Sponsored by:
Sponsored by: CARiD
Considering the EMU as first performance mod
Old Jun 19, 2006 | 01:28 PM
rmh3093's Avatar
Only gentoo powered Maxima!
My max is in desperate need of some performance mods. I've got an inspection coming soon so im holding off on the Y-pipe. Should nothing like an accident happen in the near future, I would like to add some boost but for now its staying NA. Please correct me if I'm wrong, but from what I've read, the VQ30 is a good engine... capable of 6psi (or is it 12psi with a bigger exhaust) on stock internals. So wouldn't this mean the VQ could handle reving to 7500rpm on the stock internals? Also, I though I read that after 5k the engine starts to run real rich and that leaning out the A/F mixture >5k can gain some hp. If this is all true it would seem like getting the EMU first would be a good idea seeing that I could transfer the EMU to anyother car (should I stop modding the car or get a new car in the future) and fixing the A/F mixture has to help of all around driving, not just racing.
Any thouhts or opinions are welcome.
Old Jun 19, 2006 | 02:48 PM
Nismo3112's Avatar
Custom User Title
Bad idea IMO.
You would have to retune your a/f everytime you add a mod.
Alot of mods are reversible, even a VQ35 swap.
Old Jun 19, 2006 | 07:41 PM
SR20DEN's Avatar
VQ Wizard
The thing that holds back the VQ30 from reliable 7500rpm revs is it's heavier valvetrain and weaker oil pump. You would be safer if you held it to about 7200 unless you use a VQ35 oil pump and lighten the valvetrain.
I think going to the EU is a good idea for a starting point. Because that way you'll actually learn more about what each new mod does and you'll always be able to make the most out of them.
You certainly won't be following the norm here which is slap on as many parts as you can and pray they add up to something good.
Old Jun 19, 2006 | 08:08 PM
DandyMax's Avatar
3.5 in the works
He's baaack.....
To the OP: your A/F will be just fine for normal driving since it's closed loop (O2 sensor feedback). You would only need to adjust A/F under WOT. And while the EU is a worthwhile purchase, for most people it is difficult to just jump right in with it unless you have prior knowledge/experience with wiring and tuning a car. It's nowhere near as simple as bolting on an intake or similar. Just mentioning it FWIW...
Old Jun 19, 2006 | 09:00 PM
2slow4u's Avatar
Now i noticed someone stated use the 3.5 oil pump can you use it without modifications?
Old Jun 19, 2006 | 09:15 PM
NmexMAX's Avatar
dot dot dot ...
It be interesting to se what a stock A32 could do. Stock meaning no bolt ons, just EMU 'conditioning'.
Old Jun 19, 2006 | 10:14 PM
krismax's Avatar
Father of the 00 VI
it bolts right on ,make sure you keep the 3.0 ring gear on the crank
Old Jun 19, 2006 | 10:22 PM
95BLKMAX's Avatar
indeed it would be
Old Jun 20, 2006 | 06:45 AM
Kevlo911's Avatar
Kevlo for President
I was always under the impression that the stock ECU had a pretty flat AF line from the factory, I am sure he can tweak a few HP out of it tho.
I hope you are good with wires.
Old Jun 20, 2006 | 07:19 AM
95BLKMAX's Avatar
It is pretty flat, but on the rich side. With no correction on the SAFC, I had my a/f at stoich up to 3000, then it dropped as the ECU switched to open loop. From about 3800-redline it held it pretty flat at 12.0:1 on my car. But then again, my car wasnt bone stock when I first dynoed. I'd love to see what the a/f looks like on a bone stock 4th gen
Old Jun 20, 2006 | 08:26 AM
rmh3093's Avatar
What would be involved in lightening the valvetrain?
I was hoping that having the EU installed prior to any real modding would help me learn a lot and get the most out of each mod once I learn what Im doing and whats going on...
Do I still need the 17deg timeing advance w/ the ConsultII or can I do that equivelent with the EMU? I am very comfortable with electronics/wiring in cars, I think I could handle the install. Its the mechanical/tuning of cars that Im new with.
Old Jun 20, 2006 | 09:30 AM
BigLou93SE's Avatar
I was actually thinking that exact same thing
Old Jun 20, 2006 | 12:18 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I vote no on the EU as a first mod, if interested in improving power or faster 1/4 times, ie not just to screw around/learn more about engine controllers.
Get a Ypipe(or if you have the $$$ headers) and a JWT/Stillen POP charger first. Then I'd say get an EU and start playing with your AFR/timing.
Old Jun 20, 2006 | 01:03 PM
rmh3093's Avatar
Well the Y-pipe is definately coming, I just think it would make sense to wait till end of July after my NY state inspection to install that. As for the pop charger... I have a GAB which should would fine and I replaced my resonator with a regular straight pipe.
Im going to be installing my 8" widescreen touchscreen LCD and car computer soon so since most of the interior was going to be out to route wires it would be a good time to wire up the EMU.
Too bad i chopped up my air box and ditched my resonator and cant give you guys a real pre bolt-on dyno with just A/F tuning
Old Jun 20, 2006 | 01:11 PM
NmexMAX's Avatar
dot dot dot ...
8" widescreen and....and thinking of EMU for a mod..
So what will happen next year for inspection?
Old Jun 20, 2006 | 01:17 PM
rmh3093's Avatar
My HU died so I decided to build a car computer instead of buyinbg a new HU. I built the computer for my car over winter and was waiting for $$$ to buy the touchscreen. Thats project A im working on.
Project B is get the Max some more ponies. The EMU would be sweet to have and would integrate into the dash LCD so I dont have to have a laptop floating around in my car to data log and tune with.
Well if I end of having to swap my stock Y-pipe back in for an inspection Id rather not put it on for a week and then take it right back off to put back on.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
REDinLV
Sep 28, 2015 12:31 AM
Socalstillen
Sep 26, 2015 12:01 PM
