Here is a head scratcher!
Originally Posted by chris'smax
Thats what i thought i remember reading. So now the question remains if that extra 2 degrees is what is causing all the problems.
Originally Posted by mforrest100
And how exactly can this be determined??? Basically meaning what method can be used besides swapping out the cams for stock cams. That seems like a very long method.
can i make a adjustment w/ the timming chain to make up for the increased 4degree overlap?
I thought that stock overlap for vq35 cams is 2 degree of overlap?
this is according to sr20den
VQ30DE (1995-1999)
Intake__Lift: 8.55mm -- Intake__Duration: 232º
Exhaust_Lift: 8.55mm -- Exhaust_Duration: 232º
Overlap: 6º
VQ30DE-K (2000-2001)
Intake__Lift: 8.55mm -- Intake__Duration: 224º
Exhaust_Lift: 9.0mm --- Exhaust_Duration: 232º
Overlap: 6º
VQ35DE (2002-2005) FWD
Intake__Lift: 9.5mm -- Intake__Duration: 238º
Exhaust_Lift: 9.5mm -- Exhaust_Duration: 240º
Overlap: 2º
So that would mean i have 6 degrees of overlap with the nismo cams?
VQ30DE (1995-1999)
Overlap: 6º
Overlap: 6º
Overlap: 2º
Originally Posted by nismology
Well i was referring to stock DE-K cam timing. Are tilley and stephen max drilling the 3.5 cams so that there's 2 degrees of overlap? If so, top-end power is being limited with these 3.5 swaps.
The way he put it to me is that they are drilling them in the medium between the advanced setting and the retarded setting. I am not sure what the specifics come out to.
Well the 2* of overlap in the 3.5 is with the VTC's off which im assuming is in the fully retarded position. If this is true, when they drill the stock 3.5 cams there is surely more than 2 degrees of overlap.
So say they drilled the hole to be in the middle. Say around 4 degrees, that would mean i have 8 degrees of overlap. Now with that said, if i ran the vq 30 cams in the 3.5 i would have 6 degrees of overlap correct? The nismo's would put me at 2 degrees more than the stock vq30's?
Sorry about asking all these questions, but you seem to know more about this than i do.
The 3.0 cams would put you at 6 degrees of overlap. From the link mforrest gave, the r-tune cams are 2 degrees more aggressive than the JWT/JWT knockoff cams. Those advance cam timing 2 degrees on their own. Which means you're looking at 4 or more degrees more overlap than stock, which is pretty significant especially if you don't have VTC.
I think the middle is closer to six, since that's what the 3.0's came with from the factory...a good compromise. It might be even higher than 6 degrees, depending on what the range of the VTC sprockets are.
Wouldn't guys with the 350z have the same problem if they were to get a set of the wild tomei cams? If so how is it that they are able to get away with. Maybe engine management and tunning?
The idle issues are bad enough with the overlap you're running now, but the problem is two-fold since you don't want too much overlap at all with boosted motors.
They have VTC's. That's the advantage they have. Being able to run aggressive cams while maintaining good idle and drivability.
Ok so say they get the tomei 268 cams and the stock overlap is 2 degrees w/ the vtc off. If the the tomei add say 6 degrees duration(just a random #) Wouldn't that put the overlap at 8 degrees w/ the vtc off?
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
