Sponsored by:
Sponsored by: CARiD
VQ35 swap questions - near swap date
Old Jun 1, 2006 | 10:32 AM
tavarish's Avatar
fwd gone rwd cr00
hey, i have a few questions regarding the swap i'm doing this week.
1. Is it possible to use the Crank position sensor (REF) and use the 3.5 oil pans?
2. There's a coolant tube coming from the bottom of the 3.5. Should I plug that up somehow?
3. Can I use the 3.5 crank pulley? (My 3.0 crank pulley is chipped, and doesnt give the correct readings for the crank ref sensor)
4. If I use the stock accessories on the VQ35, what size belt should I use?
Thanks,
-Freddy
Old Jun 1, 2006 | 10:39 AM
JClaw's Avatar
Use the 3.5 sensor. I just cut and soldered the wires. That way a) you don't have to change to 3.0 pan b) you don't have to grind the block for the 3.0 sensor to fit. Your 4th gen ECU will be able to read the 3.5 sensor. Just shaped differently.
Oil cooler or coolant? Either way remove the oil cooler and plug up the coolant line.
Probably. I used a motorstorm UDP for 95-99 and had to grind it some or the sensor would hit the pulley.
Old Jun 1, 2006 | 10:46 AM
tavarish's Avatar
fwd gone rwd cr00
The REF sensor is the one by the crank pulley.
Old Jun 1, 2006 | 11:02 AM
mforrest100's Avatar
So for the first paragraph, are you saying you don't have to shave down metal a 1/4" to get the sensor to contact the flywheel correctly?
Old Jun 1, 2006 | 11:24 AM
nismology's Avatar
Why not keep the oil cooler? It's there for a reason.
Old Jun 1, 2006 | 11:39 AM
SDot82's Avatar
Could I use the sensor from an auto?
Old Jun 1, 2006 | 11:58 AM
nismology's Avatar
He's talking about the CPS (REF) which goes by the crank pulley.
Old Jun 1, 2006 | 12:34 PM
chris'smax's Avatar
you have to use the 3.0 crank pulley. The 3.5 doesn't have the required timming ring on the pulley.
Old Jun 1, 2006 | 01:24 PM
diymaximakid's Avatar
you can use the 2k2 crank(pos) sensor to keep from grinding anything.just switch the connector for the crank(pos) sensor.
Old Jun 1, 2006 | 05:49 PM
nismology's Avatar
JClaw already said the same thing in post #2.
Old Jun 2, 2006 | 12:18 AM
yeah i no but i was answer a question posted after that.(or atleast i thought i was)
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
QueensMAX
Sep 15, 2015 04:14 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Johnny9595
Sep 3, 2015 05:18 AM
