers were there, but no Y-pipe. I got the O2 sensor on the front bank and all the hoses for the coolant were Cut. No Main Harness cut though
-matt
-matt
HerpDerp1919
Sep 29, 2015 02:02 PM
