Sponsored by:
Sponsored by: CARiD
6 speed swap questions
Old May 29, 2006 | 04:16 PM
Hoooper
2002 maxima, auto-6spd
the transmission is in and the engine cranks fine, but wont start. compression is ok, fuel pressure is good, but does not spark. anybody have any ideas for getting spark? all of the connections are hooked up and it seems ready to go, just wont spark.
Old May 29, 2006 | 04:22 PM
Nismo3112's Avatar
Custom User Title
Is the crank pos. sensor between the engine and tranny reading the flywheel teeth okay?
Old May 29, 2006 | 04:41 PM
Hoooper
cps is same for both man and auto and it is signaling
Old May 29, 2006 | 04:42 PM
Nismo3112's Avatar
Custom User Title
I know that.... My question was, was it reading the flywheel okay..
Old May 29, 2006 | 05:28 PM
Hoooper
well, we took a voltage reading and it was sending a signal to the computer, and you cant really put the flywheel on wrong. unless the sensor could send wacky signals i think its ok. i wanted to know about the computer really. does it need the manual computer?
Old May 29, 2006 | 08:19 PM
Kevlo911's Avatar
Kevlo for President
Check for a CEL.
What ecu?
Old May 29, 2006 | 09:38 PM
Hoooper
was trying it with the auto ECU, but now we are putting in the manual ECU to see. the dealership is retarded and doesnt understand that i want them to program the immobilizer and not just the key. hopefully the ECU will fix it.
Im pretty sure there arent any codes.
Old May 30, 2006 | 01:27 PM
Hoooper
Old May 30, 2006 | 01:31 PM
Kevlo911's Avatar
Kevlo for President
Check the codes anyways
Also, does a green key stay on while starting? How about the red security light?
Old May 30, 2006 | 01:52 PM
Hoooper
where is the green key i should be looking for? ill have to look at the security light also
Old May 30, 2006 | 02:08 PM
Kevlo911's Avatar
Kevlo for President
When NVIS (NATS) detects trouble, the security indicator lamp
lights up while ignition switch is in “ON” position.
This lighting up indicates that the
Hehe, I don;t think Maxima's have the "green key" My bad.
Old May 30, 2006 | 02:12 PM
nismology's Avatar
The murano has that.
Old May 30, 2006 | 02:16 PM
Hoooper
so the security light stays on? not flashing but solid light?
Old May 30, 2006 | 02:19 PM
Kevlo911's Avatar
Kevlo for President
Yeah solid. I think
Old May 30, 2006 | 02:21 PM
Kevlo911's Avatar
Kevlo for President
The security indicator is located on the instrument panel. The indicator
blinks when the ignition switch is in “OFF” or “ACC” position.
Therefore, NVIS (NATS) warns outsiders that the vehicle is
equipped with the anti-theft system.
I. --When NVIS (NATS) detects trouble, the security indicator lamp
This lighting up indicates that the anti-theft is not functioning,
so prompt service is required.
Old May 30, 2006 | 03:15 PM
Hoooper
ok, ill check that
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
