Sponsored by:
Sponsored by: CARiD
Question For the AUTO TECHS/ TIMING ADVANCE
Old Jul 5, 2006 | 05:47 PM
doc2278's Avatar
Doctor D I presume???
I was talking to a friend of the family who is higher-up in the Firestone Chain, So I asked the question if they use a consultII unit. I was told no BUT,.... It might be possible the use their 10k unit called.MOTUS sound Familiar? another one was called OTC he said. The question I have first of all to advance the timing has anyone used the device? #2 does the ECU reset the timing after this is done, meaning the ecu deletes the changes made from the unit. #3 whats the process in order to run the program properly, ( cause it damn hard to find a consultII and an end user that is willing to make the change locally) Bump?
Old Jul 5, 2006 | 07:07 PM
MaximaSE96's Avatar
Maxima Owner
i dunno if u can do it through the consult port....but if u do change is i dont think the ECU will reset it
Old Jul 6, 2006 | 03:28 AM
MDeezy's Avatar
someone correct me if I'm wrong.
If your ecu is RAM based it the changes should stick. For us 4th genners with ROM based ecus any changes wont stick, which is why we need a piggyback.
Old Jul 6, 2006 | 02:35 PM
killerVQ30DE's Avatar
Lightbulb IC chip to replay Consult commands
yeah I think your right BUT!! I have a consult cable, with the cable you can change settings but of course they are lost when you turn the car off. AGAIN BUT!! The consult cable just sends serial commands thru consult port so it should be possible to burn a IC that when powered up sends a burst of serial commands that reprogram the car at every start.
discuss.
Old Jul 6, 2006 | 02:54 PM
Matt93SE's Avatar
STFU n00b!
been discussed already. go read.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Balkins
Feb 1, 2016 12:45 AM
incubusjohnny
Nov 3, 2015 05:18 PM
Hawkeye61
Aug 12, 2015 06:45 PM
1992maximase30
Aug 5, 2015 09:27 PM
