Sponsored by:
Sponsored by: CARiD
need help with vq35 swap in a 96 max
Old May 12, 2006 | 12:02 PM
russt766's Avatar
Lightbulb need help with vq35 swap in a 96 max
i am installing a vq35 in my 96 maxima and i need help....
i wanted to do a vq35 with the 3.0 timing chain...
but i wanted to know if i still need to redrill the intake cam and get a jwt spacer???
i got everything else for this swap...
let me know thanks....
Old May 12, 2006 | 12:30 PM
Nismo3112's Avatar
Custom User Title
Yes you do, unless you get Tilley's new spacer... Which doesn't require drilling.
Old May 12, 2006 | 12:39 PM
hightuner's Avatar
Nissan maniaco conpulsif
hum i am not too sure about that , i tough that spacer , what for a 3.5 cam in a 3.0
anyways , if your right ill get that too
just to be curious what kind of clutch u got n fpr ?
Old May 12, 2006 | 12:42 PM
chris'smax's Avatar
2 options here
Easiest option
1) you can use your 3.0 cams(they are a direct drop in) and that would save you from getting the 3.5 cams modified.
2)More complicated but better option for power
tilley now makes adapter for the 3.5 cams so you don't have to have them sent out to be drilled anymore.
Old May 12, 2006 | 12:45 PM
Nismo3112's Avatar
Custom User Title
If you decide to use 3.0 cams, I would suggest JWT cams at the least.
Old May 12, 2006 | 01:09 PM
russt766's Avatar
i am going to be using...
3.5 head, block, intake manifold, 3.5 cams....
everything 3.5 except the timing chain, cover, sprockets from the 3.0...
Old May 12, 2006 | 01:11 PM
russt766's Avatar
i thought that spacer was for the 3.0 motor with the 3.5 cams...
so do i need the cam spacers from tilley???
Old May 12, 2006 | 01:14 PM
Biggs_02's Avatar
get the adapter that tilley made, it'll work. Also you don't wnat to use the 3.5's headers, very restrictive. Better off using the 3.0 headers.
Old May 12, 2006 | 01:22 PM
Nismo3112's Avatar
Custom User Title
I think it can work in a 3.5 too...
Old May 12, 2006 | 01:25 PM
russt766's Avatar
i will be uing the 3.0 headers with warpspeed y-pipe
Old May 12, 2006 | 03:25 PM
mforrest100's Avatar
They work for 3.5 swap. I ordered mine about two weeks ago. Hopefully Tilley sent them out. Call Tilley, if you can reach him, and get the adapters/spacers. $100 shipped.
Old May 12, 2006 | 05:56 PM
Biggs_02's Avatar
cheaper then getting the spacers and cam drilled.
Old May 12, 2006 | 07:25 PM
cantcatchme's Avatar
so how much does tilley want for the new spacer that doesnt require the cams to be drilled, and how does it work
Old May 12, 2006 | 07:37 PM
Nismo3112's Avatar
Custom User Title
See post 11 for pricing.
Old May 12, 2006 | 08:21 PM
Biggs_02's Avatar
i'm pretty sure it just goes into your current dolly hole then on the adapter it's a spacer with a dolly hole on the right side.
Old May 13, 2006 | 04:59 AM
MDeezy's Avatar
would like to see pics of this new adapter.
Old May 13, 2006 | 05:59 AM
I would like to post a picture of this new adapter but I don't have it yet. The way Rob (Tilley) says this is made is by taking the JWT spacers and doing a little modification to them to make it an adapter. I ordered the JWT spacers a month ago so I know Rob had them for about 2 weeks so I hope I can get them by next week. This is the only thing holding up my swap. Its a little frustrating but I am trying to be patient.
Old May 13, 2006 | 06:26 AM
MaxBlack97's Avatar
rust 788, what exactly do u have have the swap when u say u have everything?
Old May 13, 2006 | 06:45 PM
russt766's Avatar
i have a complete vq35 engine...i have injector clips from the vq35...i have a pftb...i have a sard fuel pressure regulator...i have a greddy emanage instead of a rpm switch..i have a 6puck act clutch
Old May 13, 2006 | 06:55 PM
diymaximakid's Avatar
what are you doin 4 iacv
Old May 13, 2006 | 08:27 PM
russt766's Avatar
block off plate from my 4th gen iacv
Old May 13, 2006 | 08:59 PM
oh with a a hole for the air valve(not sure what its called)
Old May 14, 2006 | 01:43 PM
russt766's Avatar
yup...thats what im going to do
Old May 15, 2006 | 03:56 PM
russt766's Avatar
how fast can tilley make it or is it premade to ship out???
Old May 15, 2006 | 04:44 PM
Put it like this...order your spacers ASAP. He has to order the JWT spacers from JWT which take about a week and a half to two weeks. Then he has to modify them for the adpater part. As I said, this is the beginning of the 4th week for me.
Old May 16, 2006 | 05:43 PM
russt766's Avatar
well i tried calling tilley and left message on friday but i get no return call and i tried calling all day today but no one answers.....how can i get in touch with him to order the spacers??
Old May 16, 2006 | 06:42 PM
96sleeper's Avatar
Keep trying, he is hard to get ahold of.
Old May 16, 2006 | 08:18 PM
Exactly..... Its not that he is ignoring people but he is just very busy and I believe he is on the shop by himself most of the time. If he stops to pick up every call probably wouldn't get much done. But he will eventually call you back. Just call everyday. As you can tell, he has an answering message that is two weeks old.
Old May 17, 2006 | 03:10 PM
russt766's Avatar
okay ill keep trying
Old May 17, 2006 | 08:49 PM
I am having the same problem right now as I would like to know the status of my order.
Old May 17, 2006 | 09:06 PM
hightuner's Avatar
Me too lol
hehe
Old May 18, 2006 | 01:30 AM
russt766's Avatar
i called today and no answer also but i left another message
Old May 18, 2006 | 04:48 AM
Eventually he will call.....LOL
In addition, you don't have to wait for the adapters. You can order the JWT spacers from Cattman and get the cams drilled by Stephen Max. That is another alternative that may be quicker if you are in a real rush.
Mike
Old May 20, 2006 | 02:41 PM
Has anyone heard from this guy Tilley? I've been calling him for about two weeks now and haven't heard from him.
Mike
Old May 20, 2006 | 04:11 PM
russt766's Avatar
nope not me
matts95max
Apr 23, 2025 10:44 AM
AaronL
Nov 15, 2020 11:52 AM
meccanj98
Sep 16, 2015 06:06 PM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
