Sponsored by:
Sponsored by: CARiD
EU in but some problems
Old Jun 14, 2006 | 01:52 PM
Kevlo911's Avatar
Kevlo for President
Timing won't advance or retard
Timing reads good at idle, it's at 15.
Wideband will be here in the next two weeks so then I can mess with fuel.
Why won't my timing work?
Old Jun 14, 2006 | 02:03 PM
Jeff92se's Avatar
I'm needing a caw
WTF? It's only 10 wires. How could you eff it up? j/k
Old Jun 14, 2006 | 02:32 PM
Jime's Avatar
Timing won't advance or retard until new version is released, supposedly at the end of June.
Old Jun 14, 2006 | 02:46 PM
Kevlo911's Avatar
Kevlo for President
I have 1.15
Old Jun 14, 2006 | 02:50 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Timing won't retard at idle or WOT?
If WOT, how did you verify?
Old Jun 14, 2006 | 02:55 PM
gtr_rider's Avatar
192.168.1.1
your car is broken..
Old Jun 14, 2006 | 03:04 PM
Kevlo911's Avatar
Kevlo for President
At idle, I have the beta software that reads out crank. And the timing stays at 15 at idle when I try to add +5 in the map.
Old Jun 14, 2006 | 03:06 PM
IceY2K1's Avatar
Don't use idle as a test and don't use an OBD scanner.
Dandy gave you the Beta version?
Old Jun 14, 2006 | 03:09 PM
Kevlo911's Avatar
Kevlo for President
I dont have an OBD Scanner. Naa Dandy didnt give it to me
Old Jun 14, 2006 | 03:18 PM
IceY2K1's Avatar
Where'd you get it.
Old Jun 14, 2006 | 03:40 PM
Kevlo911's Avatar
Kevlo for President
Ask Greddy Or complain about the car really
But how should I setup the rpm switch? Anyway I can make it send 12v instead of ground at the desired rpm? Do I HAVE to use a relay?
Old Jun 14, 2006 | 03:41 PM
DandyMax's Avatar
3.5 in the works
I didn't give it to him.
And like Alex said, you can't use a scanner to verify timing. It's blind to the EU.
Old Jun 14, 2006 | 03:46 PM
Kevlo911's Avatar
Kevlo for President
Im not using a scanner, I don't own one. But the EU can log timing, and when it warms up it is at 15. Once you start revving it can go past40-50. SO I let the car warm up and sit there, it stayed at 15. I tried to add 5 degrees of timing and it did nothing, it did not go to 20. Rpms did not change. I tried to retard at idle and nothing still, no changes. What did I do wrong?
Old Jun 14, 2006 | 03:48 PM
IceY2K1's Avatar
[edit]Use the Aux Output map....[/edit]
Old Jun 14, 2006 | 03:50 PM
IceY2K1's Avatar
Can you PLEASE send me v1.15 or did they make you sign some kind of lien against your house?
Old Jun 14, 2006 | 03:51 PM
IceY2K1's Avatar
No idea, but try logging WOT with/without some retard values.
Old Jun 14, 2006 | 03:58 PM
DandyMax's Avatar
3.5 in the works
I can't tell you from here obviously but the standard procedure applies: Check wiring, then jumpers, then parameter settings & dip switches. And also that firmware/software/support tool versions are all the same.
Old Jun 14, 2006 | 04:04 PM
IceY2K1's Avatar
Try switching the IGN Timing Adj under Unit drop down.
Old Jun 14, 2006 | 04:08 PM
DandyMax's Avatar
3.5 in the works
The net timing still isn't available.
Old Jun 14, 2006 | 04:14 PM
IceY2K1's Avatar
Oh...I thought, since the non-Beta default was INJ Adj and the INJ Timing was greyed out, you Beta guys had the INJ Timing default.
Didn't even think of that...
Old Jun 14, 2006 | 04:15 PM
IceY2K1's Avatar
Can you verify you both have the SAME Beta version and if so, send me one?
Apparently Greddy isn't all that concerned about it getting out?
Old Jun 14, 2006 | 04:16 PM
DandyMax's Avatar
3.5 in the works
Issue solved, he needed to export his settings or connect real-time.
Old Jun 14, 2006 | 04:20 PM
DandyMax's Avatar
3.5 in the works
It is still not supposed to be available publicly, at least from what they've told me. There have been 4 different 1.15's to my knowledge and I don't know which one he has, it may not be the most current version of 1.15 (may not matter though-there are several updates being rolled into one and most are not VQ30 related).
On another note, don't know if you saw my recent 1/4 mile threads but I was having all kinds of problems with the 2-step not activating or just coming on and then deactivating before the launch even. I recently looked at the datalogs and my TPS signal is not holding for some strange reason... foot's on the floor but the % logged by the EU drops at a fairly fast rate. I'm going to have to look into this as it really frustrated me several times. Once I was sitting there at the line and it deactivated early and my rpms shot to 7900 in the split second before I'd realized what happened!!
Old Jun 14, 2006 | 04:24 PM
Kevlo911's Avatar
Kevlo for President
Alex you should see if Greddy will give it to you, tell them you need because the car doesnt run smooth on the other rpm choices.
Old Jun 14, 2006 | 04:26 PM
IceY2K1's Avatar
So there is a lien against your home by Greddy?
WTF?
Old Jun 14, 2006 | 04:27 PM
IceY2K1's Avatar
Are you tapping or intercepting the TPS signal?
Old Jun 14, 2006 | 04:31 PM
DandyMax's Avatar
3.5 in the works
I will have to look, can't remember.. i think i intercepted it.
Old Jun 15, 2006 | 10:34 AM
Kevlo911's Avatar
Kevlo for President
Anyone wanna tell me why my injector duty cycle jumps to 100 randomly? Or even 0 at WOT?
Ill send the log...
Old Jun 15, 2006 | 03:53 PM
Kevlo911's Avatar
Kevlo for President
See it can max out randomly
Or it can drop down randomly
Old Jun 15, 2006 | 03:57 PM
IceY2K1's Avatar
Send me a couple logs....zip them first.
Old Jun 15, 2006 | 04:01 PM
Kevlo911's Avatar
Kevlo for President
I only have one log so far. It's like 3mb. Whats your email?
Old Jun 15, 2006 | 04:04 PM
IceY2K1's Avatar
3MB, WTF....sent you a PM.
Old Jun 15, 2006 | 04:15 PM
Kevlo911's Avatar
Kevlo for President
Hehe, compressing it makes it tiny.
Old Jun 15, 2006 | 04:24 PM
IceY2K1's Avatar
Are you changing **** on the fly? Looks like your timing changed...
Either the stock ECU is freaking and dumping/cutting fuel or the EU isn't measuring the input correctly. Not sure...
Old Jun 15, 2006 | 04:28 PM
Kevlo911's Avatar
Kevlo for President
2nd half of log i turned off timing to see if it really worked.
Old Jun 15, 2006 | 04:30 PM
IceY2K1's Avatar
Try selecting Airflow Adjustment map, even though it is all zeros and do another log.
Old Jun 15, 2006 | 04:33 PM
IceY2K1's Avatar
You did this on the fly with the car running?
Old Jun 15, 2006 | 04:39 PM
Kevlo911's Avatar
Kevlo for President
I parked on the side of the road and did it really fast.
Old Jun 15, 2006 | 04:43 PM
IceY2K1's Avatar
Doubt it makes a difference, but config the Dip Switch on the Front Panel for the maps.
Old Jun 15, 2006 | 04:50 PM
Kevlo911's Avatar
Kevlo for President
Will do and I'll see if it makes a difference tomorrow.
